Toshiba 43V5863DG Red/Green Lights Flashing, Black Screen Issue
spantor 2148 12
How do I fix a Toshiba 43V5863DG that flashes red and green lights, shows the logo, then stays on a black screen using USB firmware?
The TV usually needs the correct MB130 USB firmware because the boot sequence is corrupted or the wrong software/model is being used [#21472763] Put the unzipped `mb130_en.bin` file on the smallest USB stick you have and start the update from USB [#21472763] If the OK key seems inactive, the firmware may be for a different model or remote-control code, so verify that the software matches the TV before flashing [#21472763] A temporary download link for the file was also shared in the thread, but it was explicitly posted at your own risk [#21472663]
  • Requesting USB firmware for Toshiba 43V5863DG
    #1 21471385
    spantor
    Mark:Toshiba
    Model: 43v5863dg
    Chassis (main board, components): MB 17mb130s
    LCD Screen/Panel (if exist): ves430qnyl-2d-n01
    More informations:
    Hi Colleagues.
    I have a problem with the red and green lights always flashing. The Toshiba logo is displayed at the beginning but then the screen is always black. It does not respond to anything.
    Does anyone have firmware by usb for this Toshiba?
    Thanks in advance.
  • #3 21472654
    spantor
    >>21472449
    Thanks for the reply Michal99.
    There is not a single valid link to download the file in this post.
  • #5 21472755
    spantor
    >>21472663
    Thank you very much for the file.
    Unfortunately, all the attempts said "upgrade error" until finally the TV was dead, there is no backlight. Only the standby light is red and green. I imagine that the TV is definitely finished.
    Use unzipped mb130_en.bin on the USB stick
    #6 21472763
    yokoono51
    Help: 172
    Rate: 316
    I think you know the procedure and you did the right thing when installing the software.
    1. The boot sequence is corrupted and the installation does not start
    2. You have rewritten software from another TV model and which has a different remote control code (the OK key is inactive).
    3. You are using a stick with the smallest capacity possible.
    4. Put the unzipped mb130_en.bin file on the stick.
  • Power cut too quickly may have killed backlight reset
    #7 21472893
    spantor
    >>21472763
    I think the whole procedure was correct.
    I've had the same thing happen to me as in this video.
    https://www.youtube.com/watch?v=KvZWPsWuw1Y
    Several times I got the green lines and I cut the power and the same procedure happened again with the same result. I think the problem was that in one of the attempts I cut the power too quickly. Then the TV never turned on the backlight again.
    My ok button works, I've checked it with my phone. I've copied all the files directly to the pen drive (unzipped, of course).
  • #8 21515594
    mc151018
    >>21472663
    I wonder if you can reupload the firmware file I'm having the same problem
  • #9 21516164
    yokoono51
    Help: 172
    Rate: 316
    mc151018 wrote:
    >>21472663
    Try at your own risk. Link valid for 3 days.
    https://files.fm/u/gfzwgjdgyc
  • #10 21627807
    ceszpam
    Hi, same problem as above. Can you please send me a valid link to the Toshiba 55L5863DG? Alternatively show where I can download it. The manufacturer's website does not help.
  • #11 21628114
    billobirillo
    Help: 338
    Rate: 798
    are you sure about the model?
    post a photo of the sticker on the back of the tv: it needs to identify the correct software
  • #12 21628173
    ceszpam
    Information label of Toshiba TV model 55UT7830G with technical specifications
    Added after 1 [minute]:
    I actually made a mistake. The correct model is 55U7863 DG
  • #13 21628226
    billobirillo
    Help: 338
    Rate: 798
    model TOSHIBA 55U7863DG
    main 17MB130S
    panel VES550QNUS-2W-U02
    usb full software link
Discussion concerns a Toshiba TV with MB17MB130S main board and VES430QNYL-2D-N01 panel that powers on with flashing red/green LEDs, shows the Toshiba logo briefly, then remains on a black screen with no response. The main suggested remedy is USB firmware recovery using the correct mb130_en.bin file and a properly prepared USB stick, but attempts to flash the provided firmware resulted in “upgrade error” and eventually loss of backlight, leaving only standby red/green indication. Later replies stress verifying the exact model from the rear label before using software, as similar symptoms may occur on different Toshiba variants such as 55L5863DG and 55U7863DG.
