Is it possible to use 2-way walkie talkie to locate position?
399 10
Can I use two-way walkie-talkies to locate the position of a car or person without GPS or mobile data, and what equipment would I need?
Yes, but a walkie-talkie by itself cannot give an exact position; you need directional beam antennas and at least two fixed receivers separated by a known distance to triangulate the transmitter [#21661914][#21661916] With one radio you can only determine relative bearing, not distance [#21661914] The receivers measure angles, and you can use the law of sines to estimate the location [#21661916] Compasses are also needed on both ends to know the directions [#21661916] If you have two cars, they can be tracked, but you still may not know which signal belongs to which car [#21661916]
  • Suggesting radio direction finding for location tracking
    #1 21661912
    Kk Kk
  • #2 21661913
    Boi Okken
  • Directional antennas enable relative position finding
    #3 21661914
    Earl Albin
  • Clarifying antenna placement and signal identification
    #4 21661915
    Kk Kk
  • Need fixed receivers and one known distance
    #5 21661916
    Earl Albin
  • #6 21661917
    Cody Miller
  • #7 21661918
    Earl Albin
  • #8 21661919
    Kk Kk
  • #9 21661920
    Kk Kk
  • #10 21661921
    Kk Kk
  • #11 21661922
    jack miller
Locating a car or person using 2-way walkie talkies without GPS involves radio signal triangulation techniques. By employing at least two receivers with directional beam antennas placed at known fixed positions, it is possible to approximate the relative position of a transmitter through angle measurements and triangulation, similar to historical aircraft navigation methods using AM radio stations and loop antennas. Distance measurement is challenging without additional data, and identifying multiple moving transmitters requires signal differentiation strategies. The use of compasses and knowledge of trigonometric laws (e.g., law of sines) aids in calculating positions. For hobby projects within a 2-mile range, setting up three antenna stations can improve accuracy. Alternatively, GPS modules like those from Laipac can transmit location data without a mobile data plan, interfacing with microcontrollers to send position information. Some walkie talkies, such as the CX312 model, integrate GPS functionality, enabling tracking without separate GPS devices or data plans.
