Designing Adjustable 0-30V 100A CV/CC Power Supply Using 3kVA 35V Transformer
228 14
  • #1 21660647
    Sarah Harris
  • #2 21660648
    Andy Taylor
  • #3 21660649
    Sarah Harris
  • #4 21660650
    Andy Taylor
  • #5 21660651
    Sarah Harris
  • #6 21660652
    Andy Taylor
  • #7 21660653
    Sarah Harris
  • #8 21660654
    DAVID CUTHBERT
  • #9 21660655
    Sarah Harris
  • #10 21660656
    DAVID CUTHBERT
  • #11 21660657
    Sarah Harris
  • #12 21660658
    DAVID CUTHBERT
  • #13 21660659
    DAVID CUTHBERT
  • #14 21660660
    Sarah Harris
  • #15 21660661
    Sarah Harris
✨ The discussion focuses on designing a 0-30V, 100A adjustable constant voltage (CV) and constant current (CC) power supply using a 3kVA 35V transformer for electroplating applications. The user seeks a simple, reliable design due to frequent failures of commercial switched-mode power supplies (SMPS). Linear power supplies are deemed impractical due to excessive heat dissipation at high currents, making a switched-mode power supply with PWM control the preferred solution. The transformer provides mains isolation and a 50V rail after rectification, suitable for a buck regulator topology operating primarily in the 12-21V range with up to 70-80A output current. CC control is critical for maintaining consistent current during anodic plating processes, where voltage must adjust to compensate for insulating oxide layers. Ripple and current fluctuations should be minimized, though some AC ripple may benefit plating quality. The design should implement current sensing on the low-voltage secondary side to reduce EMI and improve control stability. Suggested components include PWM controllers from Linear Technology, Texas Instruments, and Analog Devices, with power MOSFETs for switching. SCR-based power supplies with ripple filtering (inductor and capacitor) are referenced as commercial examples. The user is advised to avoid primary-side dimmer controls due to EMI and control difficulties. The importance of closed-loop feedback for CC regulation and the challenges of scaling low-power linear circuits to high current are emphasized. The user is encouraged to use an oscilloscope for tuning and validation. Overall, a PWM buck converter with current sensing and filtering on the secondary side is recommended for a robust, efficient, and adjustable CV/CC power supply suitable for electroplating.
TL;DR: From a 3 kVA/35 V transformer you can realistically get ≈1.6 kW DC; “Use a buck regulator in constant current mode.” [Elektroda, DAVID CUTHBERT, post #21660654] Why it matters: This FAQ helps hobbyists design a safe, adjustable CV/CC plating supply without wasting money on short‑lived units.
Can I build a 0–30 V, 100 A linear supply from a 35 V/3 kVA transformer?
No. A linear pass design would dissipate kilowatts as heat and be inefficient and unsafe. “A linear solution will become more of a heater than a regulator.” Use a switched‑mode approach instead. Regulate on the isolated secondary to simplify CC control and reduce EMI. [Elektroda, Andy Taylor, post #21660652]
How much real power can I get from a 3 kVA, 35 V transformer after rectification?
Expect about 1.6 kW usable DC. Bridge rectifiers create high charging pulses that heat the windings, so practical output is roughly half the nameplate kVA, then apply efficiency. Design your CC stage around that limit to avoid overload. [Elektroda, DAVID CUTHBERT, post #21660654]
Should I regulate on the primary side with a triac or dimmer?
Avoid primary‑side phase control for this application. It increases EMI and complicates constant‑current control. Instead, perform PWM or buck regulation on the low‑voltage secondary after isolation. This improves stability and safety for plating loads. [Elektroda, Andy Taylor, post #21660652]
What topology is best for adjustable constant current here?
Use a buck regulator on the rectified secondary and run it in constant‑current mode. Rectify to about a 50 V rail, then step down while regulating current. This matches the plating need for rising voltage to sustain set current. [Elektroda, DAVID CUTHBERT, post #21660654]
Do plating and anodizing require true constant current or just a current limit?
For anodizing, resistance rises as the oxide grows, so voltage must increase to hold current steady. That requires true constant‑current regulation, not only a limiter. CC keeps deposition uniform on small jewelry parts. [Elektroda, Sarah Harris, post #21660657]
Can I use low‑duty, high‑current pulses instead of filtered DC?
Prefer filtered DC for plating. Commercial SCR plating supplies advertise about 8% ripple, indicating pulsed high‑current DC is not the norm. Add an L‑C output filter and tune the loop to avoid oscillation with varying loads. [Elektroda, DAVID CUTHBERT, post #21660659]
Which controller IC families are suitable for the SMPS stage?
Look for PWM controllers from Linear Technology (Analog Devices), Texas Instruments, or Analog Devices catalogs. Pair with suitable MOSFETs on the secondary, add input/output filtering, and implement current sensing with proper isolation. [Elektroda, Andy Taylor, post #21660648]
How should I sense current and handle loop stability for CC?
Use a shunt on the secondary with an amplifier to feed the PWM controller. Add modest hysteresis or compensation to prevent rapid PWM changes that heat devices and stress components. Filter design is critical for long life. [Elektroda, Andy Taylor, post #21660648]
What about output impedance and combining CV and CC?
A buck is inherently low impedance (good CV). To act as a current source, the control loop raises gain, which can cause instability if mishandled. Keep requirements clear and test stability under different bath loads. [Elektroda, DAVID CUTHBERT, post #21660656]
Is an oscilloscope necessary to finish and tune this supply?
Yes. You need a scope to verify ripple, observe SCR/PWM waveforms, and check for oscillation after the L‑C filter. Closed‑loop tuning without a scope risks unstable operation and poor plating results. [Elektroda, DAVID CUTHBERT, post #21660659]
Can I meet 70–80 A in the 8–21 V range for small jewelry parts?
Within a ≈1.6 kW budget, 70–80 A at 8–21 V is realistic for the stated use. Ensure thermal design, inductor saturation current, and rectifier ratings support your current window during long plating sessions. [Elektroda, Sarah Harris, post #21660655]
Will an SCR rectifier on the secondary work if I add filtering?
Yes, but include an inductor and capacitor after the rectifier to cut ripple near the ≈8% seen in commercial units. Close the loop carefully so the supply does not oscillate as bath resistance changes. [Elektroda, DAVID CUTHBERT, post #21660659]
How do I prototype the constant‑current buck quickly?
  1. Bridge‑rectify the 35 V secondary to create a ≈50 V DC rail.
  2. Build a buck stage with a current shunt and comparator/AMP to drive PWM.
  3. Tune compensation under several loads, watching thermal limits and ripple. [Elektroda, DAVID CUTHBERT, post #21660654]
Any safety or compliance considerations before I power up?
Switch‑mode supplies can emit broadband EMI. Provide isolation and proper filtering. If you later commercialize, factor in safety directives and emissions testing. For a hobby unit, still prioritize user and public safety. [Elektroda, Andy Taylor, post #21660648]
