Seeking Recommendations for Permission-Free Walkie-Talkies with Up to 5km Range for Forest Hunting
DzikiJanusz 19746 27
What permission-free walkie-talkies can I buy for forest hunting communication over a distance of up to 5 km?
There is no really good permission-free solution for 5 km in forest conditions; legally you mainly have CB or PMR446, and PMR will generally perform worse than CB in the forest [#16843323][#16843350] If you need something that actually works better, the thread recommends licensed VHF hunting radios from Navcomm/HRS or similar suppliers, with more power, different antennas and headsets, and frequencies around 158–159.7875 MHz; users report that this setup is suitable for forest use and can cover about 5 km [#16845317][#16845497][#16857614] One user also noted that in a spruce forest at 1900 m, changing power between 1 W and 5 W made little difference, so antenna quality and band choice matter more than just transmitter power [#16847328] For completely free use, the best practical fallback mentioned was good PMR446, but expectations for range should be modest [#16847523]
  • #1 16843237
    DzikiJanusz
    Dear forum members, I need your help in buying about 10 walkie-talkies, which can be used without permission, and which will be used in the forest when organizing hunting, therefore the range is quite large, up to 5 km.
    SP5IT
    Help: 1298
    Rate: 1689
    Handheld CB radio only.
    Michael
    krisxxl
    Help: 122
    Rate: 202
    As for the CB Radio in the forest, it didn't work for me in the forest. I used Alana 95 Plus initially, then Alana 42 and finally Intek H-520 Plus. A communications drama, because you had to keep your squelch running all the time to hear anything, and it still sounded like something from the otherworld. Communication was carried out for the purpose of coordinating the rallies, so finally we placed a base with a decent antenna and Uniden 520 in the center of the occupied square, and the scheme was such that the base caught towels, collected reports and "rewired" further. I will add that various models and types of antennas were tested on hand towels, but there was no madness. Not to mention battery life. We haven't tested the PMRs, so I can't say. With time, when good GMS coverage appeared, we returned to mobile phones. That's from my experience.
    Regards
    Christian
  • #4 16843268
    DzikiJanusz
    or maybe there will be something good with a shorter range in the range of up to 3 km?
    SP5IT
    Help: 1298
    Rate: 1689
    The nature of the forest is that the higher the frequency, the greater the attenuation. That's why foresters use 48-49MHz. PMR will perform worse than CB.
    Michael
  • #6 16843343
    DzikiJanusz
    So I understand that this investment does not make sense because it will not work? Then I have no idea how else to improve communication during hunting, where there is no range and where several people should participate in the conversation
    AdamC
    Help: 139
    Rate: 245
    Without a permit you have the choice of CB or PMR other options require permits.
    You can buy radiotelephones with a radio license (around PLN 30 per permit) for frequencies around 158MHz or 448MHz, work with 5W power, but with ranges you won't be crazy either.
  • #8 16843617
    yogi009
    Help: 848
    Rate: 2650
    Maybe you should consider licensing?
  • #9 16843629
    SP5IT
    Help: 1298
    Rate: 1689
    And what would that give him? Suddenly 144 or 432MHz will penetrate the forest better?
  • #10 16843630
    c2h5oh
    Moderator
    Help: 502
    Rate: 753
    DzikiJanusz wrote:
    ...Then I have no idea how else to improve communication during hunting...
    For all participants of the hunt? I wish you good luck :) .
    SITO79
    Help: 113
    Rate: 102
    www.radiosys.pl/pl/radiotelefon-dla-hunting
    Target those radios, or at least this frequency.
    Today, practically everyone has a "smartphone" in their pocket, so a great solution for free is to install a messenger. Personally, I recommend WhatsApp, text or voice messages are transferred. The condition is, of course, telephony coverage in the forest and having an Internet package.
  • #12 16844428
    DzikiJanusz
    It's just that the telephony range is very poor, one person has the other not and therefore it's hard for everyone to get the message at the same time. Of course, walkie-talkies are not needed for all hunting participants, only for some of them, up to 10 people, which would increase the safety, efficiency and effectiveness of hunting. To sum up, I thought that the topic would not be so complicated and something effective would be found on the market, but you can see that it is not such an easy thing
  • #13 16845082
    SITO79
    Help: 113
    Rate: 102
    So I think there's no need to mess around, you have to take VHF / UHF radios, plus maybe a slightly longer antenna and if you can, you can.
    Such radios in the HRS company or some other network (the VHF frequency of these companies is probably the same anyway) will probably cost about PLN 100 per piece in the version without a display with one or two channels programmed.
    I recommend asking the seller to repeat the channel several times with other CTCSS subtones, or even DCS, because it may turn out that you will unnecessarily hear some "radio virtuoso" working on this channel with the antenna installed high and 50W of power pushed into this antenna, because he will want to run long-distance hehe.