TL;DR: 3-day links expire fast; "Try at your own risk." Use the correct 17MB130S USB firmware to fix red/green LED boot loops on Toshiba 43V5863DG/55U7863DG. This FAQ helps owners recover from black-screen startup without bricking. [Elektroda, yokoono51, post #21516164]
Why it matters: A wrong or expired package can block the OK-triggered installer and leave your TV unresponsive.
What does red/green LED flashing with a Toshiba logo then black screen mean on 43V5863DG?
Those are the symptoms reported for the 43V5863DG with 17MB130S and panel VES430QNYL-2D-N01. Users seek a USB firmware recovery when this appears. It points to a software boot issue rather than a backlight failure at first. [Elektroda, spantor, post #21471385]
How do I start a USB firmware recovery on 17MB130S?
Follow this 3‑step sequence:
  1. Use a small‑capacity USB stick and copy the unzipped mb130_en.bin to the root.
  2. Power the TV off completely, then insert the USB stick.
  3. Start the update with the OK key sequence and wait for completion. “Put the unzipped mb130_en.bin file on the stick.” [Elektroda, yokoono51, post #21472763]
I need firmware for Toshiba 43V5863DG. Where can I get it?
Community members shared time‑limited links. One example was posted “valid for 3 days.” If a link expired, ask for a reupload in the thread and confirm your exact model before flashing. [Elektroda, yokoono51, post #21516164]
My USB update shows “upgrade error.” What should I check?
Check four things: the boot sequence may be corrupted; you might have software for another model; that mismatch makes the OK key inactive; and you should use the smallest‑capacity USB stick with mb130_en.bin at the root. [Elektroda, yokoono51, post #21472763]
During update I see green lines. Should I interrupt power?
Do not cut power during those progress screens. A user who interrupted too quickly reported, “Then the TV never turned on the backlight again.” Wait until the process finishes and the set reboots itself. [Elektroda, spantor, post #21472893]
After failed update my TV has no backlight and only red/green LEDs. Is it bricked?
This state was reported after repeated “upgrade error” attempts. It suggests severe software corruption. Try the correct mb130_en.bin on a small USB again. If it stays unchanged, professional service or board work may be required. [Elektroda, spantor, post #21472755]
How do I confirm the exact model and panel before flashing?
Check the rear sticker and share a clear photo if asking for files. As one expert notes, “it needs to identify the correct software.” This avoids remote‑code and panel mismatches during recovery. [Elektroda, billobirillo, post #21628114]
What if the OK key on the remote does nothing during update?
'the OK key is inactive' indicates the firmware is for another model with a different remote code. Get software that matches your exact sticker details. [Elektroda, yokoono51, post #21472763]
Why can’t I find firmware on Toshiba’s website?
A user reported the manufacturer’s site did not help for their 55-inch variant. Owners often rely on community‑shared OEM packages for the 17MB130S platform. [Elektroda, ceszpam, post #21627807]
Can I use firmware from another Vestel-based Toshiba with 17MB130S?
Avoid cross‑model firmware. Remote codes can differ and the OK key will not start the installer. Always match the exact model and panel ID. [Elektroda, yokoono51, post #21472763]
What are the exact board and panel IDs for 43V5863DG?
Mainboard: 17MB130S. Panel: VES430QNYL-2D-N01. These identifiers help you request or choose the correct USB package. [Elektroda, spantor, post #21471385]
What are the exact board and panel IDs for 55U7863DG?
Mainboard: 17MB130S. Panel: VES550QNUS-2W-U02. Use software that explicitly matches these IDs to ensure a successful recovery. [Elektroda, billobirillo, post #21628226]
Are community firmware links permanent?
No. As one sharer wrote, “Link valid for 3 days.” Download promptly, verify integrity, and request a reupload if needed. [Elektroda, yokoono51, post #21516164]
