PICkit3 Not Recognizing PIC16F684 in MPLAB: All Zeros Error When Programming
381 6
  • #1 21662183
    Nickolas Schwarz
  • #2 21662184
    Nickolas Schwarz
  • #3 21662185
    Mark Majewski
  • #4 21662186
    Nickolas Schwarz
  • #5 21662187
    Otto Sponring
  • #6 21662188
    Nickolas Schwarz
  • #7 21662189
    Bruce Brodsky
A PICkit3 programmer fails to recognize a PIC16F684 microcontroller in MPLAB, returning a device ID of all zeros instead of the expected code. Despite using the latest MPLAB version and proper hardware setup including a 10K pull-up resistor to VDD, the PICkit3 detects itself but not the PIC16F684 device. The issue appears common with older microcontrollers and PICkit3 compatibility. Suggested troubleshooting includes verifying manual device selection in MPLAB, as it is not automatic. A practical workaround is to use a PICkit2 programmer, which reportedly works reliably with older PIC microcontrollers like the 16F684. Contacting manufacturer application engineers for support is also recommended. The discussion briefly mentions considering Olimex PICkit3 clones but without resolution.
