Voltage Transducer Circuit: How 110V AC Is Converted to 4-20mA Signal and Sensing Explained
474 12
How does a 110 VAC voltage transducer sense the voltage and convert it to a 4–20 mA signal, and what can cause it to drift out of calibration?
A typical voltage transducer does not measure AC voltage directly; it senses a current proportional to the voltage by using an external resistor, and in at least one example model (LV25-P) that current is detected with a Hall-effect device to produce the output signal [#21665859] For your TM3UL20, the forum answer suggests the unit has likely drifted out of calibration if it now outputs 21–22 mA at 110 VAC and the zero/span potentiometers no longer bring it back into range [#21665867] Since manufacturers often do not publish the internal circuit, the practical next steps are to look for a patent, disassemble the transducer, and reverse-engineer it if needed [#21665867] A failed or drifted internal component, such as an overheated resistor with an increased value, is one possible cause to check for [#21665867]
  • #1 21665857
    ARJ
  • Advice to research voltage transducers before asking
    #2 21665858
    Mark Harrington
  • LV25-P uses hall-effect current sensing
    #3 21665859
    Steve Lawson
  • Need a specific transducer to answer compatibility
    #4 21665860
    Chuck Sydlo
  • #5 21665861
    Earl Albin
  • Polite requests get better technical help
    #6 21665862
    Mark Harrington
  • Ferrite rod coil used as magnetic transducer
    #7 21665863
    Shrikant Kamble
  • Need calibration and ferrite rod orientation control
    #8 21665864
    Steve Lawson
  • Request for exact 110 V AC to 4-20 mA transducer circuit
    #9 21665865
    ARJ
  • Transducer drift leaves 21–22 mA at 110 VAC
    #10 21665866
    ARJ
  • Out-of-calibration TM3UL20 may need reverse engineering
    #11 21665867
    Steve Lawson
  • Question about grounding a resistor voltage divider to the load
    #12 21665868
    Cactus jack
  • Use opto isolator for isolated voltage measurement
    #13 21665869
    Steve Lawson
The discussion centers on understanding how a voltage transducer converts 110V AC into a 4-20mA current signal and the sensing mechanism involved. Voltage transducers are devices that convert electrical energy from one form to another, often used to monitor voltage by producing a proportional current output. One example is the IME TM3UL20 voltage transducer, which senses 110V AC and outputs a 4-20mA signal; however, calibration issues such as inability to adjust zero and span potentiometers can cause output errors (e.g., outputting 21-22mA at nominal voltage). A practical sensing approach involves using a ferrite rod coil with hundreds of turns of fine wire to detect magnetic fluctuations from the AC line, amplified by a transistor circuit to generate a 4-20mA current loop. This method requires additional circuitry for calibration and temperature stabilization and a fixed coil orientation for consistent readings. Alternative measurement methods include voltage dividers and isolation techniques (e.g., optocouplers) to safely interface microcontrollers with high-voltage lines. The LV25-P transducer, based on Hall-effect sensing, is mentioned as a current transducer that can be adapted for voltage measurement by using an external resistor to convert voltage to current. Overall, detailed circuit schematics are scarce, and manufacturers often do not disclose internal designs, making reverse engineering or patent research necessary for in-depth understanding.
TL;DR: To turn 110 V AC into a 4–20 mA signal, you first sense voltage (e.g., Hall-effect core), then scale and condition it; “Voltage is measured by passing a current proportional to the measured voltage.” A ferrite pickup may use 300–400 turns. [Elektroda, Steve Lawson, post #21665859] Why it matters: This FAQ helps technicians pick, wire, and troubleshoot voltage-to-current transducers for controls and SCADA.
What is a voltage transducer, in plain terms?
A voltage transducer converts electrical energy in the form of voltage into another signal form for measurement or control. In practice, it can transform sensed voltage into a proportional current, such as 4–20 mA, for robust transmission to controllers. The word “transducer” covers many devices that convert one energy form to another, including electrical and biological examples. Pick the specific type to match your range, isolation, and accuracy needs. [Elektroda, Chuck Sydlo, post #21665860]
How does a Hall‑effect voltage transducer work?
You pass a current proportional to the measured voltage through an internal conductor; a Hall sensor reads the magnetic field from that current. The device outputs a signal proportional to the original voltage, with galvanic isolation set by the core and insulation. An external resistor sets the sensing current and therefore the measurement range. As one expert put it, “Voltage is measured by passing a current proportional to the measured voltage.” [Elektroda, Steve Lawson, post #21665859]
How do I convert 110 V AC to a 4–20 mA loop signal?
Sense the voltage with an isolated transducer, scale it with an external resistor, then condition and map the reading to 4–20 mA. The loop current then represents your monitored AC level for PLC/SCADA. Conceptually, you measure voltage by creating a proportional current, then translate that into the standardized loop range for transmission. This approach keeps noise low and allows long cable runs to control rooms. [Elektroda, Steve Lawson, post #21665859]
My IME TM3UL20 now reads 21–22 mA at 110 V. What does that mean?
