How does a 950,000 Volt stun gun generate high voltage from 2 lithium batteries?
345 8
  • #1 21667873
    Daniel Kinney
  • 950,000 volts dismissed as unrealistic claim
    #2 21667874
    stephen Van Buskirk
  • #3 21667875
    Steve Lawson
  • #4 21667876
    Ruben Proost
  • #5 21667877
    Steve Lawson
  • #6 21667878
    Ruben Proost
  • Questioning whether Doc Brown was a science poser
    #7 21667879
    Steve Lawson
  • #8 21667880
    Ruben Proost
  • #9 21667881
    Steve Lawson
The discussion addresses the claim of a 950,000 Volt stun gun powered by two lithium batteries, questioning the feasibility of generating such high voltage in a compact device. It is explained that achieving 950,000 volts is unrealistic due to physical and component limitations, such as the need for large electrode gaps to produce sparks at that voltage and the impracticality of carrying high-voltage capacitors. Real police tasers typically output less than 10,000 volts. The conversation briefly touches on the likely use of oscillator and transformer circuits in stun guns but emphasizes that the stated voltage is likely exaggerated or a marketing fantasy rather than a technically accurate specification.
