Calculating Resistor Value for 12V DC Motor on 120V AC with Rectifier Bridge
534 10
How can I reduce 120V AC to a safe supply for a small 6-12V DC motor after a bridge rectifier, and what resistor value should I use?
You should not use a series resistor for this motor supply; the replies say a resistor would need to be very high power and would get hot, so a proper low-voltage AC-to-DC adapter or a capacitive dropper is the better approach [#21659963][#21659969][#21659967] The motor was described as 6–12V DC, about 6W at 5.5V and roughly 1.2A under load, so the bridge rectifier alone is not enough on 120V AC [#21659966] One suggestion is to feed the bridge from the AC line through a film capacitor to limit current; one reply suggests starting with a 1.0 µF / 250V+ cap, while another suggests starting around 0.05 µF and increasing in steps while measuring the motor voltage [#21659967][#21659969] Output smoothing capacitance is optional, and any mains-side capacitors must be properly voltage-rated [#21659969]
  • #1 21659962
    Eugene Vicknair
  • #2 21659963
    Eduardo Viramontes
  • #3 21659964
    Eugene Vicknair
  • #4 21659965
    Angel Garcia
  • #5 21659966
    Eugene Vicknair
  • Suggesting capacitor or adapter instead of resistor for motor supply
    #6 21659967
    David Deleonardo
  • #7 21659968
    Angel Garcia
  • Suggests capacitive dropper with low-value test capacitors
    #8 21659969
    Frank Bushnell
  • #9 21659970
    Frank Bushnell
  • #10 21659971
    Frank Bushnell
  • #11 21659972
    Frank Bushnell
A 12V DC motor rated around 6 watts and 1.2 amps under load is being powered from a 120V AC source through a diode bridge rectifier. The user initially assumed a resistor was needed to protect the motor but experienced motor damage and tripped breakers when connecting the motor directly after the rectifier. Responses clarify that a resistor is generally unnecessary unless current limiting or torque estimation is required. Instead, a capacitor is recommended to filter the rectified output. To safely power the motor from 120V AC, options include using an AC-to-DC adapter with appropriate voltage output or implementing capacitive AC voltage dropping with film capacitors in series before the rectifier. The capacitor value depends on the desired current; starting with around 0.05 to 1.0 µF rated for 250V or higher is suggested. Inductors can also be used for current limiting but require large values. The motor wiring resembles a hairdryer motor, implying it may be in series with other circuit elements, necessitating a detailed circuit diagram for precise advice. Safety precautions include isolating the high voltage side with capacitors and avoiding direct contact with 120V AC lines. The discussion emphasizes the importance of proper voltage reduction and filtering rather than simple resistive current limiting to prevent motor damage and circuit breaker trips.