That behavior indicates an overrange or drift fault. The unit worked for 1–2 years, then produced 21–22 mA even with zero and span at minimum. This points to internal drift, component aging, or a failure that calibration can’t correct. Treat it as a miscalibrated or failing transmitter until inspected or repaired. This symptom is a practical field indicator of fault. [Elektroda, ARJ, post #21665866]
Zero and span won’t bring it back. What should I check next?
Assume the device is out of calibration. Open a non‑warranty unit for inspection if allowed. Look for overheated or drifted resistors and damaged parts, then consider reverse‑engineering the signal path to identify failure points. If you lack documentation, note board markings and search key components. “Sounds like it has gone out of calibration,” which adjustment alone may not fix. [Elektroda, Steve Lawson, post #21665867]
Can I sense mains with a ferrite rod and coil as a quick test?
Yes, as a proof‑of‑concept magnetic pickup. Wind about 300–400 turns of 36‑gauge wire on a ferrite rod, amplify the induced voltage with a transistor stage, and load the collector with a low‑impedance element to obtain 4–20 mA. This demonstrates magnetic coupling to the AC line’s field, not a calibrated measurement. Expect weak signals and the need for gain. [Elektroda, Shrikant Kamble, post #21665863]
What pitfalls exist with the ferrite‑rod method?
You must mechanically fix the rod near the conductor and control orientation for repeatability. Add temperature compensation and a calibrated conditioning chain, or readings drift. Without these, your output varies with placement and ambient changes. As one expert cautioned, the real build is “more complicated” than a simple coil‑plus‑transistor sketch suggests. [Elektroda, Steve Lawson, post #21665864]
Do I need to share ground between my MCU and the measured circuit?
Only if your MCU is battery‑powered and safe from hazardous voltages. Otherwise, keep grounds isolated to protect the MCU and users. Use opto‑isolators or isolated transducers to bridge measurement across different ground potentials. This avoids ground loops and shock risks when monitoring higher voltages. [Elektroda, Steve Lawson, post #21665869]
How can I measure voltage while maintaining isolation to my microcontroller?
Use an isolation strategy at the sensing interface. Options include an isolated voltage transducer feeding your MCU through analog scaling, or an optocoupler‑based front end that transfers a proportional signal across a safe barrier. Isolation is essential when the MCU is not floating on a battery supply. [Elektroda, Steve Lawson, post #21665869]
What is a 4–20 mA current loop, and why use it for voltage monitoring?
A 4–20 mA loop encodes the measured variable as loop current for noise‑immune transmission. You convert sensed voltage into loop current so long cables and EMI don’t corrupt readings. The scheme supports a live zero at 4 mA and scales to 20 mA for full‑scale. It integrates easily with PLC analog inputs via a loop receiver. [Elektroda, Steve Lawson, post #21665859]
Which components most often fail when a transducer drifts high?
Look for stressed resistors in the scaling network, aged electrolytics, or damaged semiconductors in the conditioning stage. Visual signs include discoloration or cracking. Replace suspect parts and recalibrate. If the device still pegs high, the sensing element or reference may be compromised and require replacement. [Elektroda, Steve Lawson, post #21665867]
Can you give me a simple 3‑step check for a misreading unit?
  1. Verify applied voltage and wiring, then set zero/span to midscale.
  2. Measure loop current with a trusted meter and note drift.
  3. Inspect internally for overheated parts; repair and recalibrate, or replace. [Elektroda, Steve Lawson, post #21665867]
What is the LEM LV 25‑P that was mentioned?
It’s a Hall‑effect voltage transducer that senses voltage by driving a proportional current and reading the resulting magnetic field. An external resistor sets the measurement range, and the design provides galvanic isolation between primary and secondary circuits. It’s widely used for isolated voltage monitoring. [Elektroda, Steve Lawson, post #21665859]
What is the LEM HLSR‑P current transducer used by another poster?
HLSR‑P is a closed‑loop Hall‑effect current sensor family with galvanic isolation and an analog output proportional to primary current. It’s suitable for MCU interfacing and keeps measurement isolated from power circuits. Use it when you need accurate current feedback without sharing grounds. [LEM, HLSR‑P SP33 Datasheet]
Is there a quick way to prototype a voltage‑to‑current transmitter?
Pair an isolated voltage transducer with a loop‑powered 4–20 mA stage. Sense voltage via a Hall‑effect module, scale to a control voltage, and drive a 4–20 mA loop element. This splits isolation and loop generation, easing calibration and safety. [Elektroda, Steve Lawson, post #21665859]
Who is this FAQ for, and what problem does it solve?
For technicians and engineers who must monitor 110 V AC and feed PLC/SCADA via 4–20 mA. It explains sensing options, isolation practices, calibration pitfalls, and fault symptoms like persistent 21–22 mA overrange. Use it to choose, wire, and fix voltage transducers confidently. [Elektroda, ARJ, post #21665866]
