Best Photodiode or Phototransistor for Measuring Sunlight 500–30,000 Lux Range
237 8
  • #1 21665846
    John S
  • #2 21665847
    Peter Evenhuis
  • #3 21665848
    Mark Harrington
  • #4 21665849
    Peter Evenhuis
  • Suggested photodetectors and temperature compensation ideas
    #5 21665850
    Steve Lawson
  • Using a green LED as a reverse-biased light sensor
    #6 21665851
    John S
  • #7 21665852
    Steve Lawson
  • #8 21665853
    Steve Lawson
  • #9 21665854
    John S
The discussion focuses on identifying suitable photodiodes or phototransistors capable of measuring sunlight intensity within a 500 to 30,000 lux range, addressing limitations of sensors accurate only up to about 1000 lux. Suggestions include using green LEDs as photodetectors, which can generate a voltage or current when exposed to light, potentially serving as low-cost, simple sunlight sensors. The LED’s spectral sensitivity to its own color and the need for transparent housing are noted. Other proposed photodetectors include solar cells, photoresistors (LDRs), reverse-biased LEDs, and PIN diodes. Sensitivity adjustments can be managed via apertures, lenses, or reflectors, while temperature effects might be compensated using thermistors or reference sensors in Wheatstone bridge configurations. Practical experimentation with LEDs connected to voltmeters or ammeters is encouraged to evaluate their response to sunlight.
