How to Analyze and Synthesize Complex Waveforms in Signal Processing?
243 12
How do I interpret the `ωt` term and plot a sinusoidal waveform when the phase angles are given in degrees and the frequency is 50 Hz?
`ωt` means angular frequency `ω` multiplied by time `t`, which gives the phase angle at that instant; it is not the same thing as ordinary frequency, and you convert between them with `ω = 2πf` [#21664580] For a 50 Hz signal, one full cycle lasts 20 ms, so the argument goes from 0 to `2π` over that interval, and that is enough to plot one complete waveform [#21664579] If your constant phase angles are written in degrees, convert them to radians before using them in a radians-based sine calculation, or keep everything in degrees consistently [#21664571][#21664575] One reply also notes that the `Vol` term looks incorrect in its present form and suggests ignoring it unless the assignment defines it more clearly [#21664577] To plot it in a spreadsheet, make one column for time, another for the sine argument, compute each sine term, sum them, and graph the result against the time/argument column [#21664577]
  • wt means angular frequency times time
    #1 21664570
    Steve Lawson
  • #2 21664571
    Steve Lawson
  • #3 21664572
    Rick Rude
  • #4 21664573
    Steve Lawson
  • #5 21664574
    Rick Rude
  • #6 21664575
    Steve Lawson
  • #7 21664576
    Rick Rude
  • Excel plotting method for summed sine functions
    #8 21664577
    Earl Albin
  • Confusion over using ωt for a 50 Hz sine wave
    #9 21664578
    Rick Rude
  • Use 20 ms time scale with 400 µs increments
    #10 21664579
    Earl Albin
  • Angular frequency is not the same as frequency
    #11 21664580
    Steve Lawson
  • #12 21664581
    Earl Albin
  • #13 21664569
    Rick Rude
The discussion focuses on understanding and analyzing sinusoidal waveforms in signal processing, specifically the interpretation of the term "wt" in the equation r = 80sin(wt). "wt" represents the product of angular frequency (ω, in radians per second) and time (t), yielding the instantaneous phase angle in radians. It is emphasized that angular frequency differs from frequency (f, in cycles per second), with the conversion factor being 2π radians per cycle. To work with angles in degrees, constant phase shifts (e.g., 40° and -15°) should be converted to radians or vice versa, depending on the calculation or plotting requirements. For waveform plotting, it is recommended to generate time increments corresponding to one full cycle period (e.g., 20 ms for 50 Hz frequency), calculate the phase angle ωt for each increment, evaluate the sine function, and sum multiple sinusoidal components if needed. The confusion about the term "Vol" (possibly open loop voltage) and its multiplication factor was noted as likely incorrect or irrelevant for the waveform analysis. Practical advice includes using spreadsheet software like Excel to tabulate time, phase angle, individual sine values, and their sum for visualization. The importance of understanding basic trigonometry and signal parameters for waveform synthesis and analysis is highlighted.
TL;DR: To model AC signals, use ωt as phase; “w stands for the angular frequency in radians per second.” There are 2π radians per cycle. Convert units consistently to analyze, synthesize, and plot one clean 20 ms cycle for 50 Hz signals. [Elektroda, Steve Lawson, post #21664580]
Why it matters: This FAQ helps students and engineers avoid unit mix-ups when building and plotting sinusoidal waveforms.
What does wt mean in a sine like v(t) = A·sin(ωt + φ)?
wt is the instantaneous phase from angular frequency ω (radians/second) multiplied by time t. That product gives the angle used by the sine. As Steve explains, frequency f (cycles/second) is distinct from angular frequency. Quote: “w stands for the angular frequency in radians per second.” [Elektroda, Steve Lawson, post #21664580]
How do I convert between degrees and radians for phase?
Use radians = degrees × π/180 and degrees = radians × 180/π. Keep the same unit across ωt and any constant phase φ before evaluating sin(). A common check: 1 radian ≈ 57.2957795°. [Elektroda, Steve Lawson, post #21664573]
How do I handle phase offsets like +40° or −15°?
Convert the offsets to radians if ωt is in radians, or convert ωt to degrees if you prefer degrees. Example conversions shown: 40° ≈ 0.6981 rad and 15° ≈ 0.2617 rad. Apply the sign to φ inside sin(ωt + φ). [Elektroda, Rick Rude, post #21664574]
Is ω the same as frequency f?
No. Frequency f measures cycles per second, while ω is angular frequency in radians per second. They are related by ω = 2πf because each cycle spans 2π radians. Mixing them causes a 2π scale error. [Elektroda, Steve Lawson, post #21664580]
How long is one 50 Hz cycle and why plot only one?
One 50 Hz cycle is 1/50 s = 20 ms. Plotting one cycle is enough because the waveform repeats each cycle. Set your time axis from 0 to 20 ms to capture a full period cleanly. [Elektroda, Earl Albin, post #21664579]
What’s a simple 3‑step way to plot a phased sine in Excel?
  1. Create a time column from 0 to 20 ms in 50 steps of 0.4 ms.
  2. Compute the argument column as ωt ± phase, keeping consistent units.
  3. Compute A·sin(argument) and chart argument (x) vs result (y). [Elektroda, Earl Albin, post #21664577]
Do I need to plot 0–360° or 0–2π?
Either works, but keep it consistent. You can plot voltage versus radians directly, or convert the ωt terms to degrees first. Do not mix units within the same equation or chart. [Elektroda, Steve Lawson, post #21664575]
What does the “Vol” term in some equations mean?
In the thread, “Vol” appears ambiguous. Treat it as incorrect in that form and proceed without it, documenting why you removed it. Use a clear amplitude A instead. [Elektroda, Earl Albin, post #21664577]
How should I choose the sampling step for plotting?
Use a small, regular step that divides the period cleanly. Example: for 50 Hz, 0.4 ms steps yield 50 samples per 20 ms cycle, producing a smooth plot and simple math. [Elektroda, Earl Albin, post #21664579]
What’s a common mistake that breaks the waveform?
Confusing frequency f with angular frequency ω. Using f inside sin() without converting to ω under-scales the phase by 2π and distorts timing. “It’s important to distinguish frequency and angular frequency.” [Elektroda, Steve Lawson, post #21664580]
How do I compute phase at a specific time t?
Multiply angular frequency by time, then add any phase offset: θ(t) = ωt + φ. Evaluate sin(θ) using the same angle unit throughout. This directly yields the instantaneous voltage when scaled by amplitude A. [Elektroda, Steve Lawson, post #21664580]
Should sin() use degrees or radians in my calculator or code?
Use whichever your tool expects, but match your inputs. Either convert constants to radians and keep ωt in radians, or convert ωt to degrees. Consistency prevents phase errors and misaligned plots. [Elektroda, Steve Lawson, post #21664571]
