Best Actuation Mechanism for Palm-Sized Dynamic Shape Display With 1000+ Linear Actuators
456 14
How can I build a palm-sized portable dynamic shape display with 1000+ closely packed linear actuators?
A practical suggestion is shape-memory alloy wire, such as Flexinol or Nitinol, where current heats the wire so it contracts and a spring returns it to the starting position, with control done by a BJT or FET; however, the thread warns that it may still be too power-hungry and difficult for 1000+ dense actuators in a laptop- or palm-sized device [#21679039] [#21679044] Flexinol is described as pre-formed and shrinking about 6–8%, while the wire resistance is typically 6–10 ohms, so at 5 V it can draw roughly 0.5 A to 0.833 A per actuator, though pulsing or PWM could reduce average power [#21679044] Nitinol was also mentioned, but it must be formed at up to 300 °C and then returns to its original shape when heated to about 20–40 °C, which adds more thermal complexity [#21679044] Other ideas were a single actuator on an X-Y positioner to sequentially push each pin, or a threaded-rod/vibration-driven pin array, but those were also judged too slow or too large for real-time operation [#21679036] [#21679046] One reply suggested latching actuators after movement to cut average current, and another mentioned air pressure or miniature balloons, but no concrete low-power dense implementation was given [#21679045] The overall conclusion was that the required size and density are likely beyond currently practical technology, especially if the shape must change in real time [#21679048]
  • Requesting actuator mechanism ideas for 1000-unit palm-sized display
    #1 21679035
    Muhammad Umair Khan
  • X-y positioner or threaded rod actuation idea
    #2 21679036
    David Ashton
  • Seeking a DIY alternative to squiggle motors
    #3 21679037
    Muhammad Umair Khan
  • Dot-matrix printhead analogy for actuator spacing limits
    #4 21679038
    David Ashton
  • Flexinol muscle wire as compact actuator option
    #5 21679039
    Mike P OKeeffe
  • #6 21679040
    Rick Curl
  • #7 21679041
    Muhammad Umair Khan
  • #8 21679042
    Muhammad Umair Khan
  • #9 21679043
    Muhammad Umair Khan
  • SMA wire resistance and drive current requirements
    #10 21679044
    Mike P OKeeffe
  • Latching actuators or air pressure to cut current
    #11 21679045
    Elizabeth Simon
  • Vibration-driven threaded pins and CNC-style array suggestion
    #12 21679046
    Adam Wilkinson
  • #13 21679047
    Muhammad Umair Khan
  • #14 21679048
    Adam Wilkinson
  • Magnetic actuator concept limited by volume scaling
    #15 21679049
    Adam Wilkinson
The discussion centers on designing a palm-sized dynamic shape display composed of over 1000 linear actuators within a strict size constraint comparable to a laptop or smaller. Conventional linear actuators are deemed too large and insufficiently dense for this application. Alternative actuation mechanisms considered include using a single linear actuator on an X-Y positioning system to sequentially adjust rods, or employing threaded rods with a rotating driver. Shape Memory Alloys (SMAs) such as Flexinol and Nitinol muscle wires are proposed as compact actuators; these contract upon electrical heating but present challenges including high current draw, thermal management, and control complexity. Flexinol is noted as expensive, while Nitinol is more affordable but requires forming at high temperatures and careful control via PWM and transistor switching. Other suggestions include miniature solenoids, electromagnetic surfaces, pneumatic micro-balloons, and vibration-driven threaded pins inspired by MIT's inForm project. However, real-time shape change demands and power constraints limit feasibility. Emerging technologies like carbon nanotube actuators and electromagnetic artificial muscles are mentioned but are currently not scalable or mature enough for the required density and size. Overall, current technology is insufficient for a compact, high-density dynamic shape display with 1000+ actuators, and significant innovation or future advancements are needed.
TL;DR: For a palm‑sized 3D pin array, SMA wires offer ~6–8% stroke, but each needs ~0.5–0.83 A at 5 V and, as one expert warns, “not really sure if it is suitable.” [Elektroda, Anonymous, post #21679044]
Why it matters: Makers asking “what’s the best tiny actuator for 1000+ pins?” get realistic options, limits, and control tips for portable builds.
What actuation mechanism best fits a palm-sized dynamic shape display with 1,000+ pins?
