Anyone still using a slide rule for calculations instead of calculators or computers?
279 23
Do any electronics engineers still use a slide rule for calculations instead of calculators or computers?
Yes, but mostly only for occasional quick estimates rather than everyday work. One user still uses a slide rule because it makes resistor-ratio and voltage-divider calculations easy [#21662982] Another says they use one only rarely for fast decimal multiplication when about three-digit accuracy is enough [#21662989] Others report that they stopped using slide rules long ago after calculators became common, though they still keep one around or remember using them in school [#21662983][#21662989] In practice, people now rely on mental arithmetic, calculators, or computers for most work, especially for functions like logs and trig [#21662988]
  • #1 21662980
    Floy Viola
  • #3 21662982
    Floy Viola
  • #4 21662983
    Steve Lawson
  • #5 21662984
    Elba R Dalet
  • #6 21662985
    Joe Wolin
  • #7 21662986
    Peter Evenhuis
  • #8 21662987
    Floy Viola
  • Manual estimation and graphing skills still matter
    #9 21662988
    David Adams
  • Remembering slide rule scales and limited use
    #10 21662989
    Richard Comerford
  • #11 21662990
    David Adams
  • #12 21662991
    Richard Comerford
  • #13 21662992
    Richard Comerford
  • #14 21662993
    Richard Comerford
  • #15 21662994
    Floy Viola
  • #16 21662995
    Joe Wolin
  • #17 21662996
    David Adams
  • #18 21662997
    Richard Comerford
  • #19 21662998
    Steve Lawson
  • #21 21663000
    Richard Comerford
  • #22 21663001
    Gregg Williams
  • #23 21663002
    madhurika Shrivastava
  • #24 21663003
    Richard Comerford
The discussion centers on the continued use and relevance of slide rules for calculations in the modern era dominated by calculators and computers. Some participants still use slide rules for specific tasks such as calculating resistor ratios in voltage dividers or for quick approximations requiring limited precision. Others recall learning and using slide rules extensively in education and early engineering careers, noting the transition to handheld calculators like those from Texas Instruments. The conversation highlights the decline in manual calculation skills due to reliance on digital tools, with references to logarithmic and trigonometric functions, semi-log graph paper, and Bode plots. Virtual slide rule simulators and smartphone apps are mentioned as modern adaptations. The discussion also touches on Reverse Polish Notation (RPN) calculators, their historical association with Hewlett-Packard, and the availability of online engineering calculators supporting algebraic and RPN modes. Historical context includes the invention of the slide rule by William Oughtred based on John Napier's logarithms and its widespread use before pocket calculators. Specialized slide rules for fields like aviation and finance are noted for their additional scales. Overall, the thread reflects nostalgia, practical use cases, and educational value of slide rules alongside modern computational tools.
TL;DR: Yes—people still use slide rules for quick, 3‑sig‑fig work. One engineer recalls “two weeks (8 hours/day) of calculator training,” and warns: “The use of calculators…has ruined man’s ability to manipulate numbers.” [Elektroda, David Adams, post #21662988]
Why it matters: If you tinker, study, or work where batteries die or devices are banned, a slide rule stays fast, durable, and EMP-proof.
Do people still use slide rules instead of calculators or computers?
Yes, mainly for quick estimates, education, or as a no‑power backup. Several posters still own and occasionally use slide rules for fast multiplicative tasks and voltage‑divider ratios. One keeps a slide rule “In Case of Emergency, Break Glass” above his workstation, underscoring its backup role. [Elektroda, Richard Comerford, post #21662989]
How accurate is a slide rule in practice?
Expect about three significant digits. That level suits resistor ratios, scaling laws, and sanity checks. One engineer notes using a slide rule for fast decimal multiplication when only three‑digit accuracy was needed. For tighter tolerances or statistics, use a scientific calculator or software. [Elektroda, Richard Comerford, post #21662989]
What calculations are slide rules good at—and not good at?
