How to Measure Clamping Voltage of TVSS at 1100V 3A—Test Circuit Setup?
291 7
  • #1 21657763
    Jerry Kelley
  • Constant-current TVS test setup with 2 µF capacitor
    #2 21657764
    DAVID CUTHBERT
  • Need a higher capacitor charge for 1100 V clamp test
    #3 21657765
    Jerry Kelley
  • #4 21657766
    Jerry Kelley
  • Need 2.5 kV source for TVS clamp test
    #5 21657767
    DAVID CUTHBERT
  • #6 21657768
    Jerry Kelley
  • Capacitive discharge or inductor test setup for TVS clamping
    #7 21657769
    DAVID CUTHBERT
  • Alternative test topologies for high-voltage TVS clamping tests
    #8 21657770
    DAVID CUTHBERT
Measuring the clamping voltage of a transient voltage surge suppressor (TVSS) at a specified current (3A) and clamp voltage (1100V) requires a test setup that simulates the standard 10/1000 µs surge waveform, characterized by a 10 µs rise time and 1000 µs exponential decay. A pseudo constant current source can be created using a high-voltage charged capacitor (e.g., 2 µF charged to 2500V) in series with a resistor (around 500 Ω) to limit current to 3A. The capacitor is charged through a high-value resistor (e.g., 100 kΩ) from a high-voltage power supply. Voltage across the TVS is monitored with a 100:1 Tektronix oscilloscope probe. The current is inferred from voltage and resistance values. Alternative methods include using a half-cycle 60 Hz AC pulse controlled by an SCR to generate the surge, or employing a 2H inductor charged to 3A and then disconnected to induce voltage rise until the TVS clamps. For high-voltage charging, specialized HV power supply bricks (e.g., Ultravolt 20W 5kV bricks) can be used. Series capacitors with equalizing resistors ensure voltage sharing and prevent overvoltage on individual capacitors. More advanced setups involve linear current amplifiers driven by arbitrary waveform generators for precise waveform control, or vacuum tube-based amplifiers for robust, high-current testing. MOSFETs (IXYS 2.5 kV and 4 kV) and autotransformer topologies are also discussed for generating the required test conditions.
