Renault Master 2.3 165HP 2019: DTC010016 & DTC203116 Check Injection at 90km/h
Contact13 4242 0
  • Suspect faulty air flow sensor or wiring fault
    #1 21572041
    Contact13
    Renault Master 2.3 165HP 2019 year
    Hi there, I have a problem with my Master. Around 90 km/h check injection message appears and cuts the power of the car for 2-3 seconds after it goes normally again.
    DPF, Ad Blue and EGR are off.
    The following error appears on Autel Scan:
    DTC010016 Air Flow Sensor Circuit/Circuit Voltage Below threshold
    DTC203116 Cat.Conv.Upstream temperature sensor circuit /circuit voltage below threshold
    I’ve been to 3 garages and they haven’t fixed my issue.
    Any idea what to do? To try and change air flow sensor?