They excel at multiplication, division, roots, logarithms, and trigonometry. They do not perform addition or subtraction directly. Treat them as an analog computer for proportional reasoning and order‑of‑magnitude checks. For sums and differences, switch to pencil‑and‑paper or a calculator. [Elektroda, madhurika Shrivastava, post #21663002]
How do I quickly compute a resistor divider with a slide rule?
  1. Set the C scale 1.0 under the top resistor value on the D scale.
  2. Move the cursor to the bottom resistor value on C.
  3. Read the ratio R2/(R1+R2) or R1/R2 as needed, then apply to input voltage for Vout. “Great for resistor ratios as a voltage divider.” [Elektroda, Floy Viola, post #21662982]
Is there a free way to learn without buying a slide rule?
Yes. Use the online N909‑ES virtual slide rule to practice movements, cursor alignment, and reading scales. It mirrors classic linear rules and includes guides. Start with multiplication/division, then try logs and square roots. [Elektroda, Joe Wolin, post #21662985]
What does RPN mean, and why do engineers mention it with calculators?
RPN stands for Reverse Polish Notation, a stack‑based entry method used by classic HP calculators and favored by some engineers for speed. It also appears in the Forth language, which uses stack operations for calculations. [Elektroda, Steve Lawson, post #21662998]
Why is it called “Polish” notation?
It references logician Jan Łukasiewicz, who introduced Polish notation; RPN is the reversed form. A poster quips it’s named because it goes “against that of Poland,” linking to background on Polish notation. [Elektroda, Joe Wolin, post #21662999]
When did slide rules fall out of mainstream engineering use?
Around 1974, affordable handheld scientific calculators displaced them in classrooms and labs. By the mid‑1970s, most suppliers exited the market as engineers adopted TI and HP calculators. [Elektroda, madhurika Shrivastava, post #21663002]
Are there smartphone apps or modern tools that mimic slide rules?
Yes. Users report slide‑rule apps on smartphones and recommend web calculators like eCalc, which supports algebraic and RPN modes and complex numbers. These help practice workflows and handle advanced math when precision is required. [Elektroda, Joe Wolin, post #21662995]
How steep is the learning curve compared to a calculator?
It’s approachable. One member trained two weeks at 8 hours per day on calculators, yet still values mental math and tables. A slide rule builds number sense through estimation and scale reading. “The use of calculators…has ruined man’s ability to manipulate numbers.” [Elektroda, David Adams, post #21662988]
What’s an edge case where a slide rule beats digital tools?
During power loss, device bans, or EMP events, a slide rule still works. One commenter joked these will be “worth their weight in gold” after a nuclear or EMP event, highlighting resilience as the differentiator. [Elektroda, Joe Wolin, post #21662985]
Which brands or models do posters remember using?
Mentions include HP (RPN heritage) and TI calculators arriving during junior years, which rapidly replaced slide rules. Some keep Ricoh slide rules and display them as memorabilia, yet still use them for quick decimal math. [Elektroda, Richard Comerford, post #21662989]
What are common slide‑rule scales, and what does the P scale do?
Common scales include C/D for multiplication/division, and trig/log scales for angles and logs. Posters reference comprehensive scale guides that explain specialized scales like P, which assist with certain trigonometric relationships and powers on some models. “See the slide‑rule scales guide.” [“Slide Rule Scales – HP Museum”]
Can universities still require slide‑rule use?
Some instructors assign a slide‑rule exercise to build estimation and logarithmic intuition. One poster notes a professor incorporating a slide‑rule project in an online engineering course, then returning to modern tools. [Elektroda, Gregg Williams, post #21663001]
Is mental math still useful if I rely on calculators?
Yes. An experienced engineer reports often rounding and calculating in his head within 10% of a calculator result, using a calculator only for logs. This keeps intuition sharp and reduces over‑reliance on devices. [Elektroda, David Adams, post #21662988]
I learned on tables and semi‑log paper—does that still matter today?
Yes. Skills like reading tables, estimating square roots, and hand‑drawing Bode plots build insight into systems. Several posters reminisce about log tables and manual plotting, which complement modern tools like Excel. [Elektroda, David Adams, post #21662988]
