1-120VDC to 115VDC 250A High Power DC-DC Converter for Lithium Battery Charging
279 8
  • #1 21657771
    Andrew Mollmann
  • #2 21657772
    Joshua Bishop
  • #3 21657773
    Andrew Mollmann
  • Questioning the 1–120 V input and 250 A spec
    #4 21657774
    Olin Lathrop
  • #5 21657775
    Andrew Mollmann
  • Request for full system specs and power budget
    #6 21657776
    Olin Lathrop
  • Generator-driven DC-DC converter must handle variable input voltage
    #7 21657777
    Andrew Mollmann
  • #8 21657778
    DAVID CUTHBERT
  • #9 21657779
    Henry Chang
The discussion centers on designing or sourcing a high-power DC-DC converter capable of converting a variable input voltage range (initially stated as 1-120VDC, later refined to 30-120VDC) to a stable 115VDC output at currents up to 250A for charging lithium-ion batteries in an electric vehicle application. The battery pack specified is a 100Ah lithium-ion pack rated around 102VDC, requiring 115VDC charging voltage and capable of continuous 300A charge/discharge current with peaks up to 400A. The input source is a small gasoline engine coupled to an electric motor acting as a generator, producing variable DC voltage depending on engine RPM. The challenge involves handling a wide input voltage range with high current output (up to approximately 23-30kW power), necessitating a robust DC-DC converter design or a customizable prebuilt solution. The complexity of lithium-ion battery charging and the need for appropriate charging electronics were noted, with a suggestion to consider chargers from the battery manufacturer. A simple high-power diode rectifier was also proposed as a potential solution for converting the generator output to DC suitable for charging. The discussion highlights the importance of clarifying realistic specifications, understanding battery charging requirements, and the technical difficulties in designing a high dynamic range, high current DC-DC converter for EV battery charging.
