SMPS circuit for 230V AC to 221V DC 20mA output, 1% ripple, DCM, N-channel MOSFET
324 13
How can I design a SMPS to convert 230 VAC to 221 V DC at 20 mA with 1% output ripple using a high-side N-channel MOSFET in DCM?
Use a two-stage supply: rectify the 230 VAC to an intermediate DC bus (about 325 V peak after the bridge and smoothing), then regulate that bus down to 221 V with a buck stage [#21660810][#21660816] Several replies note that 20 mA at only a 5 V drop is about 0.1 W, so an SMPS may be overkill and a simple linear regulator might even be sufficient if efficiency is not critical [#21660811] The main practical problem raised is how to power the controller/Vcc from such a high-voltage output without an external supply, which is why an isolated topology or another Vcc arrangement was suggested [#21660812][#21660815] One reply also questioned why the design specifically requires an N-channel high-side MOSFET [#21660819]
  • #1 21660807
    Charith Mendis
  • #2 21660808
    Charith Mendis
  • #3 21660809
    Todd Hayden
  • #4 21660810
    Cody Miller
  • #5 21660811
    Steve Lawson
  • #6 21660812
    Charith Mendis
  • #7 21660813
    Charith Mendis
  • #8 21660814
    Charith Mendis
  • #9 21660815
    Charith Mendis
  • #10 21660816
    Charith Mendis
  • #11 21660817
    Steve Lawson
  • #12 21660818
    Charith Mendis
  • #13 21660819
    Todd Hayden
  • #14 21660820
    Charith Mendis
The discussion centers on designing a switched-mode power supply (SMPS) converting 230V AC at 50 Hz to 221V DC output at 20mA with a 1% output voltage ripple, using an N-channel high-side MOSFET operating in discontinuous conduction mode (DCM). The design challenge is compounded by the requirement to use a buck converter topology, which is unusual given the output voltage is close to the input peak voltage (~325V DC after rectification). The designer is constrained by a non-isolated topology and cannot use external power for the controller Vcc, complicating the choice of MOSFET drivers and controller ICs. Simulation in PSPICE has been done for the buck converter stage, but selecting suitable driver ICs with available PSPICE models remains problematic. The project is a favor rather than commercial work, with a limited budget and strict adherence to specifications despite the low load current (20mA) and minimal voltage drop, which some suggest might make SMPS overkill compared to linear regulation. The output ripple specification is confirmed at 1% of 221V. Suggestions include splitting the design into two stages: AC to intermediate DC voltage (around 325V) and then to the regulated output. The rationale for mandating an N-channel high-side switch is unclear.
TL;DR: Design uses 230 VAC → buck to 221 VDC with 1% ripple; “output ripple = 1% of the output voltage.” [Elektroda, Charith Mendis, post #21660807]
Why it matters: Engineers searching “how do I build a tiny high‑voltage buck from mains” get constraints, pitfalls, and thread‑verified context fast.
What’s the simplest high-level architecture for 230 VAC to 221 VDC at 20 mA?
Use a rectifier and bulk capacitor to create a high-voltage DC bus, then a non‑isolated buck stage in DCM to 221 V. This mirrors the thread’s requested buck approach and maintains low output current with manageable magnetics. Keep clearances consistent with high voltage practices. [Elektroda, Charith Mendis, post #21660808]
Why not just use a linear regulator here?
A participant suggested SMPS might be overkill, but constraints include high output voltage and controller power challenges. Linear drop from a rectified bus would waste heat and still not solve auxiliary Vcc. “We’re talking a mere 5th of a watt, here!” reflects skepticism, not a final design choice. [Elektroda, Steve Lawson, post #21660811]
How do I meet the 1% ripple requirement at 221 V?
Target about 2.21 Vpp ripple. In DCM buck, size the output capacitor and switching frequency to keep the inductor current fully discontinuous while meeting ripple. Validate with simulation and measure at load. “Output ripple = 1% of the output voltage.” [Elektroda, Charith Mendis, post #21660818]
Is isolation allowed for this supply?
No. The requester explicitly disallowed an isolated topology. That restriction drives the choice toward a non‑isolated rectified bus plus buck stage and complicates safe referencing and measurements during development. [Elektroda, Charith Mendis, post #21660814]
What intermediate DC voltage should I expect after rectifying 230 VAC?
Expect about 325 VDC from a smoothed bridge (230 VAC RMS × √2). The OP confirmed using this intermediate node before the buck stage. Ensure components are rated for this bus. [Elektroda, Charith Mendis, post #21660816]
Can I power the controller Vcc from the high output if no external supply is allowed?
The OP notes Vcc generation is difficult due to the high output voltage and the no‑external‑supply rule. Plan startup and housekeeping power early, since this constraint impacts driver selection and reliability. [Elektroda, Charith Mendis, post #21660812]
Why mandate an N‑channel high‑side MOSFET in DCM—what’s the impact?
Mandating an N‑channel high‑side device in DCM narrows driver choices and startup strategies. The OP flagged the requirement, which increases design effort for a small‑power supply. Choose parts and topology with this constraint in mind. [Elektroda, Charith Mendis, post #21660807]
What MOSFET driver and controller ICs were recommended in the thread?
The designer asked for specific MOSFET drivers, controller ICs, and PSpice models but none were named in‑thread. The open request highlights parts selection and simulation models as a blocker. [Elektroda, Charith Mendis, post #21660815]
Is using off‑the‑shelf AC‑DC modules acceptable here?
One reply proposed splitting the job into two parts and considering AC‑to‑DC modules. That can reduce risk and speed development if specifications and budget allow. [Elektroda, Cody Miller, post #21660810]
What do other engineers think about using a buck here?
One respondent asked why a buck would be harder, since bucks normally step down. This underscores that perceived difficulty stems from the high voltage, Vcc generation, and high‑side drive—not the step‑down action itself. [Elektroda, Todd Hayden, post #21660809]
How tightly regulated must the output be?
The thread clarifies the requirement as 1% ripple at the output voltage level. Treat this as a hard target during simulations and component selection. [Elektroda, Charith Mendis, post #21660818]
What special constraints did the requester impose beyond specs?
The designer couldn’t use an external power source for controller Vcc, and isolation was disallowed. These constraints directly affect driver choice and startup circuitry. [Elektroda, Charith Mendis, post #21660812]
Who asked for the N‑channel high‑side switch, and why?
A participant questioned the mandate’s purpose. The designer said it was a favor for a faculty member, acknowledging the requirement may be arbitrary. [Elektroda, Todd Hayden, post #21660819]
Did the OP simulate the buck stage successfully?
Yes. The OP reports a working buck design in PSpice, though hardware driver/controller selection remained unresolved. Use simulation to verify ripple and DCM boundaries before prototyping. [Elektroda, Charith Mendis, post #21660813]
Quick 3‑step plan to de‑risk this design?
  1. Rectify 230 VAC to a smoothed HV DC bus and verify ≈325 V.
  2. Implement DCM buck to 221 V with mandated N‑channel high‑side switch.
  3. Validate 1% ripple and address Vcc without external supply. [Elektroda, Charith Mendis, post #21660816]
What’s an edge case to watch out for during bring‑up?
With no external Vcc and a high‑side N‑MOSFET, startup and driver biasing can stall progress. The OP explicitly struggled with driver and controller selection; plan this path early. [Elektroda, Charith Mendis, post #21660813]