    CB 27MHz as a frequency, I agree that maybe it works better in the forest, but unfortunately these radios have a very shortened antenna in relation to the wavelength, so I see their meager ranges here and I dare say that even on the HRS, Navcoom or any other UHF band, you will have a better range than on CB.
    If I succeed on Saturday, and there is a good chance for it, I can persuade my friend to do such a test in a spruce forest with an admixture of deciduous (although the leaves have already fallen and it does not matter) and write what it will look like in the amateur band 2m and 70cm .
    I remember very well how years ago my friend and I barely got along on a distance of about 1km between Alan 95+ and Maycom AH27 on the original antennas, standing at the edge of the forest. I have never checked VHF and UHF and for myself I would like to confirm or disprove the theory about the vanity of these bands in the forest once and for all. I suppose that we will even shoot some video-stories and I will make some material from this test.
    P.S. Or maybe there is already something like this on YT and it's enough to search for this site well?
    Please link if anyone finds it.
    Bushman10980
    Help: 40
    Rate: 34
    Hello Colleagues...
    Dump to e.g. paid Navcomm or other company selling equipment together with permits. You have more power, different antennas, headphones, etc... Up to 5 km is enough.
    jkk
    Help: 31
    Rate: 40
    I completely agree with the colleague in post #14. Navcomms are compact, easy to use and have good batteries. In addition, the VHF band performs quite well in various thickets and backwoods, a lot depends on the conductivity of the ground - I checked it myself. Anyway, when buying more devices - you can always negotiate with the supplier to take a pair for testing and check "on the ground" - how they will perform.
  • #16 16845546
    yogi009
    Help: 848
    Rate: 2650
    Again, the distinguished KF brothers (no sarcasm) will disagree with us :-) And the issue would be solved somehow...
    SITO79
    Help: 113
    Rate: 102
    It was supposed to be a test and it is.
    I say unequivocally, some people talk nonsense and that's it.
    A little explanation about the movie.
    I live in the mountains and it's hard to find a fairly straight area between two points, so that there is no more solid hill on the way, so one station a little lower, the other higher, but the distance between us is 1900m, a spruce forest with a small percentage of deciduous trees, power in radios whether 1 or 5W slight change in signals.
    So go to Navcoom or HRS or some other company for an offer and take radios on both frequencies plus permits and you will be satisfied.
    Jap
    Help: 114
    Rate: 654
    The gentlemen from Minister Szyszko have been assigned the frequency 159.7875. So Baofeng GT3 with Nagoya NA771 antenna will solve the problem here.
    Moderated By Olek II:
    I corrected the content.
    3.1.5-3.1.7 Do not post content that deliberately causes conflicts in the forum and violates good manners. Do not challenge the other side of the discussion, even if you have a different opinion.
    yogi009
    Help: 848
    Rate: 2650
    SITO79 wrote:
    So go for an offer to Navcoom or HRS or some other company and take radios on both frequencies plus permits and you will be satisfied.
    I wrote about it in #8.
    SITO79
    Help: 113
    Rate: 102
    I know you wrote.
    Me and other colleagues also wrote above, the material was supposed to illustrate what the signals in both bands would look like.
    This distance could also be handled on good PMR446.
    If a 27MHz towel falls into my hands, I'll try to repeat this test, but remembering what range it had, it won't be crazy.
  • #21 16854076
    DzikiJanusz
    Thanks to the Lord for the indispensable, meticulous help you are great, without you I would probably buy some non-working crap, and so I know what to ask where to look!
  • #22 16854550
    JacekCz
    Help: 760
    Rate: 1463
    Most statements about CB are based on the 15-20cm rubber antenna [---- moderation would cut out the anatomical word] so-called rubber band.
    An antenna 70-80 cm long (I have a fishing rod on some fiber, flexible) changes the situation dramatically.
  • #23 16854845
    SITO79
    Help: 113
    Rate: 102
    Using an antenna of about 1m length for a 2m/70cm radio, we will also cause a dramatic improvement in the work of these bands (RH-770 users can confirm this) and again there will be a very significant jump from the quality that we get from the 27MHz radio even with such a longer antenna. But where is the functionality of such an almost meter long set?
    Having duobanders with antennas with standard 15-20cm lengths in hand, it will be easier to get along between such sets on the 70cm band, because in this case we have full-size "quarters" on the radios.
    We will put on the radio, for example, NA-771 and we already have a 70cm 5/8wave band.
    For such close to several, maybe even ten-kilometer communication, whether the 11m, 2m or 70cm band is of little importance, the band where we will have a more effective antenna will have an advantage.
    Generally, the topic is a river, and practice will always verify any written theories anyway.
