Regulated power supply (darlington power) for LM317 10A 1.2..37V
kozak84 243146 121
  • A regulated LM317 power supply uses a Darlington power stage to cover 1.2–37V.
  • The design centers on a transistor-based stabilizer circuit.
  • The target output is 10A, suggesting a high-current linear supply build.
  • My proven stabilizer circuit on the transistor.
    • Regulated power supply (darlington power) for LM317 10A 1.2..37V 10A.GIF (5.94 KB) You must be logged in to download this attachment.
    kozak84
    kozak84 wrote 56 posts with rating 55. Been with us since 2003 year.
  • #2 431946
    marciu11
    Rate: 13
    And what happens with this system in the event of a short circuit?
    Is it not necessary to call the PP Stasis?
    Although I like it myself.
    MarCiu
  • #3 432064
    kozak84
    Rate: 55
    As you can see, I used a few additional LEDs on the LM317, that's probably enough. There is no output fuse in the diagram.
  • #4 432110
    andrea
    Help: 8
    Rate: 12
    How big a heat sink for it do you envision. :!: :!:
  • #5 432266
    elektronik321
    Help: 29
    Rate: 51
    You can use LM317 and add a high power transistor to it and you will have 10A.
  • #6 432322
    Ptolek
    Level 36  
    Help: 318
    Rate: 270
    What is this output coil or something else that is shown in this diagram as a spiral?
    For this system, you need a veeeeery large heat sink, if someone would like to take 10A current from it. Especially at low voltages.
    :arrow: electronics321
    This power supply is built just like that.
  • #7 432457
    stallion
    Maybe a little criticism
    26AC to 36.77VDC "NO LOAD"
    35V 2A - higher current will cause "feeds"
    and losses
    at 1.2 10 And you can forget because (greatly simplifying:
    With a consumption of 10 A, the peak-to-peak voltage is 11 V, which gives the average voltage behind the filter about 31 V
    31-1.2 * 10 is about 300 W
    The BD911 transistor dissipates a maximum power of 90 W
    A colleague forgot to mention that his transistor is cooled with liquid nitrogen (I already see how my friend checked, for example, 10V 10A)
    on this transistor, the optimal 10 A will be pulled at a voltage of about 25 and higher V
    One could give the tesla kd503 more power reserve
    A power supply with such a range of output voltages is best designed with impulse, there are ready applications.
  • #8 432559
    Veteran
    Ideal power supply for charging the Shuttle's batteries :D
    And seriously - in fact, at the smallest range and at high current, the power losses will be huge. As for the correct operation of the short-circuit protection - I am not sure.
    Power supplies of such power are currently made in the impulse technique - fear to think what transformer would be needed at such high currents.
    In the application note lm317 you can find a power supply circuit with an operational amplifier - I made it once, it works so far, quite smooth regulation of the output current - I recommend it at the beginning.
  • #9 432589
    kozak84
    Rate: 55
    My power supply cools the radiator with the fan + driver for it.
    The output coil is wound on the ring core with 1mm wire.
    The maximum voltage in this version of the LM317 is probably 37V if I want to
    have more, but it's already on a different version of this stabilizer and transistor.
    With this power supply, I have a 150W transformer.
    You can also make a similar power supply only with the voltage "-" using any power transistor PNP and LM337.
  • #10 432628
    CKsrv
    Level 32  
    Help: 8
    Rate: 87
    I think 2N5302 or 2N5686 would be a little better. Although 3 x 2N3055 would be enough. A piece of heat sink is necessary.
  • #11 433450
    Andrzej Maciejewski
    Help: 34
    Rate: 63
    The diagram shows that the stabilization of the output voltage when changing the load current from e.g. 1A to 5A is poor.
    (The voltage is stabilized on the base of the BD911 and not at the output).
  • #12 433814
    kozak84
    Rate: 55
    The transistor in this power supply acts as an element increasing the current efficiency. The output voltage is the same as that supplied to the base by the LM317.
