Submersible Pump from Grudziądz Blows 7 Amp Fuse After Few Seconds of Operation
MIREK555 47375 16
Why does my submersible pump trip the 7 A fuse in the control unit after a few seconds of running, and how can I check whether the pump can be repaired without pulling it up first?
Check the pump’s insulation resistance first with a proper 500 V insulation tester; if it is OK, the likely cause is a blocked/seized impeller or the pump sucking in mud [#9353479][#9745366][#9745966] Also inspect the control board, phase switching/contactor contacts, cable continuity, and any residual-current or dry-run protection, and measure the starting currents of all three phases [#9358002][#9358563] A simple multimeter reading of a few ohms on the windings is not conclusive at this low resistance, because lead/contact resistance can add 1–2 Ω and distort the result [#9745944][#9751492] If the pump had been run dry or lowered too deep, it may have seized or ingested silt, which would explain the fuse blowing after a short time [#9353479][#9358563][#9745366]
  • #1 9353435
    MIREK555
    Rate: 24
    Hello. After a few months of not using the submersible pump, a problem appeared. It throws the fuse in the control device after a few seconds of operation. Phases checked, I swapped the wires for a moment, it will work for a while and nothing ... The control board has a 7 amp fuse. The pump was manufactured in Grudziądz, there are 8 or 9 step, the well is 40 meters deep. Does anyone have any way to get this device to work again?
  • #2 9353479
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    First of all, check the INSULATION resistance of this pump! If it's ok, then the impeller is blocked. There will be no pulling out :cry:
  • #3 9353728
    MIREK555
    Rate: 24
    Well, the worst thing is to pull ... - at the top, I can handle it. Have any of you managed to solve it in another way? Recently, after a short break in use, it dumped some dirty water on me, and today not a drop :cry:
  • #4 9354170
    retrofood
    Help: 1140
    Rate: 4800
    I guess you can do these measurements on the power supply without removing it, right?
  • #5 9355752
    MIREK555
    Rate: 24
    I would like to ask for tips on what to measure with and what values are to be displayed. Thank you in advance. Unfortunately, I do not know what power this pump is, I only remember that it is 8 or 9-stage.
  • #6 9356156
    sebol133
    Help: 13
    Rate: 21
    Well, at least write what power this pump is, then we will know how much electricity it should consume
    You don't provide enough information, nobody here is a fortune teller
  • #7 9356442
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    MIREK555 wrote:
    I would like to ask for tips on what to measure and what values should be shown.
    And does your friend have a meter to measure the insulation resistance (even a 500V inductor) and know how to use it?
    Anticipating the answer - it's not about the multimeter ...
  • #8 9356521
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Akrzy74_Let him first measure this insulation resistance with a multimeter, due to the nature of the motor - the windings work in water, so the breakdown will be detected even with a small ohmmeter voltage.
  • #9 9356701
    k3048
    Level 37  
    Help: 515
    Rate: 281
    Are you sure she's in the water? What kind of control device is it, type of pump
    and motor, how deep submerged, did you measure depression, motor insulation condition, where this pump is running. And it's best before pulling it out (without which it probably won't happen) ask someone to check what it has to do with the depths
  • #10 9358002
    wola
    Help: 65
    Rate: 184
    Hello. Write something more about the "control board" (maybe a clear picture). I'm guessing that it turns off the overload trip (thermal switch), but it's just guesswork. It's hard to say whether the pump is still operational, but if you turn it on mindlessly, it will definitely not be operational.
    Phases checked
    How was it checked? Does this mean that the entire "control board" has also been checked for the patency of the current circuits. Is it off pressure switch and whether it controls the contactor or switches on the phases for the pump; if it switches on the phases, what is the state of its contacts. Are the wires to the pump uninterrupted (this can be checked with an "ordinary" ohmic meter) residual current device (If there is this switch in the installation, does its switching off cause the lack of voltage to power the pump?).
  • #11 9358563
    cranky
    Level 30  
    Help: 70
    Rate: 416
    Exactly.
    1 Check with an ammeter the starting currents of each of the 3 phases!
    2 Check the resistance of the windings with the wires with an ohmmeter.
    3 How many wires go to the pump and is there a differential?
    4 Is there water in the well? Is there protection against dry running (maybe it ran dry until it seized up?)
    PS To fellow "professionals":
    The dry-running submersible pump consumes less current - so it does not throw out the protection
    Grudziądz submersible pump with insulation resistance of 80 A up to 60 kohm it will work and won't trip the protections (unless it's an RCD). It won't kill the fish in the well either.
  • 4-ohm winding measurement and request for damage check
    #12 9745366
    MIREK555
    Rate: 24
    Hello, I'm back to this topic after a long break. The pump was excavated, desilted, checked on the surface for operation /-water trough/ and re-submerged. Unfortunately, the specialist lowered it too low and sucked in the mud and ... was extracted again. Measured with a meter on the windings - resistance 4 ohms. I'm afraid she might have gotten too much in the ass after those launch attempts. Motor power 5.5 KW. Is it possible to quickly check if nothing electrically serious has happened to it?/-power drop/. I no longer have the strength or the nerves to pull her up again.
  • #13 9745407
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    A resistance of 4 ohms between the windings is a short circuit. A meter to measure the winding resistance and the correct measurement.
  • Electrician finds 4 ohms acceptable, recommends winding insulation test
    #14 9745944
    MIREK555
    Rate: 24
    I just got back from the electrician /-rewinds motors/ he said that the result of 4 ohms on the multimeter is a bit too high - it should be 2-3 ohms, but it is within normal limits. So I don't understand what's going on... The engine starts and works normally /-immersed in water/ my concern is whether it will be able to lift the water column up with sufficient force. He also ordered to check the individual windings with 220V current for a short-circuit with ground. But before I do that, I'd rather wait for your feedback.
  • #15 9745966
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    I wrote about this only the measurement of "winding short-circuit to ground" is performed with at least a 500V inductor.
  • Four-ohm winding reading may reflect measurement error
    #16 9751492
    krzysiek7
    Moderator of Electricians group
    Help: 678
    Rate: 1953
    You can indicate where MIREK555 did he write that?
    My friend MIREK555 , these 4Ω at this motor power is a bit too much, but the problem lies in the measurement itself, not in the actual winding resistance. Measurement with a multimeter of such small resistances is burdened with a considerable error. Even dirty test lead plugs will give you 1 or 2 ohms.
    Then why didn't you give him the pump to check?
  • #17 9752925
    MIREK555
    Rate: 24
    A trip with a pump to an electrician is about 100 km away for me plus arranging transport. This device weighs a lot so before I do anything I try to orient myself to make the right decision. I was thinking about sinking it back into the trough by screwing in the flow reduction - somewhere by half. Thanks to this, I would create similar conditions for it to work in every day?
The discussion revolves around a submersible pump manufactured in Grudziądz that blows a 7 amp fuse shortly after operation begins. The user reports that after a period of inactivity, the pump fails to operate correctly, leading to fuse failure. Participants suggest checking the insulation resistance of the pump, as well as the condition of the impeller and control board. They emphasize the importance of measuring the pump's electrical parameters, including starting currents and winding resistance, to diagnose potential issues. The user later discovers a resistance of 4 ohms in the windings, which raises concerns about the pump's ability to function effectively. Suggestions include verifying the pump's operational conditions and considering the impact of mud intake during operation.
