Why Does Current Lag Voltage in an Inductive Circuit or Coil?
387 10
Why does current lag behind voltage in a circuit with an inductor?
Current lags behind voltage in an inductor because a changing current creates a magnetic field that induces a back EMF opposing the change in current, so the current cannot rise or fall instantly [#21662682][#21662683] In an ideal purely inductive AC circuit, this is written as i(t) = Im.sin(wt - pi/2), meaning the current is 90° behind the applied voltage [#21662683] At the instant voltage is applied, an ideal inductor behaves like an open circuit, and then the current builds up over time as the back EMF is overcome [#21662684] In real circuits, non-ideal effects such as core saturation can change the transient response and produce inrush current [#21662688]
  • #1 21662680
    ASAD ALI
  • #2 21662681
    Aniruddh Kumar Sharma
  • #3 21662682
    Supratim Srinivasan
  • Current lags voltage by 90° in an inductor
    #4 21662683
    Peter Emson
  • Inductor starts open-circuit, causing current lag
    #5 21662684
    Steve Lawson
  • #6 21662685
    ASAD ALI
  • #7 21662686
  • Motor speed and capacitor charging explain current behavior
    #8 21662687
    Frank Bushnell
  • Inrush current comes from non-ideal inductor behavior
    #9 21662688
    Steve Lawson
  • Motor startup current rises logarithmically before stall current
    #10 21662689
    Steve Lawson
  • #11 21662690
    Steve Lawson
Current lags voltage in an inductive circuit due to the inductor's property of self-inductance, where a changing current induces a back electromotive force (back EMF) opposing the change in current, as described by Lenz's law. When voltage is applied, the inductor initially behaves like an open circuit because the back EMF opposes the rise of current, causing the current to increase gradually and thus lag behind the voltage. In DC circuits, once the magnetic field stabilizes, the inductor acts like a short circuit with steady current flow. In AC circuits, the continuous change in current induces a continuous back EMF, maintaining the current lag. The inrush current observed in inductive machines occurs as the current overcomes the back EMF during startup, and the transient response follows a logarithmic rise rather than an instantaneous jump. Capacitors exhibit opposite behavior, with current leading voltage. Real-world factors such as core saturation and stalled current affect these ideal behaviors.
