Difference Between Rheostat and Potentiometer: Functions, Wiring, and Applications
453 8
  • #1 21662883
    Puneet Thakral
  • Rheostat and potentiometer are circuit implementations
    #2 21662884
    Steve Lawson
  • #3 21662885
    Puneet Thakral
  • #4 21662886
    Floy Viola
  • #5 21662887
    Puneet Thakral
  • #6 21662888
    Ashesh Sharma
  • Clarifying where rheostats are applied
    #7 21662889
    Floy Viola
  • #8 21662890
    David Adams
  • #9 21662891
    Puneet Thakral
A rheostat is a two-terminal variable resistor primarily used to control high power currents, typically above 1 watt, by adjusting resistance in power circuits such as DC motor drives and electric welding controls. It is often constructed with resistance wire wound on a heat-resistant cylinder, with a sliding wiper or metal fingers to vary the tapping point. In contrast, a potentiometer is a three-terminal device functioning as a variable voltage divider, commonly used in low power applications under 1 watt, such as volume controls. Although both devices can be implemented using a three-terminal variable resistor, the rheostat uses only two terminals (wiper and one end), while the potentiometer uses all three terminals to provide variable voltage output. Rheostats limit current flow, whereas potentiometers provide adjustable voltage without significant current limitation.
