Convert 1 cm to Pixels: Real-World Measurement Conversion Guide
cinek13 119183 8
  • #1 2097920
    cinek13
    Help: 7
    Rate: 20
    As in the subject matter, I have a question: 1 cm is how many pixels in reality?
  • #2 2097933
    BolzZ
    Help: 56
    Rate: 67
    lol
    and how big pixels ?? :D
  • #3 2098009
    arnoldk_20
    Help: 290
    Rate: 114
    It depends on the DPI resolution, e.g.
    for 72 DPI it comes out 28 pixels
    for 300 DPI it comes out 118
  • #4 2098098
    tzok
    Help: 3177
    Rate: 6558
    A 15 "TFT panel with a resolution of 1024x768 has 85 DPI, so 1cm on such a monitor is 33 pixels.
  • #5 2098761
    cinek13
    Help: 7
    Rate: 20
    it concerns pixels in paint :) I have to make a drawing for 5x5 cm and I don't know how many pixels to set. I have a 17 "monitor with a resolution of 1024x768
  • #6 2098977
    tzok
    Help: 3177
    Rate: 6558
    and this should be 1 cm on the monitor or 1 cm on the print ... paint is not very suitable for this.
  • #7 2099172
    BolzZ
    Help: 56
    Rate: 67
    violate in autocad it will be correct :P
    and if not, print a section or better a square and count the scales :P damn, what's the problem ???
  • #8 2099190
    Tommy82
    Help: 455
    Rate: 1074
    image-> attributes select cm
    and enter 5 as height and 5 as width
  • #9 2099847
    cinek13
    Help: 7
    Rate: 20
    Thanks to everyone for your help, I already know how to do it
The discussion centers around converting centimeters to pixels, emphasizing that the conversion depends on the DPI (dots per inch) resolution. For example, at 72 DPI, 1 cm equals approximately 28 pixels, while at 300 DPI, it equals about 118 pixels. A specific case is mentioned where a 15" TFT panel with a resolution of 1024x768 has a DPI of 85, translating 1 cm to 33 pixels. The author seeks to create a 5x5 cm drawing in a graphics program, leading to suggestions on how to set dimensions in pixels. The conversation also touches on the importance of distinguishing between screen and print measurements.
