H-Bridge Circuit Operation: Why Do Some Transistors Saturate While Others Cut Off?
447 16
How does this H-bridge make one transistor conduct while the other cuts off, and do the transistors really saturate?
The bridge works by using each input to pull one transistor pair’s bases high or low through Q5 and the resistors, so one device in each side is driven on while its complement is driven off [#21663924] In this type of switching circuit, a transistor is considered on when its base-emitter junction is forward biased by about 0.7 V with the correct polarity, and off when that condition is not met [#21663924] However, in this particular arrangement Steve later notes that none of the transistors can actually reach true saturation, because the emitter can only move about 0.6–0.7 V relative to the base, so the circuit settles at an equilibrium point instead of behaving like an ideal switch [#21663936] The reason for biasing switching transistors this way is to avoid the active region, since a half-on transistor wastes power as heat, while even a fully on transistor still has some Vce(sat) drop [#21663926][#21663933] For large currents, the advice in the thread is to check the datasheet’s Vce(sat) and Ptot, and consider MOSFETs instead of bipolars [#21663933]
  • #1 21663922
    wiki Saf
  • #2 21663923
    Peter Evenhuis
  • BJT switch logic explains H-bridge states
    #3 21663924
    Dorin Dragan
  • #4 21663925
    Steve Lawson
  • Why switching transistors should avoid the active region
    #5 21663926
    Steve Lawson
  • #6 21663927
    Steve Lawson
  • IGBTs and chopper drives as lower-loss alternatives
    #7 21663928
    Jan Faerie
  • #8 21663929
    Jan Faerie
  • Use datasheet Vce(sat) and Ptot to size transistors
    #9 21663930
    Steve Lawson
  • Clarifying PNP saturation and base-emitter voltage
    #10 21663931
    wiki Saf
  • #11 21663932
    wiki Saf
  • MOSFETs dissipate less heat than bipolar switches
    #12 21663933
    Steve Lawson
  • #13 21663934
    Steve Lawson
  • Why Q1 cannot satisfy both junction biases
    #14 21663935
    wiki Saf
  • Emitter follower limits prevent transistor saturation
    #15 21663936
    Steve Lawson
  • Complementary push-pull bipolars avoid saturation in MOSFET gate drive
    #16 21663937
    Steve Lawson
  • #17 21663938
    Steve Lawson
The discussion explains the operation of an H-bridge circuit focusing on why some transistors saturate while others cut off. Bipolar junction transistors (BJTs) in the H-bridge act as switches: a transistor saturates (fully on) when the base-emitter voltage exceeds approximately 0.7 V with correct polarity, and cuts off (off) otherwise. The top transistors (PNP) conduct when driven by a positive signal, while the bottom transistors (NPN) conduct when connected to ground. The circuit uses complementary pairs where one transistor in a pair saturates while the other cuts off, controlled by input signals pulling bases high or low through resistors and intermediate transistors. Saturation is desired to minimize power dissipation in the transistor, as partial conduction (active region) causes voltage drop and heat. However, in some H-bridge designs, transistors may not reach full saturation due to voltage limitations at emitter and collector junctions, resulting in a compromise between simplicity and efficiency. The discussion also covers the thermal implications of switching transistors, suggesting that MOSFETs are often preferred for high current applications due to their low on-resistance and better efficiency, while IGBTs are suitable for high voltage scenarios. The importance of consulting datasheets for saturation voltage (Vce(sat)) and power dissipation (Ptot) is emphasized. Additional points include the forward biasing of both emitter-base and collector-base junctions for saturation, and the practical observation that in some circuits, transistors never fully saturate but operate near an equilibrium point. The use of complementary push-pull bipolar transistors is also noted for driving MOSFET gates efficiently, where full saturation is less critical for switching speed.
TL;DR: In this BJT H‑bridge, V_BE ≈ 0.7 V, and—as one expert put it—"treat transistors as switches" to see which devices conduct or cut off for each input. In this specific schematic the BJTs don’t actually reach saturation, impacting efficiency. [Elektroda, Dorin Dragan, post #21663924]
Why it matters: This FAQ helps beginners diagnose H‑bridge behavior, reduce heat, and choose BJTs vs MOSFETs for motor drivers.
How does this BJT H‑bridge decide which transistors turn on or off?
