Printing Large 150x100cm Photo on Multiple A4 Sheets: Software Recommendations & Techniques
ozy2001 168638 12
How can I print a large photo across multiple A4 sheets so I can cut and assemble it into one big image?
You can print the image as a tiled poster across multiple A4 sheets using poster-printing mode in the print dialog; for example, in Paint go to Print → Preferences → Advanced → poster printing and set the dimensions you want [#14200034] This only works if the printer driver supports poster printing, otherwise the option may not be available [#19474882] If your current program does not offer it, use a dedicated tool such as Easy Poster Printer (free, works on Windows 10) to split the image into the exact number of pages you want [#19474789] Another suggested tool is Rasterbator Standalone [#5817861] You will still need to cut the pages because printers have non-printable margins, and careful trimming with a ruler and knife will hide the joins [#5817359]
  • #1 5816493
    ozy2001
    Help: 88
    Rate: 38
    Hello colleagues.
    I need a program that can do something like this, or some simple "recipe". How to print a very large photo on several A4 sheets?
    Let's say the photo has a size of 150 x 100 cm.
    The idea is to print them on a few sheets, cut them, stick them together and enjoy the large format.
    I do not hide, the matter is quite urgent.
    Thanks and regards.
  • #2 5816541
    volt1
    Level 30  
    Help: 179
    Rate: 242
    Most standard printer drivers can do this. Just open an image, select print, and when the print window pops up, choose your preferences. There should be an option to print on several sheets.
  • #3 5816590
    ozy2001
    Help: 88
    Rate: 38
    Well. It is not as simple as it may seem.
    Using Photoshop - I can reduce the size of the image - is not an option, I can print one specific part.
    Ps. Such a number to put into Word and print it is also not possible, because this program also cannot cope with such a large picture.
    I used to have a applet, but it was a few years ago ...
  • #4 5816701
    marek003
    Level 40  
    Help: 801
    Rate: 488
    Are you sure??
    Most "standard drivers" do, but they can put a few pages on one sheet of paper, not a part of a page on the entire sheet.
    As for the main plot, it must have been some kind of wall mural software or something like that. Did you search on google?
  • #5 5816753
  • #6 5816773
    ozy2001
    Help: 88
    Rate: 38
    That's what it is all about - a kind of photo wallpaper, but I already have a file of the right size - size x * y and the appropriate resolution. The poster making programs make a number such that they enlarge the image and "dots" appear. The enlarged image is clearly visible from a distance of about 5 meters. I am only 1.5 meters from the window in the shop window, then the street behind it is a huge hedge and a sidewalk. As the customer walks past the window, the printed image will look like a colored mosaic from his point of view. It will be clearly visible from the street, but it is too busy, and you cannot see the other sidewalk because there is this "Hedge"
    It is with stripes and cuts, I see it on average - but if there is no other way, the ball will have fun.
  • #7 5816841
    Krzyq
    Help: 46
    Rate: 32
    Maybe a stupid statement - but paint can even do that. Haven't you tried? Preview and print settings - separate large files into multiple sheets. In fact, every graphics program Corel7 offered, by itself, large scaled images printed like banners on several sheets without any need to impose any mesh. I remember that in Corel I struggled more with a good rescaling of a too large drawing to A4, but when we were making posters and slogans for the school anniversary, he printed it without any problems.
  • #8 5817359
  • #9 5817861
    leonov
    Help: 1039
    Rate: 2247
    Enter Rasterbator Standalone in google :D
  • #10 14200034
    Yoo!
    Rate: 117
    Some time passed, but no specific answer was given.
    We do it like this, Paint :arrow: print :arrow: (in the print window) Preferences :arrow: (in the printing preferences pane) Advanced :arrow: poster printing, we choose the dimensions we are interested in, and that's it :D
    It is not said that this is only in Paint, but in every program in the print settings.
    I hope it will be useful to someone :)
  • #11 19474789
    prosiak22
    Help: 15
    Rate: 131
    Easy Poster Printer (EPP)
    Free, prints great, 30 seconds and we have divided the image into the number of pages we want.
    Works under Win 10
  • #12 19474882
    misiek1111
    Level 37  
    Help: 325
    Rate: 1097
    Provided that the printer driver supports the printing of posters. If it doesn't, then bryndza.
  • #13 19921472
    martasobas6
To print a large photo (150x100 cm) on multiple A4 sheets, users can utilize various software solutions and techniques. Standard printer drivers may allow for multi-sheet printing, but specific applications like Corel Draw and Paint offer more control over the process. Corel Draw can print large images by using registration marks for cutting, while Paint provides a poster printing option in its advanced settings. Easy Poster Printer (EPP) is another recommended free software that efficiently divides images into desired page sizes. Users should ensure their printer driver supports poster printing to avoid limitations. Cutting and aligning the printed sheets is necessary due to non-printable areas on standard printers.
