Replacing 1N4001 Diode With Capacitor to Prevent Reverse Flow and Boost Voltage?
360 20
Can I replace a reverse-protection diode after an LM7809 with an electrolytic capacitor to eliminate the voltage drop and still block reverse current?
No, a capacitor cannot replace that diode: it will not boost the voltage, and if you do not need reverse-current protection you should remove the diode instead [#21661849][#21661856] If you still want a diode in the path, use a Schottky diode to reduce the forward voltage drop [#21661856] The 8.91 V reading is also within the LM7809’s normal output tolerance, since its typical output is 9 V but the minimum can be 8.64 V [#21661849] If reverse voltage is not expected at that node, the diode is unnecessary; if it is expected, keep proper protection rather than trying to “fix” the drop with a capacitor [#21661863] Another reply suggested that if compensation is really needed, a diode from the LM7809 ground pin to the real ground can raise the output slightly, but the main point remained that the capacitor will not do the job [#21661866]
  • Capacitor cannot replace reverse-blocking diode
    #1 21661848
    Danalog Barkman
  • 7809 output tolerance explains 8.91 V reading
    #2 21661849
    Boi Okken
  • Suggesting capacitors and LM7809A for stability
    #3 21661850
    Mike P OKeeffe
  • #4 21661851
    Mark Harrington
  • #5 21661852
    Danalog Barkman
  • #6 21661853
    Danalog Barkman
  • #7 21661854
    Danalog Barkman
  • #8 21661855
    Danalog Barkman
  • #9 21661856
    Boi Okken
  • #10 21661857
    Boi Okken
  • #11 21661858
    Danalog Barkman
  • #12 21661859
    Danalog Barkman
  • #13 21661860
    Danalog Barkman
  • #14 21661861
    Danalog Barkman
  • Check input voltage, load current, and regulator headroom
    #15 21661862
    Mark Harrington
  • #16 21661863
    Boi Okken
  • LED resistor corrected to 2.74 kΩ for 2 mA
    #17 21661864
    Danalog Barkman
  • Measure LM7809 load current and total 9 V rail draw
    #18 21661865
    Mark Harrington
  • Questioning whether compensation is needed at all
    #19 21661866
    Per Zackrisson
  • Insufficient input current prevents proper regulation
    #20 21661867
    Mark Harrington
  • #21 21661868
    Danalog Barkman
The discussion addresses voltage drop issues in a power supply circuit using an LM7809 voltage regulator and two 1N4001 diodes. The first diode is intended to stabilize and regulate the 9V output, but the measured voltage is slightly below 9V (8.91V), and after the second diode, it drops further to 8.40V. The main question is whether the second diode, primarily used to prevent reverse current flow, can be replaced by an electrolytic capacitor to both block reverse flow and compensate for voltage drop. Responses clarify that capacitors cannot boost voltage or prevent reverse current like diodes do. The voltage drop across the LM7809 and diodes is typical and within datasheet tolerances. Suggestions include removing the second diode if reverse voltage protection is unnecessary, replacing it with a Schottky diode to reduce voltage drop, or adjusting the regulator circuit with a voltage divider for output voltage compensation. The importance of proper input voltage (12-15V minimum) and sufficient current supply (at least 100mA, preferably higher) to the LM7809 is emphasized to ensure stable regulation. The input filter design and load current considerations are also discussed. Ultimately, the diode's necessity depends on the specific circuit conditions, and the voltage drop cannot be compensated by a capacitor. The original poster confirms the circuit now works correctly after applying the advice.
TL;DR: "A voltage cannot be boosted with a capacitor"; the LM7809’s minimum output is 8.64 V, so 8.9 V is within spec—remove the extra diode or use a Schottky to cut drop. [Elektroda, Boi Okken, post #21661849]
Why it matters: This FAQ helps pedal/synth builders fix 9 V rail sag, reverse-flow protection, and noise without wasting headroom.
Can I replace a 1N4001 with a capacitor to block reverse flow and raise voltage?
