Why Do My On-Demand 12V Pumps With Pressure Switches Keep Blowing 20A Fuses?
537 12
Why do my 12V on-demand pumps with pressure switches keep drawing enough current to blow 20A fuses and burn out?
Your pumps are most likely being overloaded because they are being run outside their intended duty cycle and pressure/flow limits, so they stall, overheat, and draw high current. A motor draws its maximum current when stalled or prevented from moving, and the 16A figure may be the startup draw rather than a continuous rating [#21663743][#21663753] These RV/marine-style pumps are meant for short intermittent use, so if the nozzle, hose, inlet, outlet, or pressure conditions keep them from reaching cutoff, they can run continuously and get hot enough to fail [#21663750][#21663744] The fluid and application also matter: thick liquid, blocked filters, excessive height/head pressure, or too-small nozzles can all keep the pump under heavy load [#21663744][#21663750][#21663753] Chlorine is also hard on pumps and can damage valves and other parts, so a chemical-sprayer pump better suited to that fluid and lift height is a better match [#21663752] The practical checks are to measure current with an ammeter under load, watch pump temperature, and confirm with the manufacturer whether the pump’s duty cycle and pressure rating fit your use [#21663753]
  • #1 21663742
    Ed Thompson
  • Motor stall current may be blowing the fuses
    #2 21663743
    Timothy Shuck
  • Low speed, blocked flow, or weak supply can blow fuses
    #3 21663744
    Peter Evenhuis
  • #4 21663745
    Ian Brown
  • Head pressure and voltage drop may be causing cycling
    #6 21663747
    Ed Thompson
  • Chlorine use and high head may be shortening pump life
    #7 21663748
    Ed Thompson
  • #8 21663749
    Ed Thompson
  • Continuous running likely overheating the pumps
    #9 21663750
    Chuck Sydlo
  • Cheap pump likely undersized for roof cleaning load
    #10 21663751
    Ed Thompson
  • Chlorine damage and valve failure overloading pumps
    #11 21663752
    Peter Evenhuis
  • Measure pump current and compare duty cycle limits
    #12 21663753
    Frank Bushnell
  • #13 21663754
    Ed Thompson
On-demand 12V pumps with pressure switches rated for 16A max are blowing 20A fuses due to current spikes caused by motor stall conditions, rapid cycling, or excessive load. The pumps draw maximum current at startup or when physically stalled, such as when fluid viscosity is high, input or output lines are restricted, or pressure settings are borderline. Using chlorine mixtures, which are corrosive and thickening under motion, further stresses pumps not designed for chemical spraying or vertical lift beyond typical RV applications. Inadequate wiring (undersized gauge, poor connections, long runs), unstable or undersized power supplies, and lack of thermal protection contribute to premature pump failure. Duty cycle limitations of these pumps, often designed for intermittent use in recreational vehicles, mean continuous operation or cycling can cause overheating and fuse blowouts. Solutions include verifying current draw with an ammeter, ensuring proper wiring (e.g., 12-3 wire, crimped connections), using larger marine batteries, selecting appropriate hose sizes to minimize head pressure and cycling, installing pressure gauges, and considering pumps with higher duty cycles, internal fans, and thermal protection. Switching to pumps designed for chemical spraying with suitable gearboxes and oil lubrication is recommended for applications involving chlorine and elevated pumping heights. The Delavan PowerFlo 5800 series was referenced as a typical model with a 16A startup current and 100 psi max pressure rating.
TL;DR: Your 12V on‑demand pumps are blowing 20A fuses because heat and stall/start spikes overwhelm RV‑style units; “The manufacturer recommends not letting the surface temp of the pump exceed 180 degrees.” [Elektroda, Chuck Sydlo, post #21663750] Why it matters: This FAQ helps roof cleaners, RV users, and sprayer techs quickly diagnose fuse blows, cycling, and premature pump failures.
Why does a 16A-rated 12V pump blow a 20A fuse?
DC motors draw maximum current at stall and at startup. Fast cycling or blockage raises current beyond fuse limits. “The motor in the pump will draw its maximum current when stalled.” Use correct nozzle sizing and avoid rapid on/off to reduce spikes. [Elektroda, Timothy Shuck, post #21663743]
What is stall current, in simple terms?
