Powering 6 Cameras (12V 150mA) & LCDs (12V 200mA) Safely From One Adapter?
270 14
Can I power six 12V cameras and their LCDs from one adapter, and if so how do I size and wire the supply safely?
Yes—wire all six camera/LCD pairs in parallel to one regulated 12V supply sized for the total load, which is about 2.1A, so a 2.5A or larger adapter is a safe choice [#21664356][#21664360] There is no need to “regulate amperage” per device; each load draws the current it needs as long as the supply can provide enough total current [#21664356] The 12V 350mA adapters are far too small for this setup, and a higher-current supply is fine if it is properly regulated [#21664355][#21664360] Because long cable runs can cause voltage drop, it is sensible to oversize the supply a bit beyond 2.1A [#21664356] If you want better fault tolerance, you can split the load into two supplies for three cameras each instead of using a single point of failure [#21664355]
  • Use one 12 V supply with parallel branches
    #1 21664354
    giffen Ott
  • Recommend one 12V supply with 50% current margin
    #2 21664355
    Earl Albin
  • Parallel 12 V supply sizing and redundancy advice
    #3 21664356
    Chuck Sydlo
  • #4 21664357
    Chuck Sydlo
  • #5 21664358
    giffen Ott
  • Recommend basic electricity study resources
    #6 21664359
    Frank Bushnell
  • Unregulated wall transformers can overvoltage at light load
    #7 21664360
    Steve Lawson
  • Wall wart regulation and cord voltage drop
    #8 21664361
    Earl Albin
  • Unregulated wall warts can read far above rated voltage
    #9 21664362
    Steve Lawson
  • #10 21664363
    Steve Lawson
  • #11 21664364
    Steve Lawson
  • Recommend fused 7812 feeds with battery backup
    #12 21664365
    Mark Harrington
  • #13 21664366
    muhoza Eric
  • #14 21664367
    Chuck Sydlo
  • #15 21664368
    Steve Lawson
A user with limited electrical engineering knowledge seeks advice on powering six 12V 150mA cameras and their corresponding 12V 200mA LCDs from a single adapter without damaging the devices. The consensus is that all devices can be connected in parallel to a single regulated 12V power supply, as each device will draw only the current it requires. The total current demand is approximately 2.1A (900mA for cameras plus 1.2A for LCDs), so a power supply rated at 12V 2.5A or higher is recommended to provide sufficient margin and account for voltage drops over cable runs (up to 15 feet). It is emphasized that current does not need to be individually regulated; the devices' resistive loads limit current draw. However, caution is advised regarding the type of power supply used: many common "wall wart" adapters are unregulated and can have open-circuit voltages significantly higher than their rated voltage, potentially risking damage to sensitive electronics. Therefore, a regulated power supply is preferred. For security or fault tolerance, some suggest using individual regulated outputs with protection (e.g., LM7812 regulators and fuses) and possibly battery backup to prevent total system failure if one device faults. Basic electrical knowledge and reading device specifications are recommended to ensure compatibility and safe operation.
TL;DR: Power all 12 devices in parallel from one regulated 12 V supply; total draw ≈ 2.1 A, and “There is no need to regulate amperage.” [Elektroda, Chuck Sydlo, post #21664356]
Why it matters: This helps makers and security installers power multiple 12 V loads safely without a tangle of wall warts.
Can I power six 12 V cameras and six 12 V LCDs from one adapter?
Yes. Wire all devices in parallel to a single 12 V source. Ensure the supply’s current rating exceeds the combined load. The calculated draw is about 2.1 A. Choose a higher‑rated supply for reliability and voltage drop tolerance. “There is no need to regulate amperage.” [Elektroda, Chuck Sydlo, post #21664356]
How much current do I need in total at 12 V?
Add currents: six cameras at 150 mA (900 mA) plus six LCDs at 200 mA (1,200 mA). Total ≈ 2,100 mA, or 2.1 A. Select a supply rated above this number so it runs cool and handles cable losses. [Elektroda, Chuck Sydlo, post #21664356]
Do I need to limit or regulate current per camera or LCD?
No. Each device draws only what it needs at the correct voltage. With a 12 V source, current flow is set by each load. You do not add series resistors or current regulators for these devices. Oversizing the supply is acceptable. [Elektroda, Chuck Sydlo, post #21664356]
Should I use a regulated or unregulated 12 V supply?
Use a regulated supply. Many wall transformers output far above 12 V at light or no load, which can stress electronics. A regulated adapter maintains 12 V across typical loads, protecting your cameras and LCDs. [Elektroda, Steve Lawson, post #21664360]
Why does my 12 V wall wart read 15–18 V with nothing connected?
That’s normal for unregulated adapters. Measured examples showed 15.3 V (rated 12 V/200 mA) and 17.4 V (rated 12 V/700 mA) at open circuit. Voltage drops toward 12 V only under the rated load. Sensitive gear may not tolerate that surge. [Elektroda, Steve Lawson, post #21664364]
How much safety margin should I choose for the power supply?
Add a conservative margin so the adapter runs cool and lasts. A 50% cushion is a solid target. For many 12 V systems with multiple loads, a single ~50 W supply reduces clutter and increases reliability. [Elektroda, Earl Albin, post #21664355]
Will 10–15 ft cable runs cause problems at 12 V?
Yes, long thin wires add resistance and create voltage drop. That drop can cause low‑voltage behavior on distant cameras. Choose a larger current supply and use thicker cable or shorter runs to minimize losses. [Elektroda, Chuck Sydlo, post #21664356]
Is it okay to oversize the adapter, like using 10 A at 12 V?
Yes. A higher current rating is fine because devices draw only what they need. “If you find a supply that is 10 amps… don’t hesitate to use it.” Ensure correct voltage and proper wiring. [Elektroda, Chuck Sydlo, post #21664356]
How can I improve uptime if one device fails or someone cuts power?
Split the system into two parallel groups with separate supplies. That way, a single failure or cut disables only part of the system. Overlapping camera views add evidence even if one group goes down. [Elektroda, Chuck Sydlo, post #21664356]
What is a “wall wart”?
A wall wart is a plug‑in AC‑to‑DC adapter. Some are unregulated and output higher than their label at light load. Prefer regulated types for electronics like cameras and LCDs. [Elektroda, Steve Lawson, post #21664360]
What is an LM7812, and should I put one on each feed?
LM7812 is a linear 12 V regulator. A robust build can use a central supply with six fused, individually regulated outputs for isolation. This limits a fault on one line from dragging down others. [Elektroda, Mark Harrington, post #21664365]
How do I wire twelve 12 V devices in parallel safely?
  1. Use a regulated 12 V supply sized above 2.1 A.
  2. Distribute +12 V and ground to each device from a common terminal block.
  3. Keep runs short or use thicker wire to reduce voltage drop. [Elektroda, Chuck Sydlo, post #21664356]
What failure modes should I plan for?
A device with an internal fault can overdraw current and pull the supply down, dropping all units. Per‑branch fusing and isolated feeds reduce this risk. Splitting into two supplies raises resilience. [Elektroda, Mark Harrington, post #21664365]
Does this approach suit interactive installations with short runs (~15 ft)?
Yes. With ~15 ft runs, a 2.5 A or larger regulated 12 V adapter simplifies wiring and keeps voltage stable. This matches practical feedback from similar interactive camera setups. [Elektroda, giffen Ott, post #21664358]
Do I need individual fuses on each camera/LCD feed?
Individual fuses or resettable polyfuses per branch are good practice. They localize faults and prevent one failure from shutting everything down. Combine with a sturdy central 12 V supply. [Elektroda, Mark Harrington, post #21664365]
