Transorb vs MOV vs National AN-1533 Circuit for Automotive 12V/24V to 5V 100mA Supply
276 6
  • Need for load-dump protection beyond transorb/MOV
    #1 21660146
    Pieter Kruger
  • Use load-dump TVS and protected LDO
    #2 21660147
    Kevin Parmenter
  • #3 21660148
    DAVID CUTHBERT
  • Switch regulator recommended for 24 V automotive supply
    #4 21660149
    Per Zackrisson
  • TLE4270 LDO chosen for low-emi automotive supply
    #5 21660150
    Pieter Kruger
  • #6 21660151
    Kevin Parmenter
  • #7 21660152
    Pieter Kruger
The discussion addresses designing a 12V/24V automotive power supply with a 5V, 100mA output, focusing on protection against load dump and overvoltage conditions. Transorb/MOV devices provide short-duration overvoltage protection, while the National Semiconductor AN-1533 application circuit offers fast response and continuous overvoltage protection. Recommended practice includes using a load dump TVS diode such as the MR2535L-D from ON Semiconductor placed at the input, combined with a regulator featuring built-in load dump protection like the NCV2931 or TLE4270 LDO. Additional protection can be achieved with self-resetting circuit breakers to prevent damage from excessive current during fault conditions. Linear Technology’s series pass voltage limiters are suggested as a pre-regulator protection before shunt clamps. Linear regulators like the TL7805 or LM317 are generally less favored due to heat dissipation and load dump vulnerability, especially in sealed enclosures, whereas switching regulators offer efficiency but may introduce EMI concerns. Automotive-grade designs often combine TVS devices and robust regulators to ensure reliability under harsh conditions, with cost considerations secondary to system safety and recall avoidance.