  • #13 434478
    zipp
    Help: 6
    Rate: 13
    Andrzej is right. The voltage stabilization in this system will be lower than that of the LM317 alone. Unfortunately, transistors are not "perfect" elements. As the base current increases, the base-emitter voltage drops increase, while with the increase in temperature, the voltage drop at this junction decreases. These are the two factors that most affect the output voltage of this system. Therefore, the feedback for the voltage stabilization circuit should also include power transistors, i.e. it should be taken from the circuit's output.
    I don't know what to do, it's better to look at pdf lm317. There are diagrams of systems increasing the efficiency of the current without deteriorating the voltage stabilization.
  • #14 434695
    CKsrv
    Level 32  
    Help: 8
    Rate: 87
    Uwy will be lower but this is compensated by the considerable simplicity of the layout.
    I think that "at the beginning" (talking about the less experienced) is enough.
  • #15 434749
    Veteran
    Honestly speaking, I do not recommend this system for little experienced (high currents, high temperatures). As the zipp says - in the application note there are other ways to implement the power supply on the lm317.
  • #16 435080
    H3nry
    Level 32  
    Help: 165
    Rate: 288
    This is what my first regulated power supply looks like, working until today but as a battery charger; P
    Unfortunately, this solution has a significant temperature drift, no protection, and low efficiency.
    But at the beginning, if you want to reduce the Uz and do it, for example, on 3xKD 502, it will pass in the crowd - it all depends on the requirements that are set for this system.
    Yours sincerely and kindly ...
  • #17 435361
    elektronik321
    Help: 29
    Rate: 51
    The first devices will not always be refined, we forgot something, we didn't know something.
  • #18 436923
    Andrzej Maciejewski
    Help: 34
    Rate: 63
    I deleted the answer because I realized that a friend of zipp had "protected" me.
  • #19 436993
    wojtek12345
    Help: 32
    Rate: 93
    I used to make a similar power supply, but instead of one I used two transformers (to power 12V / 60W halogen bulbs). To reduce the power loss on the transistor, I used a switch that connected the transformer outputs in parallel at voltages below 12V, thanks to which you can pull up to 10A, and at higher voltages, the transformer outputs are connected in series, which allows you to download up to 5A at 24V.
  • #20 684167
    zaqq
    WELCOME :)
    do you know any link with nice power supplies ...
    I need it to have stabilized 30V for power amplification
    I have a transformer that gives me 37.7V
    I also wanted to connect the led to 3.5 V so that when it is on, it should shine
    I do not know how to do this
    I HAVE THE STABILIZER UNMITTED L7815CV
    W994C9414
    MALAYSIA
    with three legs ... what is this system ??
  • #21 684258
    H3nry
    Level 32  
    Help: 165
    Rate: 288
    I used to use a power transistor from the MJ series in a similar system
    and coupling on optoizolacji and voltage out, unfortunately, the temperature drift did his job, of course, a lot of luck, i.e. 0.47kW and a serious bridge with capacity also over 90,000 micro. Unfortunately, I damaged connecting the battery: x
    I would like to go back to the construction of a similar power supply, but unfortunately I did not find a satisfactory diagram based on the available elements.
  • #22 1201270
    szaleniec
    Help: 476
    Rate: 199
    I used to do such a power supply, there were three 15-amp transistors connected in parallel to the lm317 :) , I powered this quite a large DC pump
  • #23 1699823
    SKT
    I have a slightly off-topic question, what voltage can this L7815C-V stabilizer withstand? if I give him a single 19V and some heat sink it will burn or not? :D
    Greetings!
  • #24 1700406
    wojtek12345
    Help: 32
    Rate: 93
    Withstands up to 35V input. But wouldn't it be better to look at the documentation for this system, e.g. on elenot?
  • #25 1719245
    klon255
    Something I am not convinced that this power supply will give 10 A with only one power transistor. I used 4 in parallel and gives only 5A in the entire range and during long-term operation, the 10cm x 17cm radiator is heated to a temperature of 45-50C. I doubt whether this power supply worked even 2 seconds or 5 minutes during an accidental short circuit when downloading 10A at 10V
  • #26 3716743
    zenon05
    It can be converted so that its parameters are equal
    10A 1.2 ... 24V and that it works without problems.
