Interrupting a While Loop Playing a Song on Boot Alarm When Disarm Signal is Sent
249 12
How can I stop a long while() loop that plays a song on boot alarm immediately when a disarm signal arrives?
Not with the song played as one long while() block; you need to either check the alarm status at regular intervals inside siren() or restructure playback so it can stop between notes. One option is the simpler approach of inserting status checks throughout siren(), although that is less elegant [#21660555] A better structure is to have a timer interrupt advance the song one note at a time, and on each tick check whether the status changed so the song can abort immediately [#21660555] Another possibility is to make siren() return a value and then use that return to break out of the surrounding loops, which can get you out of multiple levels of whiles [#21660552] The thread also suggests modeling the song as arrays of pitches and durations and iterating note-by-note, which fits the timer-driven approach [#21660559]
  • Interrupt-driven song loop exit on disarm signal
    #1 21660547
    Joshua Bishop
  • Interrupts may require a major code rewrite
    #3 21660549
    Joshua Bishop
  • #4 21660550
    Eduardo Viramontes
  • Polling status in a blocking while loop prevents interrupt response
    #5 21660551
    Joshua Bishop
  • Use siren() return value to break nested while loops
    #6 21660552
    Bob Loy
  • #7 21660553
    Bob Loy
  • #8 21660554
    Bob Loy
  • Use timer interrupt to play song and check status
    #9 21660555
    Pieter Kruger
  • Returning from siren() still leaves loop exit unresolved
    #10 21660556
    Joshua Bishop
  • #11 21660557
    Joshua Bishop
  • #12 21660558
    Ty Wangsness
  • Use a play_song flag to break the loop
    #13 21660559
    Bob Loy
The discussion addresses the challenge of interrupting a long-running while loop that plays a song as part of a boot alarm system when a disarm signal is received. The original alarm used short repeating cycles with status checks after each cycle, allowing prompt disarm detection. Transitioning to a song playback extended the cycle duration, delaying response to disarm signals. Proposed solutions include inserting multiple for() loops within the song playback to periodically check the disarm status, though this is considered inelegant. Suggestions involve using break statements to exit loops, but these only work at predefined check points. Software interrupts were considered but currently only update status flags without immediate loop interruption. A more robust approach discussed is restructuring the program to use timer interrupts to play individual notes, allowing status checks between notes and immediate song abortion upon disarm. Returning status values from the siren() function to control loop exits was also proposed. Ultimately, the first approach of periodic status checks within the song was implemented for the current project, while the timer interrupt method remains a promising solution for future development. Code formatting tips for forum posts were also shared.
TL;DR: To stop a boot-alarm song instantly, drive playback from a timer interrupt that advances one note at a time in a 30-note array; "abort the song immediately" when the disarm flag flips. [Elektroda, Pieter Kruger, post #21660555]
Why it matters: You’ll cut mid-song latency from an entire loop to a single note interval, improving safety and UX for DIY alarm builds.
How do I stop a song-playing while loop the moment a disarm signal arrives?
Move playback into a timer interrupt. On each tick, play the next note, read the disarm flag, and exit immediately on change. This limits latency to one note interval and avoids waiting for the full loop. As one expert put it, “abort the song immediately.” [Elektroda, Pieter Kruger, post #21660555]
Will a simple break statement solve nested loops in my alarm code?
No. break exits only the innermost loop. To leave multiple loops, make siren() return a status code, test it after the loop, and then break or return again to unwind higher levels. This pattern reliably propagates the stop condition. [Elektroda, Bob Loy, post #21660552]
How can siren() return a value to unwind multiple loops safely?
Have siren() return a code such as DISARMED. In the caller, check the return and break out of the enclosing while. Then test again at the next level, exiting the main loop if needed. This staged exit avoids hanging inside nested structures. [Elektroda, Bob Loy, post #21660552]
Can software interrupts help if my loop is busy?
Yes. A software interrupt can set a global status flag. Your main state machine branches when it next checks the flag. However, if siren() runs long without polling, response still delays until the next check. [Elektroda, Joshua Bishop, post #21660551]
What’s a simple interrupt-driven design to play notes and stop instantly?
  1. Store the song as pitch[] and duration[] indices.
  2. Configure a timer to tick at your smallest note unit.
  3. On each ISR tick, advance timing, output the note, check disarm, and exit if set. This yields near-instant stops mid-song. [Elektroda, Pieter Kruger, post #21660555]
How often should I poll the status if I keep a loop-based song?
Poll at short, regular intervals inside siren(). Insert quick checks between note steps or partial delays. This reduces overrun after disarm without a full rewrite, though it remains less elegant than interrupts. The author used scattered for() checks for this. [Elektroda, Joshua Bishop, post #21660549]
What edge cases can still block an immediate stop?
If you only check the flag at the end of siren(), the system won’t stop mid-note. Long operations between polls will delay exit. Restructure loops or use timer-driven steps to avoid full-function waits before noticing disarm. [Elektroda, Joshua Bishop, post #21660556]
How do I store a song cleanly for microcontroller playback?
Use arrays for notes and durations, for example pitch[30] and duration[30]. Iterate with an index, not long blocking loops. This makes ISR-based stepping easy and keeps code readable and maintainable. [Elektroda, Bob Loy, post #21660559]
Why does my for-loop polling approach feel “inelegant,” and is it acceptable?
It spreads status checks across the song, which works but mixes control and timing logic. It’s acceptable for quick results, but interrupts or return-code unwinding are cleaner long-term designs. “It seems…inelegant,” noted the author. [Elektroda, Joshua Bishop, post #21660549]
How do I exit both the siren loop and the main loop after disarm?
Return a DISARMED code from siren(), check it immediately in the caller to break that loop, then test once more to break the main while(1). This two-stage check exits cleanly from nested loops. [Elektroda, Bob Loy, post #21660552]
What’s a minimal change if I’m done with this build but want faster stops?
Keep your current design and add tighter-granularity polls inside siren(). Check the status between short delay slices or note segments to cut post-disarm overrun without major refactoring. [Elektroda, Joshua Bishop, post #21660557]
How do I format code blocks correctly in this forum thread?
Use the right-most toolbar button above the editor that looks like a document with code symbols. It inserts language-highlighted code blocks for clearer sharing. [Elektroda, Ty Wangsness, post #21660558]
