Which programmer is compatible with PIC32MX250F128B for reliable programming?
396 7
  • Need a PIC32 programmer with ICSP support
    #1 21682887
    Rich Cox
  • #2 21682888
    Aubrey Kagan
  • Pin 20 and MPLAB X compatibility notes
    #3 21682889
    Conrad Mannering
  • Check MCLR capacitor and PICkit power settings
    #4 21682890
    Mike P OKeeffe
  • Pickit Plus supports PIC32MX250F128B programming
    #5 21682891
    Rick Curl
  • #6 21682892
    Duane Benson
  • PICkit3 needs MPLAB X firmware update and external VDD
    #7 21682893
    Joe Farr
  • #8 21682894
    Rich Cox
Programming the PIC32MX250F128B microcontroller can be challenging with common programmers like PICkit2, PICkit3, and TL866A, which may fail to detect the device. The PICkit3 is officially supported by Microchip for this chip, but requires updated firmware and the use of MPLAB X IDE (version 5.20 or later) for proper recognition. Key hardware considerations include correct MCLR pin configuration without excessive capacitance, proper VCC and VSS connections with adequate bypass and Vcore capacitors, and ensuring the PIC is powered either externally or via the programmer with power enabled in MPLAB X. Low voltage programming should be disabled if issues persist. Alternative software like Pickit PLUS extends support for PIC32MX250F128B on PICkit2 and PICkit3 but is not free. Troubleshooting also involves verifying the integrity of the chips themselves, as multiple faulty units can cause programming failures. A breadboard test setup with correct wiring and updated tools typically resolves programming issues.
