Using 18V Zener Diode to Drop 36V Input Before 7809 Regulator for Micro Circuit
273 9
Can I use an 18 V zener to drop a 36 V supply before a 7809 regulator, and will that reduce heat?
No—using an 18 V zener ahead of a 7809 will not reduce the total heat; it just moves the power dissipation to the zener or the series resistor, and with a 36 V to 50 V input a switching regulator is the better choice unless the current draw is very low [#21683355][#21683358] If you want to stay with linear regulators, a practical suggestion was to use a 12 V switching regulator module first and then feed the 7809 from that 12 V output, so the 7809 only has about 3 V to drop [#21683356] Another linear approach mentioned was cascading 78-series regulators such as a 7824 first, then a 7812 or 7815, or using a series pass transistor with the zener [#21683360][#21683361]
  • #1 21683354
    Carlos Sorondo
  • Linear dropper still wastes the same heat
    #2 21683355
    Elizabeth Simon
  • #3 21683356
    David Ashton
  • #4 21683357
    Aubrey Kagan
  • #5 21683358
    Al Hajducko
  • #6 21683359
    Rodney Jackson
  • #7 21683360
    Robert Neill
  • #8 21683361
    Robert Neill
  • 18 V gate drive from 36–50 V input
    #9 21683362
    Carlos Sorondo
  • #10 21683363
    Carlos Sorondo
The discussion addresses the feasibility and practicality of using an 18V Zener diode to drop a 36V input before a 7809 linear voltage regulator to power a microcontroller circuit while reducing heat dissipation. It is clarified that using a Zener diode for voltage dropping does not reduce overall heat dissipation but shifts it between components, as the power loss remains the same. A series dropping resistor is necessary with the Zener, which will dissipate significant heat. Alternatives suggested include using a switching regulator to improve efficiency or cascading multiple 78xx series regulators (e.g., 7824 followed by 7812 or 7815) to handle large voltage drops more effectively. Another approach involves using a series pass transistor with the Zener to reduce voltage before the 78xx regulator, though this still results in heat dissipation. The 7809 regulator requires a suitable input voltage margin (typically 3V above 9V output) for proper regulation. The discussion also questions the use of 9V for modern microcontrollers, noting that some boards like the Arduino Nano accept 9V at the VIN pin. The original poster emphasizes the need for stable 9V and 18V supplies from a 36-50V input for powering a Nano board and a MOSFET driver gate, with heat management and long-term reliability as key concerns.
