How to Set Output Voltage to 3.9V and Choose Inductor for NCV890230 Switching Regulator
348 13
How do I set the NCV890230 switching regulator to 3.9 V output, and what inductor should I choose for a 2 A peak load?
Set the feedback divider so the FB pin sees 0.8 V at the desired output; one suggested 3.9 V example is about RFB1 = 31 kΩ and RFB2 = 8 kΩ if you choose roughly 100 µA divider current [#21663161], and onsemi’s example uses about a 4:1 ratio such as 100 kΩ over 26 kΩ for about 3.88 V [#21663169] The key point is that the regulator controls to 0.8 V on FB, and the divider current should be much larger than the 1 µA worst-case FB bias current [#21663160][#21663161] For the inductor, the datasheet specifies 4.7 µH [#21663164] Choose a power inductor whose current rating is about 1.5 to 2 times the calculated peak current; one estimate for an 11 V input and 3.9 V output gave about 2.2 A peak, so a 3 to 4 A saturation-current part was recommended [#21663164] Also pick a self-resonant frequency well above 2 MHz, and recalculate if your input voltage differs [#21663164]
  • #1 21663158
    Daniel Davids
  • #2 21663159
    Subham Chatterjee
  • #3 21663160
    Steve Lawson
  • Feedback divider values for 3.9 V output
    #4 21663161
    Steve Lawson
  • #5 21663162
    Steve Lawson
  • #6 21663163
    Steve Lawson
  • Inductor sizing method for NCV890230 buck regulator
    #7 21663164
    Steve Lawson
  • #8 21663165
    Daniel Davids
  • #9 21663166
    Steve Lawson
  • Output precharge detection may delay startup with battery load
    #10 21663167
    Daniel Davids
  • Suggesting output isolation until regulator reaches voltage
    #11 21663168
    Steve Lawson
  • Resistor divider values for 3.88 V output
    #12 21663169
    Daniel Davids
  • #13 21663170
    Steve Lawson
  • #14 21663171
    Steve Lawson
The discussion addresses setting the output voltage to 3.9V for the NCV890230 switching regulator and selecting an appropriate inductor for 2A peak current delivery. The output voltage is set by configuring a feedback voltage divider to provide 0.8V at the FB pin when the output voltage reaches the target. A recommended design uses a feedback current approximately 100 times the worst-case FB bias current (1µA), resulting in resistor values around 8kΩ for Rfb2 and 31kΩ for Rfb1 to achieve 3.9V output. An alternative suggestion involves using a 3.9V Zener diode across the output, though the voltage divider method is preferred for precision. For inductor selection, the datasheet specifies a 4.7µH power inductor with a saturation current rating 1.5 to 2 times the peak current. Peak current (Ipeak) can be calculated considering input voltage, transistor voltage drop, output voltage, on-time, and load current. The duty cycle and on-time are derived from input/output voltages and switching frequency. Additional discussion highlights concerns about output precharge detection when powering a Li-ion battery, suggesting isolation methods to prevent unwanted battery discharge. Official On Semiconductor guidance confirms resistor divider ratios for feedback, e.g., Rfb1 approximately four times Rfb2 for 3.9V output, but notes the ratio varies with output voltage. No specific inductor brands were recommended.
TL;DR: Need 3.9 V from NCV890230? Use the FB divider: statistic—1 µA FB bias; expert tip—“deliver 0.8V to the FB pin.” [Elektroda, Steve Lawson, post #21663160] Why it matters: This FAQ shows how to set 3.9 V and pick the inductor safely for 2 A peaks, ideal for car and battery projects.
How do I set the NCV890230 output to 3.9 V?
Design the FB divider so the FB pin sees 0.8 V at 3.9 V out. Then choose resistor values that draw enough current to swamp the 1 µA FB bias. As Steve advises, “deliver 0.8V to the FB pin.” [Elektroda, Steve Lawson, post #21663160]
What resistor values should I start with for 3.9 V?
Target 100 µA through the divider. Use RFB2 ≈ 0.8 V/100 µA = 8 kΩ. Then RFB1 ≈ (3.9 − 0.8) V/100 µA ≈ 31 kΩ. This keeps FB bias error negligible. [Elektroda, Steve Lawson, post #21663161]
Is a fixed 4:1 divider ratio required?
No. The ratio depends on your target Vout. A 4:1 example can land near 3.9 V, but other outputs need different ratios. Steve questioned using a fixed ratio without considering Vout. [Elektroda, Steve Lawson, post #21663170]
Can I just put a 3.9 V zener on the output to set voltage?
No. This regulator sets Vout via the feedback divider to 0.8 V at FB, not by a zener clamp. Use the FB network approach for regulation accuracy. [Elektroda, Steve Lawson, post #21663160]
How do I choose the inductor value and current rating?
Start with 4.7 µH. Compute peak current: Ipeak = (((Vin − Vtran − Vout)·Ton)/L) + Io. Then select an inductor with 1.5–2× that peak (saturation rating). Ensure SRF comfortably above 2 MHz. [Elektroda, Steve Lawson, post #21663164]
How do I calculate Ton and duty cycle for the inductor check?
Duty cycle D ≈ (Vout − Vd)/(Vin − Vtran − Vd). Then Ton = D/f. Example with 11 V in, 0.8 V diode, and 1.8 MHz gives Ton ≈ 189 ns and Ipeak ≈ 2.2 A at 3.9 V, 2 A load. [Elektroda, Steve Lawson, post #21663164]
What is the FB divider, in simple terms?
Two resistors scale the output so the FB pin reads 0.8 V at the desired Vout. Set current high enough that 1 µA FB bias barely matters. [Elektroda, Steve Lawson, post #21663160]
What does the freewheeling diode do here?
It carries inductor current when the switch turns off. Its forward drop Vd appears in the duty‑cycle math and affects Ton and Ipeak. [Elektroda, Steve Lawson, post #21663164]
Any quick 3‑step method to pick the divider?
  1. Choose divider current (≥20× 1 µA; e.g., 100 µA).
  2. Compute RFB2 = 0.8 V / Idivider.
  3. Compute RFB1 = (Vout − 0.8 V) / Idivider. [Elektroda, Steve Lawson, post #21663161]
Does the NCV890230 start if a Li‑ion battery is already on the output?
It may delay startup due to output precharge detection. Isolate the output until the regulator reaches operating voltage, or use an active switch or different IC. Edge case: direct connection can prevent soft‑start. [Elektroda, Steve Lawson, post #21663168]
How much safety margin for inductor current is sensible?
Select an inductor with saturation current about 1.5–2× the computed Ipeak. For a 2.2 A peak, look around 3–4 A. [Elektroda, Steve Lawson, post #21663164]
What if my car battery dips to 11 V?
Recalculate D, Ton, and Ipeak using the 11 V input case. The example shows D ≈ 0.34 and Ton ≈ 189 ns, guiding inductor choice. [Elektroda, Steve Lawson, post #21663164]
Any guidance on divider current for efficiency vs. accuracy?
Use at least 20× the 1 µA FB bias to minimize error. The worked example uses 100×, which is still efficient at these levels. [Elektroda, Steve Lawson, post #21663161]
Who provided the key equations and examples here?
Engineer Steve Lawson detailed the FB divider approach, current scaling guidance, duty‑cycle math, and the inductor sizing example in the thread. [Elektroda, Steve Lawson, post #21663164]