No. Capacitors don’t boost steady DC, and they don’t provide one‑way conduction. Use a diode for reverse-flow protection. If that post‑regulator diode only wastes headroom, remove it or swap to a Schottky for lower drop. “A voltage cannot be boosted with a capacitor.” [Elektroda, Boi Okken, post #21661849]
Why is my LM7809 reading 8.91 V instead of 9 V?
Because it’s in tolerance. The LM7809 has a typical 9 V output, but the minimum can be 8.64 V. Your 8.91 V reading is normal and does not indicate a fault. Small load and temperature shifts can move the reading within spec. [Elektroda, Boi Okken, post #21661849]
Do I actually need a second series diode after the 7809?
Often no. That diode only makes sense if another source can back‑feed the regulator. If the regulator’s input can’t be driven above the output, remove the diode to avoid unnecessary drop. This frees roughly half a volt of headroom. [Elektroda, Boi Okken, post #21661863]
Will a Schottky diode help preserve more voltage than a 1N4001?
Yes. Schottky diodes have lower forward voltage than standard silicon diodes. Replacing a 1N4001 with a Schottky on the 9 V rail reduces drop and keeps the rail closer to the regulator output. This is the common fix when you still need reverse protection. [Elektroda, Boi Okken, post #21661856]
What input voltage headroom does the LM7809 require?
Budget about 3–4 V of dropout. With a 9 V target, aim for at least about 13.7 V at the regulator input under load to maintain regulation. Less input voltage increases sag and ripple on the 9 V rail. [Elektroda, Per Zackrisson, post #21661866]
Is a 12 V / 100 mA wall adapter enough for a 7809 pedal supply?
Usually not for peak or multi‑module loads. A contributor advised using ≈500 mA at 15 V or more so the 7809 can regulate reliably, especially at turn‑on surges. Undersized adapters cause low 9 V output and instability. [Elektroda, Mark Harrington, post #21661867]
How do I measure the load current my 7809 is feeding?
Three steps: 1) Desolder the 7809 output pin from the board pad. 2) Put your DMM on mA range and connect between the pin and the pad. 3) Power up and read the current to confirm your adapter and regulator margins. [Elektroda, Mark Harrington, post #21661865]
What does the TLE2426 “rail splitter” do, and what’s its limit?
It creates a low‑impedance virtual midpoint (virtual ground) from a single supply for audio op‑amps. In this build, plan around about 80 mA capability. Exceeding that can starve the 9 V rail and increase distortion or noise. [Elektroda, Mark Harrington, post #21661865]
Which capacitors should I place around the 7809 for stability?
Use a small ceramic on the output and one on the input close to the pins. A 0.1 µF on the output and a 0.33 µF on the input were suggested to keep the 12 V steady and the 9 V stable. [Elektroda, Mike P OKeeffe, post #21661850]
What’s the purpose of the input filter and D1 in pedal supplies?
The RC/RC+electrolytic filter reduces adapter hum and high‑frequency noise. D1 protects against reverse‑polarity plug‑ins. This is common in guitar pedals and synth modules that share adapters. It trades some headroom for robustness and quieter rails. [Elektroda, Danalog Barkman, post #21661864]
How can I reduce LED brightness and power‑on “pop” in pedals?
Run the LED at a lower current and add a small electrolytic with a series resistor. One builder used 2 mA, 10 µF, and 390 Ω to soften turn‑on and limit surge. This tames visual glare on dark stages and reduces popping. [Elektroda, Danalog Barkman, post #21661864]
Does adding a diode after the regulator protect the 7809?
Not usually in simple, single‑source builds. That diode mainly drops voltage and can be removed when there is no higher back‑feed risk. If protection is still desired, choose a low‑drop Schottky to minimize loss. [Elektroda, Boi Okken, post #21661856]
What if my adapter voltage dips below 9 V at the 7809 input?
Regulation fails and the output sags; audio circuits may distort or mute. This edge case appears when the adapter is under‑rated or the load peaks at power‑up. Increasing adapter voltage/current fixes the failure. [Elektroda, Mark Harrington, post #21661867]
Did these changes actually solve the builder’s problem?
Yes. After removing unnecessary drops and right‑sizing the supply, the original poster confirmed the circuit worked as intended. “It all works now!” [Elektroda, Danalog Barkman, post #21661868]
