Correct Reference Designator for Terminal Block and Coin Battery Holder?
753 9
What reference designators should I use for a terminal block and for a coin battery holder?
Use TB for a terminal block and XBT for a coin battery holder; the battery itself is designated BT [#21659185] [#21659190] ANSI/IEEE 315 states that the class designation for a terminal block is TB, and for a battery it is BT, with the holder getting an X prefix just like a fuse holder uses XF [#21659185] Example designators given in the thread are TB6 for the terminal block and XBT1 for the battery holder [#21659190]
  • #1 21659182
    KUDAYA KUMAR
  • #2 21659183
    Cody Miller
  • J for jack, P for plug, B or BT for coin cell
    #3 21659184
    Bob Casiano
  • ANSI/IEEE 315 designations for terminal blocks and battery holders
    #4 21659185
    Lawrence Joy
  • #5 21659186
    Cody Miller
  • #6 21659187
    Bob Casiano
  • Recommend ANSI/ASME Y14.44 and IEC 60617 standards
    #7 21659188
    Lawrence Joy
  • Connector designators should use P or J numbering
    #8 21659189
    Val Vonheeder
  • Terminal blocks use TB and battery holders use XBT
    #9 21659190
    Val Vonheeder
  • #10 21659191
    vikasbly44
The correct reference designator for a terminal block is "TB" according to ANSI/IEEE 315 clause 22.4, with terminals treated similarly to connector contacts (e.g., TB6-3). The designation "J" is commonly used for jacks (fixed connectors) and "P" for plugs (movable connectors), but these letters do not inherently indicate gender (male or female contacts). For coin battery holders, the appropriate designator is "XBT," where "BT" represents the battery and the prefix "X" denotes the holder, analogous to fuse holders ("F" for fuse, "XF" for fuse holder). The letter "B" can also be used for batteries but may cause ambiguity as it sometimes denotes motors or blowers. Standards such as IPC-2612, ANSI/IEEE Std 315-1975, ANSI/ASME Y14.44-2008, and IEC 60617 provide guidance on schematic symbols and reference designations. Connector contacts are numbered or lettered and appended to the connector designator (e.g., P5-12, J3-aa). These conventions help minimize confusion in schematic documentation and component identification.
