Walkie-Talkie and CB Radio: Can They Communicate with Each Other?
p5656 41007 11
Can a walkie-talkie communicate with a CB radio, or do they only work with radios of the same type?
Yes, but only if both radios work on the same frequency band; a handheld radio and a CB set will not communicate just because both are called “walkie-talkies” [#2608145][#2608354] CB radios use the 11 m band, while many handheld radios are on other bands such as VHF, so you need to check the actual operating frequency in MHz [#2608145][#2608354] If you want to talk to a CB radio from a bicycle, the simplest solution is to buy a small portable CB radio rather than a generic walkie-talkie [#2612007][#2612061] The thread suggests basic 40-channel CB sets, and mentions portable models like ALAN 37 / ALAN 38 style units [#2612007][#2612061][#2612777] A decent antenna is also important, especially for installation on a vehicle [#2612007]
  • #1 2608082
    p5656
    Hiya !! I have a question, if I have a walkie-talkie, can I also establish communication with someone who has a CB radio, or do the walkie-talkies only work with each other????
    kriss51
    Help: 672
    Rate: 482
    walkie-talkie is a colloquial name for something that is held in the hand and speaks through it. nothing more wrong, e.g. a portable radio for 2m is not a walkie-talkie, but a VHF, and CB works on short waves. I will tell you again that the range of short waves is quite wide and divided into bands so think about what band your so-called walkie-talkie works in. cb works in the 11m band. I hope you get what's going on. Regards
    SITO79
    Help: 113
    Rate: 102
    Yes .
    it has become common in many environments that handi (handheld) radio is always walkie-talkie and whether it is mobile or stationary CB .and it doesn't matter what bands they work on.
    so buddy p5656, if the radios are to work together, they must work on the same frequency. in MHz. so check and you will find the answer to your question yourself.
    Regards.
  • #4 2611967
    p5656
    that is, if I find a walkie-talkie operating on the same frequencies as CB radio, I will be able to make contact, I will be able to listen to the "road", "emergency" channel, etc. ????
    Tomasz.W
    Help: 263
    Rate: 161
    From what you write, you need the most ordinary CB radio. For these channels what you mentioned, the simplest with the basic forty is enough. Just invest in a decent antenna, because it will probably be installed in the car. And don't bother with the naming.
  • #6 2612049
    p5656
    maybe you will say that I'm fucked .... but I want to use a cb radio while riding a bicycle. so i am looking for a device that will be small and light and will allow me to communicate with people who use cb radio (father has a cb in the car). That's why I was thinking about walkie-talkies.
    artur.lubin
    Help: 73
    Rate: 46
    p5656 wrote:
    that is, if I find a walkie-talkie operating on the same frequencies as the CB radio, I will be able to make contact, I will be able to listen to the "road", "emergency" channel, etc. ????
    I highly doubt you'll find one. In fact, there was once a seller on my exchange who offered portable radios with several channels, and in this 19-gauge, however, the devices were very old and colossal, and the antenna itself was about 1 meter long. If you want the device you are writing about, buy the most ordinary portable CB in the ALAN 37 style. http://www.alanfrance.fr/images/248.jpg
    lord_blaha
    Help: 177
    Rate: 112
    Well, maybe some Alan towel
  • #9 2612091
    p5656
    ok, how much would this equipment cost me? Or maybe you know someone who would like to get rid of a radio of this type??
    Added after 27 [minutes]:
    or maybe one of you would have a list of these basic 40 channels and their frequencies?????
  • #11 2612521
    p5656
    Thanks !!!!
    przybor71
    Rate: 19
    Hello. Look at allegro, there are alan 38 towels
    Regards, Przybor71
Walkie-talkies and CB radios operate on different frequency bands, which means they cannot communicate directly unless they are set to the same frequency. Walkie-talkies typically function on VHF or UHF bands, while CB radios operate on the 11m band. If a walkie-talkie is capable of tuning into the same frequencies as a CB radio, communication is possible, allowing users to listen to channels like "road" or "emergency." For portable use, a compact CB radio, such as the ALAN 37, is recommended for those wanting to communicate while biking. Users can find lists of basic CB channels and their frequencies online.
