Can a 470uF or 100uF Capacitor Cause a Short Circuit in 7805 Regulator Circuit?
222 9
Can a 470 µF or 100 µF capacitor in a 7805 regulator circuit go short and make the regulator overheat?
Yes, a capacitor can fail short, but in this case the actual short was a tiny solder bridge or similar conductive debris between PCB tracks, not the capacitors themselves [#21679609][#21679614] A 22 µF tantalum on a 7805 output was reported as a real shorted-capacitor failure, so the advice was to remove suspected caps and see whether the short disappears [#21679609] The 100 µF output capacitor was considered larger than necessary for a 7805; 10 µF was suggested as adequate, with a voltage rating at least double the 5 V rail, so 10 V would be fine [#21679609] It was also recommended to check the 7805 pinout, inspect for shorts between input and output pins, and measure low resistance with an ohmmeter before powering up again [#21679610] The original poster later confirmed that replacing the old electrolytics did not fix it, and scraping away the hidden bridge made the circuit work [#21679614]
  • Shorted capacitor suspected in 7805 supply circuit
    #1 21679608
    Rich Cox
  • Shorted output capacitor can kill 7805 regulator
    #2 21679609
    David Ashton
  • Check 7805 pinout and capacitor polarity
    #3 21679610
    Rick Curl
  • #4 21679611
    David Ashton
  • Old electrolytic capacitors suspected in 7805 short issue
    #5 21679612
    Rich Cox
  • Test reclaimed capacitors before reuse
    #6 21679613
    David Ashton
  • Solder bridge between tracks caused the short
    #7 21679614
    Rich Cox
  • Recommend magnifier or USB microscope for solder bridges
    #8 21679615
    David Ashton
  • #9 21679616
    Rich Cox
  • #10 21679617
    David Ashton
A 7805 voltage regulator circuit powered by a 6-9V AC input through four 1N4007 diodes and filtered by a 470µF capacitor on the input and a 100µF capacitor on the output experienced overheating and a short circuit condition. The regulator became excessively hot, and continuity tests indicated a short on the power lines even after removing the 7805 IC and LCD. It was confirmed that electrolytic capacitors, although more prone to drying out and increased resistance, can occasionally fail short-circuited, especially if reused from old boards without testing. Recommendations included using new capacitors with voltage ratings at least double the operating voltage, reducing output capacitance to around 10µF, and verifying capacitor polarity, particularly for tantalum types. The actual cause was identified as a minute solder bridge or conductive debris between PCB tracks, which was removed by careful scraping, resolving the short circuit. The discussion emphasized the importance of thorough visual inspection with magnifying tools, testing reclaimed components with capacitance meters or LCR meters, and proper PCB assembly practices to avoid shorts.
