How to Convert AC Magneto Output to DC for 12V Toy Motor and Prevent Surges?
513 8
  • Need rectifier and smoothing for magneto motor drive
    #1 21681706
    Jarrod Houghton
  • Full-wave rectification with inductor and capacitor
    #2 21681707
    David Ashton
  • #3 21681708
    Jarrod Houghton
  • #4 21681709
    Rick Curl
  • #5 21681710
    Jarrod Houghton
  • Magneto rectifier with 100 V bridge and 1000 µF filter
    #6 21681711
    David Ashton
  • #7 21681712
    Jarrod Houghton
  • #8 21681713
    David Ashton
  • Battery charging from magneto with diode and surge protection
    #9 21681714
    Roy F Alvord
The discussion addresses converting the AC output of a 5-bar phone magneto, which produces a spiky AC waveform with peak voltages around 60V, into a stable DC supply suitable for powering a 12V toy motor. Recommended solutions include using a full-wave bridge rectifier with a peak inverse voltage rating above 100V, followed by a series inductor and a large storage capacitor (approximately 1000µF rated for 60V or higher) to smooth the voltage and reduce surges. The inductor helps filter the rectified voltage, while the capacitor provides a steady supply to maintain smooth motor operation. An alternative approach involves employing a switching power supply such as the Mean Well APV-12-12, which can accept input voltages starting below its nominal 90V requirement and output regulated 12V DC without additional smoothing components. Component sourcing can be done through electronics stores or online. Additional considerations include ensuring component voltage ratings exceed peak magneto voltages and understanding that the magneto’s average voltage is lower than its peak, which affects motor performance. The discussion also briefly touches on related applications involving magneto outputs for battery charging and protection against diode failure.
