VHDL Design for Asynchronous Combination Lock with Four Two-Bit Input Sequence
342 9
How do I design a VHDL combination lock that behaves like an asynchronous circuit, using a four-symbol two-bit input sequence and an asynchronous reset?
Start with a state diagram, because this lock is essentially a synchronous finite-state sequence detector with a fast clock and asynchronous reset, and the hardware/VHDL should come after the states are defined [#21665703][#21665705] Build the design around finite-state-machine ideas and sequence-detector examples, since those are the key references suggested in the thread [#21665705] The circuit should stay in each state until the input changes to a new symbol, so the state diagram needs to reflect symbol changes rather than repeated identical inputs [#21665703] If you are stuck, study FSM notes and sequence-detector references, and bring your partial design and research to your tutor rather than arriving empty-handed [#21665705][#21665708]
  • Asynchronous lock requires synchronized two-bit inputs
    #1 21665700
    EEWeb
  • #2 21665701
    Frank Bushnell
  • #3 21665702
    EEWeb
  • Need a state diagram before hardware design
    #4 21665703
    Mark Harrington
  • #5 21665704
    EEWeb
  • #6 21665705
    Mark Harrington
  • #7 21665706
    Mark Harrington
  • #8 21665707
    EEWeb
  • General advice to plan ahead and seek tutor help
    #9 21665708
    Frank Bushnell
  • #10 21665709
    EEWeb
The discussion centers on designing a VHDL-based asynchronous combination lock that uses a sequence of four two-bit input symbols, with the constraint that no consecutive symbols are identical. Although the lock appears asynchronous, it is implemented as a synchronous circuit with a fast clock and input synchronization. The lock state cycles until a new input symbol is detected, and an asynchronous RESET is used to lock the system. Key advice includes starting with a state diagram to model the finite state machine (FSM) before hardware design, as FSMs are critical for sequence detection and control logic. References to multiplexers, demultiplexers, counters, and sequence detectors are made as relevant components. Emphasis is placed on early study, consulting tutors for help, and documenting all design attempts to secure partial credit if the project is incomplete. The complexity of FSM design and sequence detection is acknowledged, with encouragement to persist and visualize the problem clearly.