Stall current is the highest current a motor draws when it cannot turn. Starting and hard cycling mimic stall conditions and create big current spikes that blow fuses. Reduce restrictions and give the pump time to reach speed to cut peaks. [Elektroda, Timothy Shuck, post #21663743]
How do nozzle size and hose height cause pump cycling?
Too-small nozzles or high head from second/third-floor hoses increase backpressure. The pressure switch then toggles rapidly, creating heat and current spikes. Use adequate hose ID and flow so the pump runs steadily without chatter. [Elektroda, Ed Thompson, post #21663747]
What is duty cycle and why does it matter for these pumps?
Duty cycle is the percentage of time a pump can run without overheating. Many RV-style units are not 100% duty. If your sprayer runs continuously, choose a higher-flow, fan‑cooled, or 100% duty model to avoid burnout. [Elektroda, Chuck Sydlo, post #21663750]
Are my pumps overheating?
Check the pump surface temperature during use. The maker guidance cited is to keep it under 180°F. If it’s hot to the touch or cycling, upgrade to a model with better cooling or more flow to reduce runtime. [Elektroda, Chuck Sydlo, post #21663750]
Could thick fluids or blockages be the reason?
Yes. Thickened liquids, a clogged inlet filter, or a too‑high outlet restriction slow the pump, raising current. Consider a lower pressure switch setting and verify inlet/outlet paths are clear to restore speed and cut draw. [Elektroda, Peter Evenhuis, post #21663744]
How do I measure what the pump really draws under load?
Put an ammeter in series with the pump during real spraying. Log current while operating. Compare to the maker’s heat‑rise graph; ~13A continuous is indicated as sustainable when within thermal limits. Add a pressure gauge if chemicals allow. [Elektroda, Frank Bushnell, post #21663753]
Can chlorine mixes void warranties or damage parts?
Yes. Users report chlorine attacking valves and internals, leading to overload and overheating. Choose chemical-rated agricultural sprayer pumps and compatible plumbing to handle chlorine blends safely and reliably. [Elektroda, Peter Evenhuis, post #21663752]
Will a bigger pump help stop cycling and fuse blows?
Often yes. A higher‑GPM, longer‑duty pump can build pressure, then shut off periodically, running cooler. Even a 10% off-time reduces heat and stress on fuses and windings during long jobs. [Elektroda, Chuck Sydlo, post #21663750]
How high can this pump push fluid?
The referenced line lists 100 psi maximum. Convert your elevation head and flow needs accordingly. If you routinely spray to second or third floors, select a pump rated for that head with chemical compatibility. [Elektroda, Frank Bushnell, post #21663753]
Could wiring or power supply be part of the problem?
Yes. Long runs, poor crimps, or undersized wire increase voltage drop and current. Keep runs short, use fine‑strand cable and proper crimped terminals, and verify battery voltage under load, not just at rest. [Elektroda, Ed Thompson, post #21663747]
What’s a pressure switch and why does it chatter?
A pressure switch turns the pump off at a set pressure. If your nozzles are too small or head is high, pressure toggles around the setpoint, causing rapid cycling. A lower switch setting can stabilize flow. [Elektroda, Peter Evenhuis, post #21663744]
Do these marine/RV pumps suit commercial roof cleaning?
They can work, but frequent, long-duty spraying exceeds their design intent. For daily chemical use and height, choose ag‑rated chemical pumps with cooling, thermal protection, and the required head. [Elektroda, Peter Evenhuis, post #21663752]
Any tell‑tale edge cases I should check first?
Look for a partially stuck check/valve from chemical attack. One bad valve raises load; two can overheat the pump fast without protection. Replace damaged valves and flush lines after chlorine use. [Elektroda, Peter Evenhuis, post #21663752]
What battery numbers should I expect during operation?
Healthy systems showed 12.2–12.8V at rest in field reports. Measure voltage under load to catch drop issues that raise current and heat. Upgrade cabling or batteries if loaded voltage sags excessively. [Elektroda, Ed Thompson, post #21663747]
How do I do a quick 3‑step test to stop blowing fuses?
  1. Measure current with an inline ammeter while spraying a typical job.
  2. Swap to larger nozzles or lower the pressure switch to end rapid cycling.
  3. Verify inlet filter, hose ID, and wiring gauge/length; retest current and temperature. [Elektroda, Frank Bushnell, post #21663753]