Direct one‑motor‑per‑pin is too dense. A practical route is one linear actuator on an X‑Y stage that visits each pin, or threaded rods driven by a rotating “screwdriver.” This trades density for complexity and time, but fits tight spacing better. [Elektroda, Anonymous, post #21679036]
Can shape memory alloys (SMA) like Nitinol or Flexinol drive tiny linear actuators?
Yes. SMA wires shrink when heated by current and can pull against a return spring. They enable very small actuators but require careful power and thermal design due to heat and current needs. “Another muscle wire is Nitinol.” [Elektroda, Anonymous, post #21679039]
How much stroke do SMA wires provide and how do I drive them?
Flexinol‑type SMA shortens about 6–8%. Drive it with PWM through a transistor switch, watching FET RdsOn to avoid heating the switch. Typical wire resistance is ~6–10 Ω; at 5 V that’s ~0.5–0.83 A. [Elektroda, Anonymous, post #21679044]
Will SMA overheat a compact, palm-sized array?
It can. The wire’s operating temperature can soften or melt nearby plastics. Use high‑temperature plastics, thermal spacing, and duty‑cycle limits. Otherwise pins may deform or seize under continuous drive. [Elektroda, Anonymous, post #21679039]
How can I reduce power draw for a battery‑portable device?
Move pins, then latch them mechanically so current can drop to near zero. Without latching, holding force wastes power. One contributor suggested latching and also floated miniature pneumatic “balloons” to cut steady current. [Elektroda, Anonymous, post #21679045]
Could air pressure or soft actuators work at this scale?
Possibly, using tiny inflatable cells to raise pins. This shifts power from electrical hold to intermittent pneumatic pumping. The challenge is micro‑scale fabrication and airtightness across a dense grid. [Elektroda, Anonymous, post #21679045]
Is a vibration-driven threaded-pin array fast enough for real-time shapes?
Usually not. With sparse actuators stepping across many pins, full refresh can take about a minute, which misses real‑time goals for interactive surfaces. This approach favors low motor count over speed. [Elektroda, Anonymous, post #21679046]
Are carbon nanotube actuators a near-term solution?
No. As one expert put it, the “technology you need is 10, or maybe 20 years away.” They are promising but not ready for dense, palm‑sized arrays today. [Elektroda, Anonymous, post #21679048]
What physical size constraints did the OP confirm?
The complete mechanism must be no bigger than a laptop, with a preferred palm‑sized form factor. That constraint rules out large, off‑module drive systems. [Elektroda, Anonymous, post #21679041]
Are off‑the‑shelf micro linear actuators dense enough for 1,000+ pins?
Unlikely. The spacing between rods leaves little room for dedicated actuators. That’s why proposals favor shared actuators or threaded engagement rather than one motor per pin. [Elektroda, Anonymous, post #21679036]
How do I control Nitinol from a microcontroller?
Switch the wire with a transistor (BJT or FET) and modulate current using PWM. Mind the FET’s RdsOn, or the switch wastes power and limits heating. A spring provides return motion once current drops. [Elektroda, Anonymous, post #21679044]
3-step: build a single SMA pin actuator with spring return
  1. Preform/install SMA wire in a short, straight path with a light compression spring for return.
  2. Drive wire via a low-side transistor and PWM until desired retraction occurs.
  3. Cut current; let the spring extend the pin as the wire cools. [Elektroda, Anonymous, post #21679044]
What’s a realistic per‑pin power budget if I use SMA at 5 V?
Using 6–10 Ω wire, current is ~0.5–0.83 A and power is ~2.5–4.2 W during heating. Duty cycle and multiplexing reduce average draw, but peak demands are substantial. [Elektroda, Anonymous, post #21679044]
Could a CNC-style toolhead set pin heights instead of 1,000 motors?
Yes. One actuator can visit pins across X‑Y, pressing or screwing each to height. It suits tight grids but increases refresh time and mechanical complexity. [Elektroda, Anonymous, post #21679036]
Any encouragement or caution from engineers who tried similar builds?
Expect density and drive challenges. As one respondent joked, “you’ll make a fortune!” if you solve packing and control at this scale. Plan for heat, current, and latching. [Elektroda, Anonymous, post #21679038]