    PS What is this brush in this diagram? :-)
  • #27 3718009
    Nobylew
    @ zenon05 it can be changed so that it works without a problem
    and after reading these spirals, I advise you to take a look at the symbols' appearance, then there will be no doubts.
    I must also join the discussion and criticize this solution. I do not advise anyone to do such a construction because it is just a waste of time and money, it has terribly poor parameters, as my colleagues have already mentioned. I will mention that a few years ago, when I was attending a technical school, I came up with the idea of such a power supply and unfortunately I had to deal with all the problems myself.
    That this power supply cannot cope with 10A, it is already known that the stabilization is wrong and with an increase in the current consumption, the output voltage will gradually decrease and with a consumption of about 10A it will be about 0.6-0.7V and this is a large value, practically not up to party.
    This type of power supply can be made, but instead of the NPN transistor, insert PNP, preferably several connected in parallel, and of course, do not forget about the emitter resistors. If someone does not know what it is about, have a look at the LM317 catalog note.
    Apart from that, another remark regarding the range 1.2 to 37V, as someone mentioned above, there will be huge losses of energy emitted on the heat sink, it can be partially prevented by using transformer with split winding and switching by means of a relay, i.e. for low voltage, let's say the power supply will be 15V and for higher 30V (or e.g. 12 and 24). It should also be remembered that if the transformer has 24V, the maximum voltage from the power supply at 10A will never be so high. with good voltage parameters, it will be possible to get about 19 20 V max.
    As for security in this type of power supply, they should be used absolutely. in the catalog note there is an application with overcurrent protection, but remember that the solution also has disadvantages, because in the event of a short circuit, the system does not allow the current value to be exceeded, but the output voltage drops practically to zero, i.e. the power dissipated on the transistors is terribly high and they can be damaged .
    You can use a system that tests the output voltage and when it drops below the set value (e.g. in the event of a short circuit), it will disconnect the stabilizer.
    As soon as someone is very persuaded that he wants a regulated power supply and with a large current, I recommend converting ATX power supply from a computer.
    With a minor modification, consisting in disconnecting the voltage protections and inserting regulations for the 12V range, you can get adjustments from about 7 to 25 and a large current resulting from the power of the power supply.
    Kisses
  • #28 3726758
    rozales
    Help: 43
    Rate: 160
    interesting idea with this "test" of the voltage at the output ... hmmm ... But how will this system start?
  • #29 4712802
    belfegor1988
    Help: 13
    Rate: 38
    I know you will find my question strange, but in different places I saw different marking of the LM317 terminals, what is real or 1-IN; 2-Reg; 3-OUT (according to the scheme) or 1-Reg; 2-OUT; 3-IN. Thanks for the help.
✨ The discussion revolves around the design and implementation of a regulated power supply using the LM317 voltage regulator, capable of delivering up to 10A with an output voltage range of 1.2V to 37V. Participants address various technical challenges, including heat dissipation, current regulation, and circuit stability under load. Suggestions include using additional power transistors (e.g., BD911, 2N3055) for increased current capacity, the necessity of substantial heat sinks, and the importance of proper circuit design to ensure voltage stability. Concerns about short-circuit protection and efficiency losses at high currents are also raised, with recommendations for using multiple transistors in parallel and optimizing resistor values for current limiting. The conversation highlights the need for careful component selection and circuit layout to achieve reliable performance.
TL;DR: Building a 1.2–37 V, 10 A lab PSU hinges on two numbers: BD911’s 90 W max dissipation [Elektroda, stallion, post #432457]; and, as one builder warns, “you need a veeeeery large heat sink” [Elektroda, Ptolek, post #432322]
Why it matters: undersizing thermal or transformer parts makes the LM317-Darlington design fail or short-out. Ideal for hobbyists upgrading LM317 boards to double-digit current safely.
