How to Adjust Common Emitter Amplifier for Temperature Drift in Audio Circuits?
318 8
  • #1 21664313
    jeff Cheng
  • Thermal test to isolate drifting transistor stage
    #2 21664314
    Earl Albin
  • Thermal oven or coupled transistors to reduce drift
    #3 21664315
    Steve Lawson
  • Opamp source current drops faster with temperature
    #4 21664316
    Todd Hayden
  • #5 21664317
    Earl Albin
  • Opamp output asymmetry likely causes temperature drift
    #6 21664318
    Todd Hayden
  • Suggests measurement verification and cascading stages to reduce error
    #7 21664319
    Earl Albin
  • #8 21664320
    DAVID CUTHBERT
  • #9 21664321
    DAVID CUTHBERT
The discussion addresses temperature drift issues in a common emitter amplifier used in audio circuits, where two output voltages drift differently with temperature changes. It is suggested to experimentally isolate the temperature effects on individual components—NPN transistor, PNP transistor, and opamp—by selectively heating each and observing drift behavior. Using matched NPN/PNP transistors, preferably monolithic pairs or thermally coupled devices, can help synchronize temperature responses. The opamp, configured as voltage followers, contributes significantly to drift due to its input offset voltage temperature coefficient (typical 1µV/°C, max 5µV/°C) and asymmetric sourcing/sinking current capabilities that vary with temperature. The OP295 opamp datasheet indicates output current sourcing capability degrades faster with temperature than sinking in single supply mode, potentially causing unequal drift on high and low sides. Thermal coupling of transistors via heatsink compound and physical contact is recommended to equalize temperature. Stabilizing the circuit in a temperature-controlled environment ("oven") with a resistor heater and thermistor feedback can minimize drift. The amplifier gain (~1000) and feedback diode presence may also influence DC offset and drift. Overall, the dominant temperature coefficient arises from the opamp's input offset voltage and its asymmetric output stage behavior under temperature variations.
