Correct Syntax for AND, OR, NOT Operations in MATLAB Editor Window
312 7
  • #1 21664694
    Zahoor Ahmad
  • #2 21664695
    Farhan Ali
  • #3 21664696
    Zahoor Ahmad
  • Requesting error message and operand data types
    #4 21664697
    Steve Lawson
  • Suggesting simpler languages and tools for logic operations
    #5 21664698
    Mark Harrington
  • #6 21664699
    Steve Lawson
  • #7 21664700
    Farhan Ali
  • #8 21664701
    Zahoor Ahmad
The discussion addresses the correct usage of logical AND, OR, and NOT operations in MATLAB's editor window. The original issue involved errors when using the '&' operator between variables 'a' and 'b'. Clarifications were sought regarding the data types and values of these variables, as MATLAB requires compatible scalar or array inputs for element-wise logical operations. References to MATLAB documentation on logical and element-wise operators were provided to guide proper syntax. Suggestions included verifying variable initialization and assignment of results to variables. Alternative programming environments such as C, Java, C#, Delphi, VBA in Excel, and JavaScript were mentioned as options for implementing logic gate operations. The user later indicated resolving the problem by sharing a working MATLAB script file. The key focus is on understanding MATLAB's logical operator syntax, data type compatibility, and proper coding practices for logic gate simulation.
