EMF Probe With Meter Circuit: What Type of Meter Is Used and How Does It Work?
519 43
What kind of meter is used in this EMF probe circuit, and how does the meter section work with AC or DC current?
It uses a small DC panel meter, specifically a 250 uA full-scale ammeter/D'Arsonval movement, not an AC meter [#21659867][#21659871] The two diodes rectify the signal so only positive pulses reach the meter, which makes the movement respond to the average DC component of the waveform rather than negative swings [#21659869][#21659905] One diode also gives the negative transitions a path to ground so the meter arm is protected from slamming back to zero [#21659869] In simulation, the meter reading should be taken after the diodes, because before rectification you will see the AC waveform and it can appear to average near zero [#21659880][#21659884] If you are seeing only tiny pA/fA currents, the thread suggests checking the excitation/coupling setup and the load values, because the original circuit expects a 9 V supply and a very sensitive 250 uA meter movement [#21659867][#21659880]
  • #31 21659896
    Mike Burr
  • #32 21659897
    Luca Tarpini
  • Dual-supply op amp unsuitable for 9V single supply
    #33 21659898
    Mike Burr
  • #34 21659899
    Mike Burr
  • #35 21659900
    Luca Tarpini
  • Second probe version with improved gain control
    #36 21659901
    Mike Burr
  • #37 21659902
    Luca Tarpini
  • #38 21659903
    Mike Burr
  • #39 21659904
    Luca Tarpini
  • #40 21659905
    Mike Burr
  • #41 21659906
    Luca Tarpini
  • #42 21659907
    Mike Burr
  • #43 21659908
    Luca Tarpini
  • #44 21659909
    DAVID CUTHBERT
The discussion centers on understanding and simulating an EMF probe circuit with a meter, specifically clarifying the type of meter used and its operation. The meter is identified as a small DC panel ammeter with a full scale deflection (FSD) of 250 µA, measuring DC current resulting from rectified AC signals. The circuit uses diodes and a capacitor to rectify the AC signal induced by an electromagnetic field into a DC current suitable for the D'Arsonval analog meter movement. Simulation challenges include observing extremely low currents (picoamperes or femtoamperes) and negative oscillations in the meter current, attributed to simulation setup issues such as source modeling and measurement points. Proper simulation requires placing the inductor as the field coupling element, using a sinusoidal source at appropriate amplitude and frequency, and measuring current after the diode rectification stage. Frequency response shows the circuit performs well from 10 Hz to about 1-2 kHz, with roll-off and reduced meter current amplitude at higher frequencies like 10 kHz, which is expected due to circuit filtering effects. Practical considerations include using a 9 V power supply, selecting suitable op-amps (e.g., LF351 or alternatives like LM386 for single supply operation), and understanding that the meter current should be a DC level after rectification to avoid meter needle oscillation. A second, more stable version of the probe circuit with improved gain control and isolation is also referenced. The discussion emphasizes trial and error in coil design and component selection to optimize sensitivity and meter response.
TL;DR: It’s a 250 µA full-scale DC panel ammeter driven by a rectified EMF probe; “The meter is a small dc panel meter with a FSD of 250uA.” [Elektroda, Cody Miller, post #21659871]
Why it matters: If you know the meter type and rectification, you can simulate, build, and troubleshoot EMF probes with confidence. This FAQ is for hobbyists and students asking how the EMF probe’s meter is chosen, wired, and interpreted.
What kind of meter does this EMF probe use?
It uses a small DC panel ammeter with a 250 µA full‑scale deflection (FSD). That means 250 µA drives the pointer to the end of the scale. “uA units gave it away.” [Elektroda, Cody Miller, post #21659871]
Is the meter measuring AC or DC?
The probe rectifies the pickup signal with diodes, so the meter sees a DC level proportional to field strength. Negative swings are shunted, preventing the pointer from slamming below zero. [Elektroda, Mike Burr, post #21659869]
How do the two diodes around the meter actually work?
One diode and the capacitor form a rectifier that passes positive pulses to the meter. The second diode provides a return path for negative transitions, protecting the delicate D’Arsonval movement from reverse current. [Elektroda, Mike Burr, post #21659869]
Why do I see tiny pA/fA currents in SPICE?
Your source or coupling may be wrong. Drive the pickup coil via a realistic coupled inductor and measure current after the rectifier. Ensure the meter is modeled as a small resistance path, not an ideal probe. [Elektroda, Mike Burr, post #21659875]
My plot shows current going negative—did I wire it wrong?
You likely measured before the diodes. Measure across the meter, after rectification. The display before the diodes will look bipolar, but the meter side should be unipolar. [Elektroda, Mike Burr, post #21659880]
What frequency range does this circuit respond to?
Builders observed solid response from about 10 Hz up to roughly 1–2 kHz, with reduced amplitude and lower average reading near 10 kHz due to roll‑off. [Elektroda, Luca Tarpini, post #21659886]
I see 500–600 µA in simulation. Will the 250 µA meter saturate?
Yes, at the meter terminals that exceeds FSD and will over‑deflect. Real coils often pick up µV‑level signals, so practical current can be lower than aggressive simulations suggest. [Elektroda, Mike Burr, post #21659903]
What does “roll‑off” mean here?
Roll‑off is gradual attenuation as frequency rises. The probe’s R‑C network and amplifier bandwidth reduce high‑frequency gain, so 10 kHz shows a smaller, more zero‑centered average. [Elektroda, Mike Burr, post #21659892]
Is the transistor stage necessary, or can the op‑amp drive the meter?
One participant notes the op‑amp can drive the 250 µA meter directly. The added transistor isn’t strictly required for meter drive in this design. [Elektroda, DAVID CUTHBERT, post #21659909]
Should I use a single‑supply or dual‑supply op‑amp?
The schematic shows a single 9 V supply. A single‑supply audio op‑amp can behave better here than a dual‑supply part like the LF351 run from a single rail. [Elektroda, Mike Burr, post #21659898]
Why does SPICE force me to add resistors across inductors or use tiny series resistances?
That’s a convergence aid. Adding a small resistor in parallel with the inductor, or a tiny meter resistance, helps the solver. It doesn’t represent ideal behavior; confirm by measuring after the diodes. [Elektroda, Luca Tarpini, post #21659881]
How should I generate the EM field for simulation?
Use a sinusoidal source coupled through a transformer model into the 1 mH pickup. Drive reasonable amplitudes and observe current after the rectifier into the meter model. [Elektroda, Luca Tarpini, post #21659868]
What analysis type should I run?
Use transient (time‑domain) analysis to see rectified meter current rise and settle. Simulators like MultiSim also show oscilloscope traces across the meter versus time. [Elektroda, Mike Burr, post #21659884]
What power source do I need to build it?
A 9 V battery is sufficient for the original schematic. Wire it with correct polarity and decouple the op‑amp supply as recommended. [Elektroda, Mike Burr, post #21659880]
Is there a more stable version of the EMF probe?
Yes. A second version improves gain control and isolates the meter and audio outputs. It was suggested for better stability during testing. [Elektroda, Mike Burr, post #21659901]
Quick 3‑step: how do I wire and read the meter?
  1. Place the meter in series after the rectifier diode and smoothing capacitor.
  2. Observe polarity so current drives upscale.
  3. Calibrate so 250 µA equals full‑scale under a known field. [Elektroda, Mike Burr, post #21659869]
