Potentiometer Markings: Understanding A, B, W Types & Differences (e.g. 2.2k-A, 100k-W)
adi-niunio 58295 15
What do potentiometer markings like 2.2k-A, 2.2k-B, and 100k-W mean, and how do the A/B/W types differ?
A/B mark the potentiometer taper, while W marks the power rating: A is linear, B/C are non-linear tapers (the thread disagrees on whether B is logarithmic and C exponential or the other way around), and W means the potentiometer’s wattage, for example 0.25 W [#424186][#424045][#424240][#4928200] One reply also notes that A is the usual linear type, while B and C are used for audio-related controls such as volume or tone, because the control is matched to how the ear perceives changes [#424186][#4928200] So a 2.2k-A part is 2.2 kΩ with a linear curve, and a 100k-W part is 100 kΩ with a specified power rating rather than a special taper [#424186]
  • #1 423644
    adi-niunio
    Help: 9
    Rate: 33
    I know that there are different markings of the potentiometers
    e.g. 2.2k - A; 2.2k - B
    How are they different ??
    There is also a "W" marking and I care about it the most because I need such 100k-W, and I can't get it. The guy in one skep told me that this is the first time he has heard of such :(
  • #2 424045
    MisiekD
    Honestly, I also met the designation W for the first time, write to what and maybe we will come up with something.
    As for the markings, they mean as much as the first number is the resistance of the resistor, i.e. 2.2k is just 2.2 kiloohms (2200 ohms), and this letter - A or B - is the characteristic: A - linear, B - logarithmic (or vice versa :D but rather yes), and what does it mean: linear - if you have, for example, a 1k resistor, if you set it to 10%, you will have a resistance of 100ohm, and as for 50% it is 500ohm, while the logarithmic is such that the closer to the end, the more resistance goes up (like a logarithm plot)
  • #3 424186
    hefid
    Rest in Peace
    Help: 546
    Rate: 6172
    As previously stated:
    A- is a potentiometer with a linear characteristic
    B- is a potentiometer with an exponential characteristic
    C- is a potentiometer with a logarithmic characteristic.
    Potentiometers B and C are usually used to adjust the volume (or gain) in acoustic amplifiers due to the specificity of human hearing.
    The letter W means the potentiometer power, e.g. 025 W means a potentiometer with a power of one quarter Watt.
  • #4 424240
    marian-48
    Rate: 31
    :arrow: hefid I think you made a mistake and it should be;
    B- potentiometer with logarithmic characteristics
    C- potentiometer with exponential characteristics
    ... the rest o, key
  • #5 424254
    adi-niunio
    Help: 9
    Rate: 33
    you know what it is when you don't read the texts exactly. I am making a mixer with PE 9/2002 and subsequent numbers and there are potentiometers marked with the letter W in the voice equalizer.
    whatever that means, I can't get such potentiometers in Zabrze, so which one should I use ??????????
  • #6 424411
    Ptolek
    Level 36  
    Help: 318
    Rate: 271
    With these characteristics it is different, according to one wise book the type B potentiometer has an exponential characteristic, and according to another wise book it has a logarithmic characteristic. And I do not know what it should be like, if someone knows 1000%, let him say it :)
    As for this W-type potentiometer, I have the impression that this letter does not mean the characteristics of the potentiometer, although I may be wrong. Usually, in tone controls, linear potentiometers (type A) are used. Unless it's some audiophile mixer :roll:
  • #7 424649
    Tremolo
    Help: 1016
    Rate: 497
    All in all, give the potentiometer you want there, you will have a problem with the accuracy of regulation related to the non-linearity of human hearing
    The characteristic of S is so arranged that at the ends it allows for more precise control and when passing through the center (I think so when I understand this description)
    This can be done from an ordinary pot by adding an RC circuit to it
  • #8 428023
    hefid
    Rest in Peace
    Help: 546
    Rate: 6172
    I think I got the potentiometer designations right though. Until now, this is how they were labelled in POLISH electronics and in all Polish equipment. And I've known these designations for several dozen /at least 45/ years.
    This is how they used to be listed in the catalogues of manufacturers, including TELPOD from Kraków, a leading manufacturer at the time, not only of potentiometers.
    And that was it, as Professor Jan Tadeusz Stanisławski used to say.
  • #9 430528
    broda997
    And I have such a marking on the 1M2 potentiometer, it is an old tube amplifier and all the potentiometers have 2 at the end. :P
  • #11 432560
    broda997
    I thought it was 1.2 MOhm too, but the meter was showing a maximum of 700 kOhms, but I put in one of those 1 MOhm ones and it works, so no problem.
  • #12 1505508
    jpalach
    broda997 wrote:
    I also thought it was about 1.2Mohm, but the meter showed a maximum of 700Kohm. But I put on this 1Mohm and it works, so after the trouble.
    1M2 is 1.2 Mega Ohm, but when measuring with a meter, you could have made one mistake: you say that the potentiometer was from a tube amplifier, you could measure the resistance on the element connected to the circuit. Then the voltage divider is made, and such an indication is worth nothing (although not always :) ). It is enough to unsolder one leg in the potentiometer and check it.
  • #13 1506967
    k4be
    Help: 102
    Rate: 333
    M and N potentiometers are probably from the balance?
  • #14 1507232
    jpalach
    I made a blunder - I didn't look at the date of the last post :) I think the questioner has probably already found the answer ;)
  • #15 3026839
    piechczu
    I have a question, I just finished the "line of light" I have a M15 potentiometer (I do not know what it means, but the detail :P ) but my point is that if it gives it at a minimum, the LEDs, in my opinion, are still flashing too quickly, I would like them to walk even more ... do you have any idea ?? Thanks in advance POZDRO :)
  • #16 4928200
    dino7
    Rate: 14
    I have a question.
    What potentiometers are usually used for volume control in audio amplifiers? I mean the power value (0.1W; 0.5W; 2W?) The volume control potentiometers are placed between the preamplifier and the power amplifier?
    The case is that he is building a guitar stove. The equalizer block has an adder at the output, which also serves as a preamplifier. I do not know what amplification this adder (operational amplifier) has (I downloaded the ready schematic).
    What values of potentiometers (power) are usually used in such cases and if I put 0.25W there (shooting, without calculations) it should be enough?
    Speaking of the characteristics of potentiometers, some time ago during the lesson we had something like the one in the picture.
    A - rectilinear
    B - logarithmic (used to adjust the volume gain). This is the whole characteristic of how sound can be absorbed by the human ear.
    C - exponential (tone control)
    • Potentiometer Markings: Understanding A, B, W Types & Differences (e.g. 2.2k-A, 100k-W) ABC.JPG (7.89 KB) You must be logged in to download this attachment.
The discussion revolves around the different markings on potentiometers, specifically the A, B, and W types. The letter A indicates a linear characteristic, while B denotes a logarithmic characteristic, and C is associated with an exponential characteristic. The W marking refers to the power rating of the potentiometer, such as 0.25W. Users express confusion regarding the W designation, particularly in the context of audio equipment, where specific types are required for applications like mixers and equalizers. The conversation highlights the importance of understanding these characteristics for proper application in audio devices, as well as the challenges in sourcing specific potentiometer types.