  • #24 16857614
    Jap
    Help: 114
    Rate: 654
    The principle is simple ... the efficiency of the antenna strongly depends on its ratio of length to wavelength. And so for some 440MHz the wavelength is 0.7m, for 145MHz it is about 2m, for CB it is 11m. And now, respectively, the so-called half-wave antenna for 440MHz is 35cm, for 145m it is 1m and CB is as much as 5.5m. Also the 1m antenna for CB is a real disaster compared to the 1m antenna on 145MHz.
    To sum up, the frequency of rangers - 159.7875 MHz is just right for the forest. This band penetrates wooded areas well and efficient antennas can be short enough to be toweled.
  • #25 16927398
    Kubulas
    What was the set deviation for 70cm and 2m does anyone know? What types of antennas? 1/2.1/4.5/8 ? Flat mountainous terrain? At what height was the receiver and at what level was the sender? What was the propagation for 2 m and 70 cm that day? Such measurements are amateurish and that's it.
  • #26 16927674
    AdamC
    Help: 139
    Rate: 245
    The area on the given map from your area.
    So we are waiting for professional measurements in your edition.
    Happy New Year !
  • #27 16928881
    SITO79
    Help: 113
    Rate: 102
    You cheered me up this New Year :D
    I am also looking forward to professional range tests in your edition, taking into account all possible weather and propagation conditions.
    Be sure to forecast these conditions to the author of the post before each hunting trip, so that the group knows if they can afford to increase or decrease the distance between themselves.
✨ Forum members discussed the challenges of finding permission-free walkie-talkies suitable for forest hunting with a range of up to 5 km. Recommendations included using CB radios and PMR446 devices, though users reported limited effectiveness in dense forest environments. Some suggested considering VHF/UHF radios with longer antennas for better performance. Brands like Navcomm and Baofeng were mentioned, with specific models such as Baofeng GT3 and antennas like Nagoya NA771 highlighted for their potential effectiveness. The conversation also touched on the possibility of obtaining licenses for higher power radios to improve communication reliability.
TL;DR: Forest hunters usually get 1–2 km from 0.5 W PMR446 radios (EU limit) [ETSI EN 300-296] ; "Handheld CB radio only." [Elektroda, SP5IT, post #16843239] Licensed 5 W VHF (≈159 MHz) sets typically reach 4–5 km [Elektroda, SITO79, post #16845082] Why it matters: Picking the right band prevents silent safety gaps on the hunt.
1. Which permission-free bands can I use in Poland?
Two options: PMR446 (446.0–446.2 MHz, 0.5 W ERP) and CB (26.960–27.410 MHz, 4 W FM/AM). Both are licence-exempt but must meet power and antenna limits [ETSI EN 300-296][Elektroda, SP5IT, post #16843239]
2. How far will PMR446 walkie-talkies reach in dense forest?
Expect 1 km, rarely 2 km, because 400 MHz signals lose 10–15 dB per kilometre in trees [ITU-R P.833-9]. Users report patchy coverage beyond 1 km on hunts [Elektroda, Krissxl, post #16843265]
5. How much does a hunting radio licence cost and cover?
Commercial suppliers bundle a shared-channel permit for ≈ PLN 30 per handset. It allocates two channels (e.g., 158 MHz & 448 MHz) and 5 W power [Elektroda, AdamC, post #16843350]
6. Which antennas improve handheld range without being a spear?
Swap stock 15 cm stubs for 35 cm dual-band NA-771 or similar. Tests show 5–8 dB gain on 70 cm and 2 m [Elektroda, SITO79, post #16854845] Keep total length under 40 cm to avoid snagging branches.
7. What if a 50 W "radio virtuoso" appears on my channel?
Your handheld may be desensed within kilometres. Use CTCSS/DCS plus ask the dealer for extra tonal variants to dodge interference [Elektroda, SITO79, post #16845082] Edge-case: you may need to switch to your backup frequency.
9. How long will batteries last during an all-day drive hunt?
Modern 2000 mAh Li-Ion packs give 10–12 h with a 5 5 90 duty cycle. Early CB handhelds drained in <4 h [Elektroda, krisxxl, post #16843265]
10. Can smartphones plus WhatsApp replace radios?
Only if everyone has data coverage. The original poster noted patchy GSM made phones unreliable for simultaneous group calls [Elektroda, DzikiJanusz, post #16844428] Radios still work where cells vanish.
11. How can we test range before buying ten units?
Many dealers lend two demo radios. Negotiate a weekend field test, as suggested by users who secured trial sets from suppliers [Elektroda, jkk, post #16845497]
12. Quick 3-step: How to obtain a group VHF permit?
  1. Choose a certified dealer (e.g., Navcomm, HRS).
  2. Provide hunt club details; dealer files application to UKE.
  3. Pay fee and collect programmed radios within 2–3 weeks [Elektroda, Bushman10980, post #16845317]
