How to Boost 11.8V to 12V at 1A for Old HDD Using Commodore 64 Power Supply?
240 7
  • 11.8 V is too low for HDD spin-up
    #1 21659847
    Stephen Shaffer
  • #2 21659848
    Ralph Pruitt
  • #3 21659849
    Per Zackrisson
  • #4 21659850
    Stephen Shaffer
  • #5 21659851
    Ralph Pruitt
  • #6 21659852
    David Deleonardo
  • #7 21659853
    Siraj A
  • #8 21659854
    Frank Bushnell
A user attempts to power an old hard drive using a Commodore 64 power supply, which outputs +12V measured at 11.8V. The hard drive fails to spin up properly at 11.8V but works at a true 12V from a lab power supply. The Commodore 64 PSU is rated for 1A at 12V, but the hard drive's current requirements are unknown. Discussion highlights that many hard drives and even modern ATX power supplies tolerate ±5% voltage variation, so 11.8V should generally be sufficient. The hard drive may have failed due to insufficient current or other issues. A suggested solution to increase the PSU output voltage slightly is to modify the feedback resistor divider in the PSU by adding a resistor to raise the output voltage above 11.8V. Further advice includes verifying the current draw of the hard drive at startup and under load, and testing the PSU's current capability and voltage stability under load to ensure it meets the hard drive's requirements.