Model each BJT as a switch. If the base‑emitter junction is forward‑biased by about 0.7 V with the correct polarity, it turns on. With input A high, Q5 pulls the bases of Q1/Q2 low, turning Q2 on and Q1 off. With A low, R1 pulls bases high, turning Q1 on and Q2 off. The other half mirrors this. [Elektroda, Dorin Dragan, post #21663924]
Do the transistors in this specific schematic actually reach saturation?
No. In this arrangement, the emitters cannot rise or fall beyond about 0.6–0.7 V from their bases. That constraint prevents true saturation, so devices sit just out of saturation. It simplifies drive but wastes power compared with a fully saturated switch stage. [Elektroda, Steve Lawson, post #21663936]
Why avoid the active region in switching?
When a transistor sits half‑on, it drops significant voltage at substantial current. That dissipates power as heat instead of delivering it to the load. Biasing for hard on (near saturation) or hard off minimizes loss and keeps devices cooler. [Elektroda, Steve Lawson, post #21663926]
How can I estimate heat in a saturated BJT leg?
Use the datasheet’s V_CE(sat) and your load current: P ≈ V_CE(sat) × I. Then compare the result with the device’s P_tot rating. If P exceeds safe limits, add a heatsink or pick a device with higher ratings. [Elektroda, Steve Lawson, post #21663930]
Why can V_BE be ~0.7 V while V_CE(sat) is only ~0.1 V?
The base‑emitter junction is forward‑biased near 0.7 V, while the collector‑base junction is reverse‑biased in normal operation. That allows V_CE to be very small at saturation, sometimes around 0.1 V for devices like PN2222A. [Elektroda, Steve Lawson, post #21663934]
What determines top versus bottom device conduction (PNP vs NPN)?
Top PNP devices conduct when their bases are driven lower relative to their emitters (toward ground). Bottom NPN devices conduct when their bases are driven higher relative to their emitters (toward V+ return). The arrow on the symbol hints at required polarity. [Elektroda, Peter Evenhuis, post #21663923]
How do I reduce overheating in a motor H‑bridge?
Start with calculations: use V_CE(sat) and current for BJTs or R_DS(on) and I² for MOSFETs. Compare with thermal limits (P_tot, θJA/θJC) and add heatsinking. For high currents, MOSFETs often run cooler when properly driven. [Elektroda, Steve Lawson, post #21663930]
Should I oversize BJTs to avoid heatsinks?
Only if power calculations plus thermal resistance show safe junction temperatures. Oversizing helps margin, but verify with P_tot and V_CE(sat) at your current. Always validate against the datasheet and real measurements. [Elektroda, Steve Lawson, post #21663930]
Are MOSFETs actually lower loss than BJTs here?
Yes for high current stages. MOSFETs behave resistively and can achieve milli‑ohm R_DS(on), so I²R loss stays low. That translates to less heat than a BJT dropping a fixed V_CE(sat) at the same current. [Elektroda, Steve Lawson, post #21663933]
Are IGBTs a better switch for my DC motor H‑bridge?
Use IGBTs mainly at higher voltages. For typical low‑voltage DC motors, MOSFETs are preferred due to low R_DS(on) and easier gate drive. Always align the device with your bus voltage and current. [Elektroda, Steve Lawson, post #21663930]
Why might this complementary BJT stage be chosen despite lower efficiency?
It cuts complexity and cost. Not driving devices into deep saturation can also improve switching speed, which is helpful for driving MOSFET gates or light loads. It’s a simplicity–efficiency trade‑off. [Elektroda, Steve Lawson, post #21663937]
How do pull‑ups and the Q5 transistor influence base drive?
With input A high, Q5 pulls the bases of Q1/Q2 low more strongly than the pull‑up. That turns the appropriate device on and the other off. With input A low, the pull‑up biases the opposite state. Repeat symmetrically for the other half‑bridge. [Elektroda, Dorin Dragan, post #21663924]
Quick 3‑step: How can I trace current for each input state?
  1. Treat each BJT as a switch with ~0.7 V base‑emitter threshold.
  2. Set A/B high or low, then note which bases go low or high via Q5/pull‑ups.
  3. Mark ON devices and follow the supply‑to‑ground path through the motor. [Elektroda, Dorin Dragan, post #21663924]
Can a switching BJT still get hot when used “correctly”?
Yes. Even fully on, a BJT drops some voltage, so it dissipates power as heat. “There is still a voltage drop and thus a power loss,” especially at higher currents. Ensure thermal design and margins. [Elektroda, Steve Lawson, post #21663933]
