SPDT 8-Position Toggle Switch with 3 Pins per Switch, Under 2 Inches—Where to Buy?
327 26
Where can I buy a compact 8-position switch that lets each input select either logic high or logic low instead of leaving the line open?
You’re looking for a toggle-style SPDT DIP switch; those do exist, and one source found in the thread is RS Electronics plus a Digi-Key part (KAT1108E / EG4555-ND) [#21660934] They were described as the closest match to your request for multiple separate high/low switches in one body, with the note that DIP switches get their name from the dual-in-line footprint [#21660930] If your inputs are going to a microcontroller, you may not need SPDT at all: a simple SPST switch can work with pull-up or pull-down resistors so the input is never left floating [#21660940] The thread also notes that the microcontroller may already have internal pull-ups, which can eliminate external resistors if enabled correctly [#21660944][#21660947]
  • Need for 8-position SPDT toggle with 24 pins
    #1 21660924
    Steffan Long
  • Suggesting 8P4T rotary switch or relay workaround
    #2 21660925
    Steve Lawson
  • Need eight true binary inputs switched between 5 V and ground
    #3 21660926
    Steffan Long
  • #4 21660927
    Steve Lawson
  • #5 21660928
    Steffan Long
  • #6 21660929
    Steffan Long
  • Rocker switch and 8-gang panel alternatives
    #7 21660930
    Steve Lawson
  • #8 21660931
    Steffan Long
  • #9 21660932
    Steve Lawson
  • #10 21660933
    Steffan Long
  • #12 21660935
    Steffan Long
  • #13 21660936
    Steve Lawson
  • #14 21660937
    Steve Lawson
  • #15 21660938
    Steve Lawson
  • #16 21660939
    Steffan Long
  • Input family determines pull-up resistor value
    #17 21660940
    Steve Lawson
  • #18 21660941
    Steffan Long
  • Choosing pull-up value from leakage and battery life
    #19 21660942
    Steve Lawson
  • #20 21660943
    Steffan Long
  • #21 21660944
    Steve Lawson
  • #22 21660945
    Steve Lawson
  • Using internal pull-ups with input pins
    #23 21660946
    Steffan Long
  • #24 21660947
    Steve Lawson
  • #25 21660948
    Rathina Vel
  • Enable weak pull-ups via OPTION_REG on PICs
    #26 21660949
    Mark Harrington
  • #27 21660950
    Mark Harrington
The discussion centers on finding an 8-position SPDT toggle switch with three pins per switch, ideally under two inches in length, capable of switching each input line between logic high (+5 V) and logic low (ground) without leaving inputs floating. The original request was clarified to needing eight separate SPDT switches integrated into one body, similar to DIP switches but with toggle or rocker actuators rather than push-button types. Standard DIP switches are typically SPST and do not switch between two logic states directly, which led to exploring alternatives. Suggested solutions include using multiple 4-position SPDT switches or rocker-type DIP switches that provide on-on functionality. The use of pull-up or pull-down resistors with SPST switches was discussed as a cost-effective alternative, with explanations on how resistor values affect noise immunity and power consumption, especially for microcontroller inputs. The Atmel microcontroller internal pull-up resistors were also mentioned as a convenient feature to eliminate external resistors. Sources for toggle SPDT DIP switches were identified, including Digi-Key and RS Electronics, with specific part references such as KAT1108E. The discussion also touched on the impracticality and high cost of 8-pole rotary switches and the possibility of using relay or transistor circuits driven by simpler switches. An Indian supplier offered an 8-pole 2-way front panel mounting switch with external power supply for logic levels. Overall, the consensus was that toggle SPDT DIP switches exist but are less common and more expensive than standard DIP switches, and that using pull-up/down resistor circuits with SPST switches or multiple smaller switches is a practical approach for microcontroller input testing and prototyping.
TL;DR: Need an 8-line SPDT in one package? Options include SPDT DIP switches and rotary alternatives; “Sounds like you want ‘double throw’.” Also, Digi‑Key showed 82 4PDT parts in stock. [Elektroda, Steve Lawson, post #21660925]
Why it matters: This FAQ helps makers choose, wire, and source compact multi-line logic switches for microcontroller projects.
