Voltage and why voltage cannot change instantaneously in capacitor but current but why current cannot change instantaneously in inductor. Thank you in advance.
Capacitor and inductor equations require infinite impulse values
The formula i = C dV/dt says that the current thru a capacitor is equal to capacitance multiplied by dV/dt. To change voltage instantaneously (infinite dV/dt) the current must be infinite.
To formula V = L di/dt says that the voltage across an inductor is equal to inductance multiplied by di/dt. To change current instantaneously (infinite di/dt) the voltage must be infinite.
changing the current or voltage instantaneously means (dt=0approximately) i.e the slop (dv/dt or di/dt) goes to infility . then i(for the c) or v(for the inductor) should be infinite.
dv/dt is the change of the voltage with respect to time. Remember that capacitors are open when applied with a DC voltage. A DC voltage has dv/dt = 0, which means that there is no change in its voltage. Applying it in the equation i = C dV/dt, current would be zero. The contrary applies to inductors. Please check on the capacitor/inductor graphs for more info.
