I have happened upon a Solargizer, which, from my understanding is a solar battery charger. For those unfamiliar with this item, I will describe it....It is one solar panel that is 4.5"x 5.5". It has 2 wires, one black and one red, coming from the panel and going to a small black box, which I do not know what it does, but I am sure that someone here does. Two other wires then leave the black box and have attachemnt points, basically washers, on the end. This device is found by searching, "Solargizer IS-24-L 735x150". It is commonly sold to the US military for charging 24v batteries on HMMVWs. Ok...so here is what I want to do. I want to be able to use this thing, assuming it works. I have also acquire d a 12V 8Ah AGM cell battery that is common for RC cars. It is manufactured by Power Patrol batteries and has the product #RCE1250. It has two connections on the top, one positive and one ground I assume- is this correct? From my research on the Solargizer I have discovered it has a small red light on top of the black box that indicates that it is charging. I have connected the battery to the connections from the Solargizer (Connected simply by touching/crimp). When placing the whole system in direct sunlight, I did not see the red light and assume the battery was not charging. I do not even know where to begin on assessing where I may be wrong, but I was hoping that someone would be able to help me out. GOAL: I would like to be able to charge the 12v battery and eventually hook it up to a 120ac inverter in order to charge small electronics. I am aware that I will get all sorts of responses being that this is the internet, but I assume that in a professional forum, I will get professional responses. I am willing to try nearly anything to get this to work or to troubleshoot the problem. I have attached a picture of the setup and below is the key for that. Thank you for taking the time to look at this and assess the problem(s). A-SMALL BLACK SOLARGIZER BOX. HAS "SOLARGIZER BATTERY MAINTENANCE SYSTEM" WRITTEN ON OUTSIDE. B-12V AGM CELL POWER PATROL BATTERY. READS "SEALED AGM MAINTENANCE FREE RECHARGEABLE BATTERY" IT IS A BRAND NEW BATTERY AND HAS NOT BEEN USED. C-SMALL SOLAR PANEL DESCRIBE ABOVE. PART OF SOLARGIZER SYSTEM.
Alexander Day
Alexander Day
