How to Convert 220V 50Hz to 115V, 28V, 26V 400Hz for School Project Circuit?
384 11
How can I convert 220V 50Hz to 115V, 28V, and 26V at 400Hz for a school project circuit?
Use a sine-wave generator feeding a power audio amplifier, then a transformer to step the 400Hz AC to the required voltage; for a simple test setup, a normal 220V-to-30V 50Hz transformer can even be used in reverse, with output adjusted by the amplifier input level [#21662240] [#21662241] For your 25A example at 28V, the load is about 700W, so the amplifier and transformer should be roughly 850W to cover losses [#21662245] A rectifier-to-DC stage followed by a 400Hz DC/AC inverter is another possible approach, but no ready-made schematic was offered in the thread [#21662238] To make one supply for 115V/28V/26V, you still need the exact current required on each output before the circuit can be sized properly [#21662247]
  • #1 21662237
    Dlama Elijah
  • Suggesting rectifier and inverter approach
    #2 21662238
    Mark Majewski
  • #3 21662239
    JAWED MATEEN
  • #4 21662240
    Kevin Parmenter
  • Using a reversed 220 V to 30 V transformer as inverter output stage
    #5 21662241
    JAWED MATEEN
  • #6 21662242
    Dlama Elijah
  • #7 21662243
    Dlama Elijah
  • #8 21662244
    Dlama Elijah
  • Power amplifier and transformer sizing by load current
    #9 21662245
    JAWED MATEEN
  • Clarifying frequency step-up and multi-voltage supply blocks
    #10 21662246
    Dlama Elijah
  • #11 21662247
    JAWED MATEEN
  • #12 21662248
    Dlama Elijah
The discussion addresses converting a 220V 50Hz AC supply to multiple outputs of 115V, 28V, and 26V at 400Hz for a school project. The simplest approach suggested involves rectifying the 220V 50Hz AC to DC (~300V), then using a DC/AC inverter to generate a 400Hz AC output. Challenges include designing or modifying power supplies, as typical PC AT/ATX power supplies operate at much higher switching frequencies (30-70 kHz) and are not directly suitable. Power requirements are critical; the user specifies a load of approximately 25A, equating to about 700W at 28V, necessitating an amplifier and transformer rated around 850W to accommodate losses. One practical solution involves using an audio power amplifier combined with a sine wave generator to produce a 400Hz sine wave, then stepping up the voltage via a transformer capable of handling 400Hz operation. Another method demonstrated includes using a 220V to 30V 50Hz step-down transformer connected in reverse, with output voltage adjusted by varying the input amplitude to the audio amplifier. The user seeks a block diagram for supplying multiple voltages (115V, 28V, 26V) from the same source, with further details on current requirements pending. Designing and fabricating such a circuit requires experience and appropriate equipment, and the discussion emphasizes the importance of specifying exact current demands for each voltage output to optimize the power amplifier and transformer selection.
TL;DR: To get 400 Hz from 220 V, one path is “use a rectifier then a dc/ac inverter”; note AT/ATX switchers run ~30–70 kHz. [Elektroda, Mark Majewski, post #21662238]
Why it matters: Students often ask how to make safe, realistic 115/28/26 V 400 Hz supplies for labs and avionics-style loads.
How do I convert 220 V 50 Hz to 400 Hz AC for a school project?
Two common routes: 1) rectify 220 V to roughly 300 V DC, then feed a 400 Hz inverter; or 2) generate a 400 Hz sine and amplify it. The rectifier–inverter path mirrors how many supplies work, but you must design the inverter stage and output filtering carefully for a clean waveform. Define your load current and whether you need a sine wave before choosing. [Elektroda, Mark Majewski, post #21662238]
What’s the simplest way to get 115 V/400 Hz in a lab?
Use a sine‑wave oscillator into a robust audio power amplifier, then step up with a transformer rated for 400 Hz. This approach is hands‑on, uses off‑the‑shelf parts, and yields a sinusoidal output. As one expert put it, “make sure the transformer can deal with 400 Hz.” [Elektroda, Kevin Parmenter, post #21662240]
Can I drive a transformer in reverse to step up voltage at 400 Hz?
Yes. One contributor tested a standard 220 V→30 V, 50 Hz transformer wired in reverse, driven by an audio amplifier. Adjust the input amplitude to set your output voltage. Verify the core and winding temperature at 400 Hz and under load to avoid overheating. [Elektroda, JAWED MATEEN, post #21662241]
How much power do I need for 28 V at 25 A?
You need about 700 W at the load (28 V × 25 A). Size the amplifier and transformer around 850 W to cover conversion and thermal losses with headroom. This margin helps avoid clipping and overheating during continuous operation or start‑up surges. [Elektroda, JAWED MATEEN, post #21662245]
How do I generate a clean 400 Hz sine wave?
Use a sine generator (function generator or oscillator circuit) set to 400 Hz, feed an audio power amplifier, then a transformer. This chain preserves the sine shape if you avoid amplifier clipping and keep the transformer within its frequency rating. [Elektroda, Kevin Parmenter, post #21662240]
Can I modify a PC AT/ATX PSU to output 400 Hz?
Not practically. AT/ATX supplies switch around 30–70 kHz and are optimized for DC outputs, not 400 Hz AC. Modifying them for a stable 400 Hz sine is complex and unreliable for student builds. Use a purpose‑built inverter or the audio‑amp method instead. [Elektroda, Mark Majewski, post #21662238]
Do I need a pure sine output for 400 Hz loads?
Many 400 Hz applications expect a sine wave. One responder asked explicitly whether your load requires a sinusoid. If your instruments mimic 400 Hz mains, choose a sine output; the audio‑amp approach produces it naturally. Clarify this before designing. [Elektroda, Mark Majewski, post #21662238]
How can I supply 115 V, 28 V, and 26 V from one system?
It depends on current per rail. A helper requested exact current for 115/28/26 V to propose a single‑supply plan. With defined currents, you can choose transformer taps or separate secondaries and size the amplifier accordingly. Provide those numbers first. [Elektroda, JAWED MATEEN, post #21662247]
Is there a quick 3‑step build plan I can follow?
  1. Set a 400 Hz sine source and feed an audio power amplifier.
  2. Connect the amplifier to a suitable transformer wired to step up/down as needed.
  3. Measure output voltage under load and adjust input amplitude; confirm the transformer handles 400 Hz. [Elektroda, JAWED MATEEN, post #21662241]
What are common pitfalls when driving transformers at 400 Hz?
Using a transformer not rated for 400 Hz can cause excess heating or saturation at load. Also, an undersized audio amp will clip, distorting the sine and raising losses. As one expert warned, “make sure the transformer can deal with 400 Hz.” [Elektroda, Kevin Parmenter, post #21662240]
What details should I share to get accurate help?
State total power and the exact current for each voltage rail (115 V, 28 V, 26 V). Helpers asked specifically for power/current before proposing a unified design. Include whether the output must be sinusoidal and any duty cycle expectations. [Elektroda, JAWED MATEEN, post #21662247]
Is rectifying 220 V to ~300 V DC a valid first step?
Yes. Rectifying and filtering 220 V AC yields roughly 300 V DC, which can feed a dedicated 400 Hz inverter stage. This method matches how contributors suggested approaching a 400 Hz source when designing beyond the audio‑amp route. [Elektroda, Mark Majewski, post #21662238]
