Why does induced current require a changing magnetic field instead of a steady DC current?
Induced current is produced only by a changing magnetic field, so a steady DC current does not induce anything once it is constant [#21664130] The inductance relationship is V = L di/dt, which means if current does not change with time, the induced voltage is zero [#21664129] A DC current can still create induction while its magnitude is changing, but not when it is steady [#21664130]
  • #1 21664127
    Zahoor Ahmad
  • #2 21664128
    Zahoor Ahmad
  • #3 21664129
    Ulf Kirchner
  • Changing magnetic fields induce current, not steady DC
    #4 21664130
    Steve Lawson
  • #5 21664131
    Earl Albin
  • #6 21664132
    Per Zackrisson
  • #7 21664133
    Steve Lawson
  • #8 21664134
    DAVID CUTHBERT
  • #9 21664135
    Zahoor Ahmad
  • #10 21664136
    Zahoor Ahmad
Induced current is always alternating current (AC) rather than direct current (DC) because it arises from a changing magnetic field, which requires a time-varying current or magnetic flux. According to the law of inductance (V = L di/dt), if the current does not change over time (as in steady DC), the induced voltage and thus induced current will be zero. A DC current can only induce a current if its magnitude changes over time, but not if it remains constant. This principle is rooted in Faraday's law of electromagnetic induction and Lenz's law, which state that only a varying magnetic field can induce an electromotive force (EMF) and consequently an induced current in a conductor.