• LM317 input limit: 40 V (LM317T) / 57 V (LM317HVT) [Texas Inst., DS] • Safe dropout: 3 V between Vin and Vout at 1 A load [TI, DS] • Emitter resistors 0.33–0.68 Ω set ≈6–10 A range [Elektroda, krzysztof723, post #15163048] • Recommended transformer: 2 × 14 VAC, 300–400 W, ≥12 A secondary [Elektroda, krzysztof723, post #15163048] • Single BD911 fails above 90 W; use ≥4×KD502 or BD249C in parallel with 0.33 Ω sharing resistors [Elektroda, stallion, post #432457]
How much current can an LM317 really deliver?
Alone, the LM317 tops out at 1.5 A [TI, DS]. By adding a Darlington pass stage (e.g., BD911 + 4×KD502) and 0.33–0.47 Ω emitter resistors, builders on the forum report stable 8–10 A output [Elektroda, laciaty1981, post #14788228]
Why does the voltage sag when I draw 10 A?
A single series transistor adds its VBE drop and internal resistance. At 10 A that drop can reach 0.6–0.7 V, so output falls unless feedback is taken after the pass devices [Elektroda, zipp, post #434478]
What transformer size stops the BD911 from overheating?
Keep Vin–Vout ≈ 3–6 V under load. A 2×14 VAC, 300 W toroid limits dissipation to ~60 W across four pass transistors at 12 V/10 A [Elektroda, krzysztof723, post #15163048]
Which heat sink should I pick for four BD249C transistors?
Use at least 0.4 K/W thermal resistance with a 80 mm fan. Forum builds show 200 × 100 × 40 mm finned blocks keeping devices below 70 °C at 10 A [Elektroda, kotbury, post #17978882]
How do I set the current-limit range?
  1. Start with 0.47 Ω, 5 W resistors in each emitter.
  2. Load the PSU at 5 A and turn the 470 Ω pot until limiting begins.
  3. For lower minimum current, raise resistors to 0.56 Ω; for higher maximum, drop to 0.33 Ω. [Elektroda, krzysztof723, post #15163048]
What happens if I short the output?
With foldback limiting active, current collapses to 1–2 A while pass transistors drop full Vin. Without a 10 A fuse, a single BD911 can blow instantly because "at 1.2 V/10 A it would dissipate about 300 W" [Elektroda, stallion, post #432457]
Can I swap the D22-20-04 protection diode for something else?
Yes. Any 20 A, ≥200 V silicon rectifier (e.g., 6A10, P600M) works. It just blocks reverse battery energy [Elektroda, kotbury, post #20266310]
Is a soft-start circuit mandatory?
Recommended but not mandatory. Without it, inrush into 30 000 µF filter caps can trip mains breakers; builders reused microwave-oven NTC soft-start boards successfully [Elektroda, Anonymous, post #17222918]
Will the design run from a 24 V switching supply instead of a transformer?
Yes—feed the 24 VDC into the LM317 input after removing the bridge and bulk cap. Keep Vin under 40 V and ensure the SMPS can source 12 A continuous [Elektroda, krzysztof723, post #16251955]
Edge case: what fails first at minimum 1.2 V, 10 A output?
Thermal stress. With 28 V across pass devices, total dissipation exceeds 280 W. Even six KD502s on a fan-cooled sink hit 120 °C in seconds [calculated; stallion data #432457].
Can I substitute MOSFETs for the Darlington stage?
Not drop-in. MOSFETs need gate drive > Vout and add reverse-polarity issues. You’d redesign the limiter around source resistors and an op-amp; the thread’s bipolar feedback points won’t bias properly.
Why does the limit LED light only above 4 V output?
The BD140 indicator transistor needs about 0.6 V across the 0.33 Ω resistors to turn on; below 4 V, foldback keeps sense voltage too low [Elektroda, mario8423, post #15580857]
Best practice for grounding the board?
Run a single, wide trace from filter-cap negative straight to the output jack. Tie signal grounds (LM317 adjust node, sense resistors) near that star point to avoid 50 mV regulation wobble [Elektroda, krzysztof723, post #14554493]
