Why Does 32V AC Pose More Risk Than 32V DC for Electric Shock and Injury?
348 9
Why can 32 V AC be more dangerous than 32 V DC for electric shock, especially for causing ventricular fibrillation?
AC is more dangerous than the same nominal DC voltage because it can trigger ventricular fibrillation at much lower current, around 60 mA for 60 Hz AC versus about 300–500 mA for DC [#21660344][#21660347] The main factor is current through the body, since voltage is what pushes that current [#21660350] Also, 32 V AC is usually an RMS value, so its peak is about 45 V, which is not the same as 32 V DC [#21660349][#21660350] One reply notes that DC can cause muscle lock-up instead, and the heart may restart after the current is removed, while AC reverses 50 or 60 times per second and is more likely to disturb the heart’s rhythm [#21660347] Even low voltages can be dangerous if the current path crosses the heart, because much of the body’s resistance is in the skin and internal tissue can be around 500 ohms [#21660347]
  • #1 21660343
    Richard Bosanquet
  • #2 21660344
    Cody Miller
  • #3 21660345
    Richard Bosanquet
  • #4 21660346
    Cody Miller
  • AC more dangerous due to fibrillation risk
    #5 21660347
    Steve Greenfield
  • #6 21660348
    Richard Bosanquet
  • #7 21660349
    BHARADWAJ ACHARYA
  • #8 21660350
    Steve Greenfield
  • #9 21660351
    BHARADWAJ ACHARYA
  • #10 21660352
    bob Lin
The discussion explains why 32V AC poses a greater risk of electric shock and injury compared to 32V DC. AC current at typical mains frequencies (50-60 Hz) can cause ventricular fibrillation at much lower currents (around 60 mA RMS) than DC, which requires significantly higher currents (300-500 mA) to induce fibrillation. This is because AC reverses direction multiple times per second, disrupting the heart's electrical signals and causing fibrillation, whereas DC tends to cause muscle contraction or "locking" without fibrillation. Additionally, 32V AC is usually specified as an RMS value, meaning its peak voltage is about 1.414 times higher (~45V peak), increasing its potential to drive harmful current through the body. The severity of electric shock depends primarily on the current flowing through the body, which is influenced by voltage and body resistance (typically around 500 ohms internally). Lower voltages like 5V or 12V DC are generally safer due to insufficient current to cause lethal effects. Medical defibrillation uses high-energy DC pulses to reset the heart rhythm, not AC. Overall, AC is more hazardous at lower voltages due to its alternating nature and higher effective peak voltage compared to DC at the same RMS voltage.
