Development and Control of a Two-wheeled Inverted Pendulum Robot
288 10
How can I get started quickly designing, building, and controlling a two-wheeled inverted pendulum robot with little background in electronics or control systems?
Start with an existing open-source balancing robot design instead of trying to invent everything from scratch. The Elektor OSPV1 project includes an article, open software, and an optional complete hardware set you can buy and modify [#21663955][#21663957] As a control reference, look at the Microchip application note linked in the thread [#21663959] If you want the simplest possible proof of concept, one reply suggests a 555 timer with CDS cells, and notes that an analog design can avoid using a microcontroller; the posted explanation also mentions using AC light-tube pulsing in the sensing circuit [#21663961][#21663962] It may also help to team up with an electrical engineering student so the electronics and control parts are covered alongside the mechanical work [#21663958]
  • Requesting guidance on inverted pendulum robot design
    #1 21663954
    Ella Ross
  • #2 21663955
    Peter Evenhuis
  • #3 21663956
    Ella Ross
  • #5 21663958
    Steve Lawson
  • #7 21663960
    Peter Evenhuis
  • #8 21663961
    Brian German
  • #10 21663963
    Brian German
  • #11 21663964
    Steve Lawson
A Mechanical Engineering student seeks guidance on designing, building, and controlling a two-wheeled inverted pendulum robot with limited knowledge in electrical engineering and control systems. Responses suggest leveraging open-source projects such as the Elektor magazine's open source hardware and software platform for inverted pendulum robots, which provides schematics and control code that can be modified. Collaboration with electrical engineering students is recommended to address control system challenges. Additional resources include a Microchip application note on balancing robots and a simple analog balancing robot design using a 555 timer and CDS cells, which avoids microcontroller complexity. The analog design employs AC light tube pulsing for electronic control. Discussions also consider mechanical approaches like driving two servos in parallel, though questions arise about the balancing mechanism and the role of wheel radius and body weight distribution in stability.
