Why Do Stun Guns Advertise Million Volt Outputs Despite 0.5 Spark Gap Limitations?
462 11
Why do stun guns with spherical electrodes need much higher voltage to spark than pointed electrodes, and how does electrode shape affect the claimed output?
A pointed electrode breaks down air at a lower voltage because charge concentrates at the tip, creating a much stronger local electric field than on a sphere, where charge is spread more evenly [#21665269] [#21665270] At the same applied voltage, the total charge can be similar, but the needle has far higher charge density at the point, so the air ionizes and sparks sooner [#21665270] [#21665272] That is why sharp or needle electrodes spark more easily than spherical ones for the same gap [#21665270] [#21665272]
  • Spark-gap breakdown depends on electrode shape
    #1 21665268
    Stephen Van Buskirk
  • #2 21665269
    Steve Lawson
  • Needle electrodes concentrate charge and raise local field strength
    #3 21665270
    Cody Tappan
  • #4 21665271
    Stephen Van Buskirk
  • Electrode geometry concentrates charge density at points
    #5 21665272
    Cody Tappan
  • #6 21665273
    Mark Harrington
  • #7 21665274
    Ulf Kirchner
  • Safety concern about sharing stun gun information
    #8 21665275
    Mark Harrington
  • #9 21665276
    Steve Lawson
  • Public safety argument against online stun gun details
    #10 21665277
    Mark Harrington
  • #11 21665278
    Stephen Van Buskirk
  • #12 21665279
    Steve Lawson
The discussion addresses the discrepancy between advertised stun gun voltages, often claimed to be in the millions, and the practical voltage limits imposed by spark gap measurements and skin conduction resistance. It is explained that the high voltage ratings are influenced by electrode geometry, particularly the concentration of charge density at pointed conductors versus spherical electrodes. Pointed electrodes create localized high charge density, increasing the electric field strength and causing air breakdown at lower voltages compared to spheres, which distribute charge evenly. This explains why spark gaps in handheld stun guns, typically around 0.5 inches, correspond to much lower actual voltages (tens of kilovolts) than the advertised million volts. The discussion also touches on the physics of charge distribution in conductors, the role of capacitance and dielectric layers in preventing arcing, and the practical voltage outputs of police tasers, which are around 4000 volts. Some responses diverge into ethical concerns and unrelated commentary, but the core technical explanation centers on electrode geometry affecting voltage measurement and advertising claims.
TL;DR: A 1-inch air gap typically needs about 30 kV with needle points or ~70 kV with spheres; “spark gaps are used to measure high voltages.” Overstated “million-volt” stun-gun claims ignore these limits. [Elektroda, Stephen Van Buskirk, post #21665268]
Why it matters: This FAQ helps engineers, buyers, and curious readers fact-check stun-gun voltage claims and understand spark-gap physics.
Are “million-volt” stun-gun claims realistic with a 0.5–1 inch spark gap?
Not in open air. A 1-inch gap needs about 30 kV with needles or ~70 kV with spheres. That is far below one million volts. Many products cite theoretical or no‑load peaks, not actual air-gap breakdown. Half‑inch display gaps further constrain real voltages. [Elektroda, Stephen Van Buskirk, post #21665268]
Why do pointed electrodes spark at lower voltage than spheres?
Points concentrate charge and create a stronger local electric field. The higher field reaches air’s breakdown sooner than a smooth sphere with the same applied voltage. As one expert put it, “a pointed conductor causes a concentration of charge.” [Elektroda, Steve Lawson, post #21665269]
What does “charge density” mean in this context?
Charge density describes how much charge accumulates per unit area or volume on a conductor’s surface. Geometry drives it. Sharp features force charges into smaller regions, raising local density and field strength. That’s why points initiate arcs more easily than smooth shapes. [Elektroda, Cody Tappan, post #21665272]
Do a sphere and a needle at the same voltage have the same potential but different fields?
Yes. The conductor surfaces share the applied potential, but the needle tip hosts a far stronger local field due to concentrated charge. That stronger field facilitates ionization and arc initiation at lower overall voltage. [Elektroda, Cody Tappan, post #21665270]
How much voltage do police Tasers reportedly output?
One analysis cited in the discussion notes police Tasers around 4,000 volts, which aligns with practical spark-gap requirements rather than “million-volt” marketing. Use such figures to sanity‑check claims. [Elektroda, Stephen Van Buskirk, post #21665268]
Why do arcs start at high voltage but continue at lower voltage?
Before breakdown, air is an insulator. After ionization, the channel conducts and its required sustaining voltage drops markedly. This causes a visible, loud arc that can persist at lower voltage than the initial strike. [Elektroda, Stephen Van Buskirk, post #21665268]
Can I estimate required voltage from the visible spark gap?
Yes, roughly. Use ~30 kV per inch for needle electrodes and ~70 kV per inch for spheres in dry air. Multiply by your observed gap length to estimate striking voltage. Treat results as approximate, not as safety ratings. [Elektroda, Stephen Van Buskirk, post #21665268]
Is fitting a 10 kV capacitor into a handheld stun gun practical?
The thread notes how challenging high‑voltage energy storage is in small enclosures. High‑voltage capacitors have size and insulation constraints, making the bold energy claims suspect for pocket devices. [Elektroda, Stephen Van Buskirk, post #21665268]
What is a spark gap and why is it used to gauge high voltage?
A spark gap is the space between two electrodes across which a discharge occurs. Because air breaks down at characteristic fields, engineers use controlled gaps and geometry to infer approximate high voltages by whether a spark jumps. [Elektroda, Stephen Van Buskirk, post #21665268]
Does electrode shape matter as much as gap length?
Yes. Geometry sets charge density and local field. Needles lower the striking voltage versus spheres for the same gap. Uniform fields (smoother shapes) demand higher striking voltages than sharp points. [Elektroda, Cody Tappan, post #21665270]
Is there consensus on the ethics and safety of stun guns?
Opinions differ. One participant argues stun guns cause comparatively few deaths and may reduce lethal outcomes, while acknowledging myths and urging fact‑based debate. Treat use policy and ethics separately from physics. [Elektroda, Stephen Van Buskirk, post #21665278]
How can I sanity‑check a stun gun’s advertised voltage quickly?
Look at the visible arc length and electrode shape. Then estimate striking voltage using typical kV‑per‑inch values. If the estimate is tens of kV but the box claims a million volts, treat that as marketing, not measurement. [Elektroda, Stephen Van Buskirk, post #21665268]
What’s an example of a failure mode or edge case with arcs?
Once a discharge begins, the plasma channel can persist briefly even if the supply sags. That can mask weak supplies during demos because sustaining voltage is much lower than the striking voltage. [Elektroda, Stephen Van Buskirk, post #21665268]
Quick How‑To: estimate arc voltage from a demo video
  1. Identify approximate gap length from frame stills (e.g., 0.5 or 1 inch).
  2. Note electrode shape: point‑to‑point (needle) or rounded (sphere‑like).
  3. Multiply gap by ~30 kV/in (needle) or ~70 kV/in (sphere) to get striking voltage. [Elektroda, Stephen Van Buskirk, post #21665268]
