What is the name for an electronically controlled pin grid array like Pin Art toy?
276 12
What is the name for an electronically controlled grid of pins that can move individual pins up and down like a Pin Art toy?
There isn’t a standard off-the-shelf part for a dense electronically controlled pin grid like that; it would usually be a custom array of solenoids or linear actuators [#21664326][#21664328] Solenoids were described as iron pins moved by an electromagnet, but packing hundreds of them closely together is difficult because they interfere with one another [#21664326] One alternative suggested was a compressed-air design: a drilled block with individual tubes and solenoid valves, so the control hardware can sit away from the pin array [#21664329] For control electronics, a rolling LED dot-matrix sign or a braille-printer-style mechanism might be adapted [#21664331][#21664334] Other ideas mentioned were nitinol memory-wire coils and electroactive polymers, but these were presented as experimental alternatives rather than a named standard module [#21664333]
  • Seeking name for compact electronically controlled pin grid
    #1 21664325
    Mike W
  • Custom solenoid array needed for pin grid display
    #2 21664326
    Boi Okken
  • #3 21664327
    Mike W
  • #4 21664328
    Steve Lawson
  • Compressed air and solenoid valves for needle array
    #5 21664329
    Sarah Harris
  • #6 21664330
    Mike W
  • #8 21664332
    Mike W
  • Nitinol memory wire coils as actuator option
    #9 21664333
    Steve Lawson
  • #10 21664334
    Per Zackrisson
  • #11 21664335
    Mike W
The discussion centers on identifying or creating a compact electronic device capable of individually moving hundreds of pins arranged in a dense grid, similar to the Pin Art toy or Hyundai's dynamic wall installations. No off-the-shelf component exists for this specific function. Suggested solutions include arrays of solenoids (electromagnetic coils) to actuate pins, though challenges arise from size constraints and electromagnetic interference. Alternative actuation methods proposed are linear actuators, bimetallic strips that bend when heated by current, compressed air systems controlled by solenoid valves, and nitinol shape memory wire coils that contract when electrified. Braille printers were noted as a related technology due to their dot-punching mechanisms, and electroactive polymers were mentioned as a potential advanced material for actuation. Ready-made controllers, such as those used in LED dot matrix signs, could be adapted for controlling solenoid arrays. Rapid prototyping approaches and digitally reconfigurable molds were also referenced as possible development aids. The overall consensus is that a custom solution integrating multiple technologies and control hardware/software is necessary for such a device.
TL;DR: You’re chasing a tiny, electronically controlled pin grid with “a high number of pins (hundreds), closely packed.” [Elektroda, Mike W, post #21664325]
Why it matters: This FAQ helps makers and engineers name the concept, pick actuators, and avoid common pitfalls when building a pin‑matrix display.
What is this electronically controlled Pin Art–style grid actually called?
There isn’t a standard off‑the‑shelf “pin‑grid” component. Builders assemble arrays using actuators like solenoids or other linear drives. [Elektroda, Boi Okken, post #21664326]
Is there a generic term for the up/down motion I should search for?
Yes—search for a linear actuator. “Another term for a device that moves this way is ‘linear actuator’.” [Elektroda, Steve Lawson, post #21664328]
Can I use solenoids to move each pin?
Yes. A solenoid is an electromagnet that moves an iron pin up or down. Dense packing risks magnetic coupling, so add spacing or shielding. [Elektroda, Boi Okken, post #21664326]
Will tightly packed solenoids cause problems?
Yes. When solenoids sit too close, their fields interact and reduce control accuracy. Design for spacing or alternate actuation paths. [Elektroda, Boi Okken, post #21664326]
Could compressed air drive the pins instead of magnets?
Yes. Use a drilled manifold block, one hose per pin, and control airflow with solenoid valves. “My preferred method would be compressed air.” [Elektroda, Sarah Harris, post #21664329]
Is there a ready-made controller for beginners?
A rolling LED dot‑matrix sign controller can be repurposed to switch valves or coils, reducing firmware work for novices. [Elektroda, Sarah Harris, post #21664331]
What about shape-memory alloy (Nitinol) wires for actuation?
You can wind Nitinol coils around cylinders; current heats the wire, it contracts, and pulls the pin. Include cooling time in your cycle. [Elektroda, Steve Lawson, post #21664333]
How durable is Nitinol for repeated pin motion?
Durability was raised as a concern; plan life‑cycle tests and consider replacement access if wires lose stroke over time. [Elektroda, Mike W, post #21664335]
Is there a product that bundles many solenoid valves for pneumatics?
The thread suggests pneumatic control via solenoid valves and hoses; look for manifolded valve banks when sourcing parts. [Elektroda, Sarah Harris, post #21664329]
Any reference project for a reconfigurable pin surface?
See the shared link to a digitally reconfigurable mold; it demonstrates vertically actuated pins for rapid prototyping. [Elektroda, sarosh Mehta, post #21664336]
What inspired this idea and scale?
The Pin Art toy and Hyundai’s moving‑block wall inspired a compact grid with “hundreds” of closely packed, individually driven pins. [Elektroda, Mike W, post #21664325]
How do I prototype a small pneumatic column quickly?
  1. Drill a tight guide bore for one pin and fit a seal.
  2. Plumb a small hose to the bore through a solenoid valve.
  3. Use a simple controller to pulse air for up/down actuation. [Elektroda, Sarah Harris, post #21664329]
What is a solenoid in this context?
A solenoid is a coil that creates a magnetic field to move an iron plunger linearly, ideal for simple up/down pin motion. [Elektroda, Boi Okken, post #21664326]
What failure modes should I plan for?
Expect magnetic interference in dense coils, thermal fatigue in Nitinol, and air leaks in pneumatics. Include isolation and testing. [Elektroda, Boi Okken, post #21664326]