What did the OP actually need: one switch with 8 positions, or 8 SPDT switches in one body?
They needed eight independent SPDT switches housed together, not an 8‑position selector. Each line must switch between logic 0 and logic 1, not open. [Elektroda, Steffan Long, post #21660928]
Do SPDT DIP switches exist, and where can I buy them?
Yes. SPDT DIP switches with individual toggles exist and were identified via RS/Digi‑Key links in the thread. These pack multiple on‑on poles in a DIP footprint for breadboards and protoboard. “By golly, there IS such a thing.” [Elektroda, Steve Lawson, post #21660934]
What is a DIP switch?
A DIP switch is a multi‑pole switch in a Dual‑In‑Line footprint, like a DIP IC. It’s designed for easy PCB or breadboard use and often presents small rockers or toggles per circuit. [Elektroda, Steve Lawson, post #21660930]
Why not use SPST DIP switches with pull‑ups or pull‑downs?
You can. Add a resistor so an open state becomes a defined logic level. Then a simple SPST can assert the opposite level. This approach saves cost and parts hunting. [Elektroda, Steve Lawson, post #21660932]
How do pull‑up and pull‑down configurations read when the switch is open?
With a pull‑up, open reads HIGH; with a pull‑down, open reads LOW. Closing the switch forces the opposite rail. The OP confirmed this behavior in testing. [Elektroda, Steffan Long, post #21660939]
What resistor values should I start with for microcontroller inputs?
For CMOS‑like microcontroller inputs, start near 10 kΩ when not battery‑powered. On battery, use the highest value that still meets VIH/VIL, but note noise immunity decreases as resistance rises. [Elektroda, Steve Lawson, post #21660942]
What if my inputs are TTL‑like instead of CMOS?
Favor pull‑up networks for TTL‑style inputs. Values like 1 kΩ provide strong drive but waste power; check the family’s VIH/VIL and leakage specs, then size the resistor. [Elektroda, Steve Lawson, post #21660940]
Is there a ready-made 8‑pole, 2‑throw rotary alternative?
Yes, but it can be pricey. One two‑position 8‑gang rotary located at Mouser was over $200, which pushed the discussion toward DIP switch solutions. [Elektroda, Steve Lawson, post #21660925]
What statistic defines the OP’s multi‑line requirement?
They needed eight SPDT lines, three pins per switch, totaling 24 pins, to drive eight binary inputs positively to either +5 V or GND. [Elektroda, Steffan Long, post #21660924]
Can I enable internal pull‑up resistors instead of using externals?
Yes. The AVR in question includes internal input pull‑ups. “You don’t need no stinkin’ external pull‑up resistors!” You must enable them in software/registers. [Elektroda, Steve Lawson, post #21660944]
How do I turn on pull‑ups using Arduino‑style code?
Set the pin as INPUT, then write it HIGH to enable the pull‑up. Example: pinMode(pin, INPUT); digitalWrite(pin, HIGH); The OP reported this approach context. [Elektroda, Steffan Long, post #21660946]
Any quick three-step wiring plan for SPST plus pull‑down?
  1. Connect one side of SPST to +5 V. 2. Tie input to the other side; add a resistor from input to GND. 3. Verify input reads LOW open, HIGH when closed. [Elektroda, Steve Lawson, post #21660936]
What’s an edge case to watch with large-value resistors?
Very large pull‑ups or pull‑downs reduce noise immunity. Inputs may float near thresholds in noisy environments; choose the highest value that still meets VIH/VIL. [Elektroda, Steve Lawson, post #21660942]
Does this work well with battery-powered builds?
Yes, but power budgets matter. Eight inputs multiply leakage and divider currents by eight. Size resistors to balance battery life and reliable logic thresholds. [Elektroda, Steve Lawson, post #21660942]
What if I still want tactile toggle levers, not rockers?
SPDT DIP with miniature toggles exists, but availability varies by distributor search filters. The thread links show specific families to start from. [Elektroda, Steve Lawson, post #21660934]
Can a single SPDT drive multiple lines through relays or transistors?
Yes. Use one SPDT to control driver stages or relays that route multiple signals. This trades mechanical complexity for electronics. [Elektroda, Steve Lawson, post #21660925]
